05-08-2013 08:48 AM - edited 03-16-2019 05:13 PM
Hello All
I have a cisco 2921 with 4fxs ports that I need to configure to attach pdq's and fax devices.
Are these the options I have:
Configure ports as either mgcp or sccp. Either way I will have to add a new gateway with the 4 ports on cucm. The 2921 is currently a H323 gateway.
Will the MGCP config look something like this:
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.107.14.67
ccm-manager config
mgcp
mgcp call-agent 10.107.14.67 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711ulaw
mgcp ip qos dscp cs3 signaling
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
dial-peer voice 99920 pots
service mgcpapp
port x/x
For SCCP
sccp local GigabitEthernet0/0
sccp ccm 10.129.16.21 identifier 4 priority 3 version 7.0
sccp ccm 10.129.16.22 identifier 3 priority 2 version 7.0
sccp ccm 10.129.16.23 identifier 2 priority 1 version 7.0
sccp ccm 10.129.16.24 identifier 1 priority 4 version 7.0
sccp ip precedence 3
sccp
sccp ccm group 101
associate ccm 2 priority 1
associate ccm 3 priority 2
associate ccm 4 priority 3
associate ccm 1 priority 4
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 15
dial-peer voice 8001 pots
service stcapp
port 0/1/1
I will have ATA 187s and VG224's with fax machines attached with modem pass through enabled so will I need this on the Integrated Gateway as well as the vg224 (sccp controlled):
voice service voip
fax protocol pass-through g711alaw (or no fax protocol?)
h323
modem passthrough nse codec g711alaw
Another question regarding the VG224's, if the ports are sccp controlled do I need dialpeers pointing to pstn gateway with destination 9T or pointing to the cucm cluster as the ports will use cucm for routing calls won't they?
Many thanks
Feisal
Solved! Go to Solution.
05-08-2013 03:07 PM
Yes you dont need dial-peer son the VG224
Modem pass through can be configured on either a global levell
voice service voip
modem pass-through nse codec g711ulaw
Or on each dial-peer
dial-peer voice xx voip
destination-pattern xxxxxxx
incoming called-number .
session target ipv4:X.X.X.X
codec g711ulaw
fax rate disable
fax nsf 000000
no vad
Yes they can talk to each other..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
05-08-2013 01:11 PM
The sccp devices will be under cucm conroll.hence they will use the dial plan in CUCM for outbound calls. If your gateway is mgcp then you dont need any dial-peer, if its h323 you still need dial-peers for routing to the PSTN
05-08-2013 02:23 PM
Voice gateway is h323 and has VoIP and pots dial peers. From what you say I will not need dial peers on the vg224 as it is cucm controlled.
Any input on the the config needed for modem pass through on both the voice gateway and the vg224.
This might be a daft question but can a fax that is mgcp controlled port originating fax talk to a sccp controlled port terminating fax on the same ip network?
05-08-2013 03:07 PM
voice service voip
codec g711ulaw
fax rate disable
fax nsf 000000
no vad
05-09-2013 01:24 AM
I will give it a go and let you know the results.
