Walkthrough Wednesdays
987
Highlighted
Beginner
FXS ports showing Unknown state, but calls can be completed.
Hi, I'm having a problem with a mgcp configuration, some ports show Registered status and others show Unknown status. But all analog phones can complete calls normally, I have rebooted the router many times and it happens allways with the same ports.
here is my configuration:
Current configuration : 5233 bytes
! Last configuration change at 22:21:29 UTC Fri Sep 6 2013 by cisco
! NVRAM config last updated at 22:21:05 UTC Fri Sep 6 2013 by cisco
version 15.2
hostname RT2901VESTPOC01
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp excluded-address 172.34.3.97 172.34.3.106
ip dhcp pool Voz
network 172.34.3.96 255.255.255.224
default-router 172.34.3.97
option 150 ip 172.21.200.10
no ipv6 cef
voice-card 0
application
global
  service alternate Default
license udi pid CISCO2901/K9 sn FTX1703845H
hw-module pvdm 0/0
vtp mode transparent
redundancy
vlan 201
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/3/0
switchport access vlan 201
no ip address
spanning-tree portfast
interface FastEthernet0/3/1
no ip address
interface FastEthernet0/3/2
switchport voice vlan 201
no ip address
interface FastEthernet0/3/3
no ip address
interface Vlan1
no ip address
interface Vlan201
ip address 172.34.3.98 255.255.255.224
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.34.3.97
control-plane
voice-port 0/0/0
cptone CO
voice-port 0/0/1
cptone CO
voice-port 0/0/2
cptone CO
voice-port 0/0/3
cptone CO
voice-port 0/1/0
cptone CO
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
cptone CO
timing hookflash-out 50
timing guard-out 1000
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
ccm-manager fallback-mgcp
ccm-manager redundant-host 172.21.200.10
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.21.200.10 172.21.200.40
ccm-manager config
mgcp
mgcp call-agent 172.21.200.40 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
dial-peer voice 999000 pots
service mgcpapp
port 0/0/0
dial-peer voice 999001 pots
service mgcpapp
port 0/0/1
dial-peer voice 999002 pots
service mgcpapp
port 0/0/2
dial-peer voice 999003 pots
service mgcpapp
port 0/0/3
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 5212 pots
description "S. Reunion"
destination-pattern 5212
port 0/0/0
forward-digits all
dial-peer voice 5213 pots
description "Jefatura Pocitos"
destination-pattern 5213
port 0/0/1
forward-digits all
dial-peer voice 5214 pots
description "Vivienda OP Pocitos"
destination-pattern 5214
port 0/0/2
forward-digits all
dial-peer voice 5215 pots
description "Casa Huespedes"
destination-pattern 5215
port 0/0/3
forward-digits all
dial-peer voice 5216 pots
description "Porteria"
destination-pattern 5216
port 0/1/0
forward-digits all
dial-peer voice 9 pots
description "llamadas externas en SRST"
destination-pattern 9T
port 0/2/0
gatekeeper
shutdown
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 172.34.3.98 port 2000
max-ephones 25
max-dn 25
system message primary MODO SUPERVIVENCIA
system message secondary SRST Fallback
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input telnet ssh
scheduler allocate 20000 1000
ntp authentication-key 1 md5 08711F1B5B492747425B2A540F790079126404 7
ntp authenticate
ntp trusted-key 1
ntp server 172.20.197.18
end
3 REPLIES 3
Highlighted
Advisor
this could be a cosmetic problem since all ports whether regsitered/unregsitered  are working.
what is the exact router/CUCM version and FXS card model?
regds,
aman
Highlighted
Hi Aman.
CUCM is 8.6.2.23900
Router 2901, IOS: c2900-universalk9-mz.SPA.152-4.M2.bin
FXS card model: VIC3-4FXS/DID
Highlighted
Can u also share output of following commands from the router ?
a. show mgcp endpoints
b. show voice port summary
c. show voice call summary
d. show dial-peer voice summary
Did u ever try to restart RIS Data Collector service?
regds,
aman
Content for Community-Ad
