04-23-2009 04:08 PM - edited 03-15-2019 05:38 PM
can any one tell me how to configure G.711 and G.729 Codec between two different Branch Sites ???
04-23-2009 04:52 PM
configure a region for each site, assign the region to a device pool, assign DP to devices. configure the codec between regions to be G729
I'd recommend you to fully read the CUCM admin guide and also features and services guide
java
if this helps, please rate
04-24-2009 12:30 AM
ok
gr8 thanks java ...
