G.711 and G.729 Codec between sites
can any one tell me how to configure G.711 and G.729 Codec between two different Branch Sites ???
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
configure a region for each site, assign the region to a device pool, assign DP to devices. configure the codec between regions to be G729
I'd recommend you to fully read the CUCM admin guide and also features and services guide
java
if this helps, please rate
java
ok
gr8 thanks java ...
