04-23-2013 06:16 PM - edited 03-16-2019 04:58 PM
Hello people,
I'm newer inside Cisco voip and I wonder it's possible do an communication between FXS and FXO ?
I have two router device one with FXS Interface witch has a analog phone pluged and other router has a PABX that supplies FXO Interface.
I need do called between each other, it's possible ?
if someone has an tip about how to please post here or any doc about
thanks
04-24-2013 03:37 AM
Yes it's possible. Simply a matter of dial-peers. Related reading:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Here's an overly simplified config example. There are many additional command options but this gets the ball rolling:
!The FXO port
voice-port 0/1/0
!Where you want the router to direct incoming calls
connection plar opx 1234
caller-id enable
!The FXS port
voice-port 0/2/0
station-id name Example
station-id number 1234
dial-peer voice 100 pots
destination-pattern
port 0/1/0
dial-peer voice 200 pots
destination-pattern 1234
port 0/2/0
Please remember to rate helpful responses and identify helpful or correct answers.
05-03-2013 08:39 AM
Thank you Jonathan for your tip.
I had done a test but unsuccess. I don't know why but my Interface FXO seems no detect the ring pulse because when into a call from my PABX to the extention it's pluging in that FXO nothing happen.
I think there is some tuning to do at the configuration about ring, pulse, etc. but I don't know where neither how to
any tip about how to tuning that it's welcome.
thanks
05-07-2013 05:51 PM
Sorry my persistence about that issue below follow parts of configuration and a draw.
My problem is when the call come from of extention 21 ( FXO ) to extention 2000 ( FXS ) of course numer dialer is 20 ( number of extention PABX ) but nothing happen on router A. when I turn on debug nothing appear! I Think should shows anything on console but nothing. so I wonder what is happen ?
When the call come from FXS interface to FXO it's work!
any tip about is welcome
Configuration on Router A
voice-port 0/1/0
connection plar opx 2000
caller-id enable
destination-pattern 21
port 0/1/0
dial-peer voice 101 voip
destination−pattern 2000
dtmf−relay h245−alphanumeric
session target ipv4:10.80.80.1
Configuration on Router B
voice-port 0/2/0
station-id name example
station-id number 2000
cptone BR
supervisory disconnect signal
destination-pattern 2000
port 0/2/0
dial−peer voice 201 voip
destination−pattern 21
session target ipv4:10.80.80.2
05-07-2013 08:49 PM
Please capture the following debugs on both routers for the not working call:
deb voice ccapi inout
deb vpm signal
deb h225 asn1
Do "term mon" and/or "logging console" and capture the output.
Jorge Armijo
05-08-2013 03:57 PM
Thank you Jorge I'm going that test on friday and come back here next week.
thanks
