Just abit of guidance regarding voice jitter issues over 4 concurrent calls.
We have a international remote site with 17 Cisco Phones, registered at our Data Centre CUCM over a 10MB MPLS. The phones voice calls terminate at our Voice Gateway also located in the same Data Centre. I have set G.711 as the codec.
During 4 concurrent calls from the PSTN to the remote office telephone, all is well but the 5th call experience jitter either for the 5th call or one of the existing calls.
We are looking at QoS setup but it wouldn't be the case since the link at both ends of the MPLS are not congested.
Could this be more on the CUCM?
Solved! Go to Solution.
It could be QoS issue depending on what SLA you have with your MPLS circuit service provider. Your link may be under-utilized, but if traffic is not treated with priority as the SPs backbone, you may be experiencing delay jitter.
First, look your own QoS configuration in case you re-mark RTP traffic (above some threshold) from EF to some other value. Then, check that with your provider as well.
Thanks for the reply. We are working on QoS at the moment end to end.
The remote site mentioned that inbound calls from UCCX to the remote agents have issues in call quality but outbound calls from agents phones is OK?
Both inbound and outbound go through the same hub Voice Gateway.
UCCX or do you think its still QoS and egress link is congestion compare to ingress?
Peter
