G729 trunk to CME and G711 to CUE Mailbox
I have problem that when i call form trunk and there is no answer it has to go to Mailbox buat it is directly disconnected
it seem that the problem is in codec because to trunk the codec that used is G729 but to CUE is G711
i already configured the transcode for that, but still cannot goes into mailbox from trunk, what i miss ?
this is the configuration for that
voice-card 0
 dspfarm
 dsp services dspfarm
voice service voip
 mode border-element
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip refer
 no supplementary-service sip handle-replaces
 fax protocol t38 version 3 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
 sip
  header-passing
  registrar server expires max 3600 min 600
  early-offer forced
  no silent-discard untrusted
  midcall-signaling passthru
interface SM1/0
 ip unnumbered GigabitEthernet0/0
 service-module ip address 192.168.100.10 255.255.255.0
 !Application: CUE Running on SM
 service-module ip default-gateway 192.168.100.1
 no keepalive
sccp local GigabitEthernet0/0
sccp ccm 192.168.100.1 identifier 1 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate profile 1 register mtpac7e8a2ade21
dspfarm profile 1 transcode
 codec g711alaw
 codec g711ulaw
 codec g729br8
 maximum sessions 6
 associate application SCCP
dial-peer voice 2200 voip
 destination-pattern 2200
 session protocol sipv2
 session target ipv4:192.168.100.10
 dtmf-relay rtp-nte sip-notify
 codec g711ulaw
 no vad
thanks & regards,
Rocky
Okay, can you please add this..
voice service voip
no sup sip moved
Do another test call and send me
debug ccsip messages
Please rate all useful posts
6 Replies 6
Ayodeji Okanlawon
The configuration you have posted here is not enough to make your xcoder register.
Where is your telephony-service commands/config..You need the ff commands
telephony-s
sdsp units 2
sdsp trans sess 6
sdsp tag 1 mtpac7e8a2ade21
ooh sorrry.. here is the telephony-service config
telephony-service
 sdspfarm units 1
 sdspfarm transcode sessions 6
 sdspfarm tag 1 mtpac7e8a2ade21
 video
 no auto-reg-ephone
 max-ephones 30
 max-dn 30
 ip source-address 192.168.100.1 port 2000
 timeouts interdigit 2
 load 7965 SCCP45.9-3-1SR1-1S
 time-zone 41
 time-format 24
 date-format dd-mm-yy
 dialplan-pattern 1 20.. extension-length 4
 voicemail 2200
 max-conferences 4 gain -6
 transfer-system full-consult
 create cnf-files version-stamp 7960 Oct 22 2015 16:11:35
ok so is the transcoder registered..
sh sccp
If it is..then we need to look at your call flow..inbound and outbound dial-peer
please do a test call and send the ff
debug voip ccapi inout
I also need your full sh run (just attach it )
this is the debug result
term mon
CME-CEDRUS#
Oct 22 10:24:03.523: //-1/DA1934B48114/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=08978398199
   ----- ccCallInfo IE subfields -----
   cisco-ani=sip:08978398199@172.16.34.100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=sip:622129634600@192.168.12.15:5060
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Oct 22 10:24:03.527: //-1/DA1934B48114/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x22542770, Call Info(
   Calling Number=sip:08978398199@172.16.34.100,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=sip:622129634600@192.168.12.15:5060(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=447
Oct 22 10:24:03.527: //-1/DA1934B48114/CCAPI/ccCheckClipClir:
   In: Calling Number=sip:08978398199@172.16.34.100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=sip:08978398199@172.16.34.100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Oct 22 10:24:03.527: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Oct 22 10:24:03.527: :cc_get_feature_vsa malloc success
Oct 22 10:24:03.527:  cc_get_feature_vsa count is 1
Oct 22 10:24:03.527: :FEATURE_VSA attributes are: feature_name:0,feature_time:567156048,feature_id:117
Oct 22 10:24:03.527: //447/DA1934B48114/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Oct 22 10:24:03.527: //447/DA1934B48114/CCAPI/cc_process_call_setup_ind:
   Event=0x410E2478
Oct 22 10:24:03.527: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 622129634600
Oct 22 10:24:03.527: //447/DA1934B48114/CCAPI/ccCallSetContext:
   Context=0x39F3FD90
   >>>>CCAPI handed cid 447 with tag 100 to app "_ManagedAppProcess_Default"
Oct 22 10:24:03.527: //447/DA1934B48114/CCAPI/ccCallProceeding:
Oct 22 10:24:03.527: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
   mempool not found from usrContainer(41A48EA0)
Oct 22 10:24:03.527: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
   Mempool(41AE3F50) created in usrContainer(41A48EA0)
Oct 22 10:24:03.527: //447/DA1934B48114/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=20009, Params=0x39F47FD0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Oct 22 10:24:03.527: //447/DA1934B48114/CCAPI/ccCheckClipClir:
   Destination Pattern=2000$, Called Number=2000, Digit Strip=TRUE
Oct 22 10:24:03.531: //447/DA1934B48114/CCAPI/ccCallSetupRequest:
   Calling Number=sip:08978398199@172.16.34.100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=2000(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=08978398199, Final Destination Flag=TRUE,
   Guid=DA1934B4-77DD-11E5-8114-C3E647508F1A, Outgoing Dial-peer=20009
Oct 22 10:24:03.531: //447/DA1934B48114/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=2000
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Oct 22 10:24:03.531: //447/DA1934B48114/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x23119190, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=sip:08978398199@172.16.34.100,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=2000(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20009, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Oct 22 10:24:03.531: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Oct 22 10:24:03.531: :cc_get_feature_vsa malloc success
Oct 22 10:24:03.531:  cc_get_feature_vsa count is 2
Oct 22 10:24:03.531: :FEATURE_VSA attributes are: feature_name:0,feature_time:567155600,feature_id:118
Oct 22 10:24:03.531: //448/DA1934B48114/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Oct 22 10:24:03.531: //448/DA1934B48114/CCAPI/ccCallSetContext:
   Context=0x39F47F80
Oct 22 10:24:03.531: //447/DA1934B48114/CCAPI/ccSaveDialpeerTag:
Oct 22 10:24:03.535: //448/DA1934B48114/CCAPI/cc_api_update_call_info:
   Interface=0x23119190, Call Id=0x1C0
Oct 22 10:24:03.535: //448/DA1934B48114/CCAPI/cc_api_call_proceeding:
   Interface=0x23119190, Progress Indication=NULL(0)
Oct 22 10:24:03.539: //448/DA1934B48114/CCAPI/cc_api_call_alert:
   Interface=0x23119190, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Oct 22 10:24:03.539: //447/DA1934B48114/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Oct 22 10:24:03.539: //448/DA1934B48114/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=448
Oct 22 10:24:03.539: //447/DA1934B48114/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=447
Oct 22 10:24:13.539: //448/DA1934B48114/CCAPI/cc_api_call_disconnected:
   Cause Value=19, Interface=0x23119190, Call Id=448
   Call Entry(Responsed=TRUE, Cause Value=19, Retry Count=0)
Oct 22 10:24:13.539: //447/DA1934B48114/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Oct 22 10:24:13.539: //448/DA1934B48114/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
Oct 22 10:24:13.539: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=2000
Oct 22 10:24:13.539: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=2000, Called Number=2000, Calling Number=08978398199, Calling DN=-1 Calling Id=447,
   Redirect Number=2200, Redirect Reason=2
   Updated numbers: type=6  Original Called Number=2000, Redirect Number=2200
Oct 22 10:24:13.539: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Oct 22 10:24:13.539: :cc_get_feature_vsa malloc success
Oct 22 10:24:13.539:  cc_get_feature_vsa count is 3
Oct 22 10:24:13.539: :FEATURE_VSA attributes are: feature_name:0,feature_time:567155376,feature_id:119
Oct 22 10:24:13.539: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Oct 22 10:24:13.539:  feature_vsa is 21CE1D48,featname is 0
Oct 22 10:24:13.539:  cc_get_feature_vsa count is 4
Oct 22 10:24:13.539: :FEATURE_VSA attributes are: feature_name:0,feature_time:567154704,feature_id:120
Oct 22 10:24:13.539: : Generating new feature vsa,inserting it
Oct 22 10:24:13.539:  feature call forward featname is 3
Oct 22 10:24:13.539:  feature_vsa is 21CE1B88,featname is 0
Oct 22 10:24:13.539:  cc_get_feature_vsa count is 5
Oct 22 10:24:13.539: :FEATURE_VSA attributes are: feature_name:0,feature_time:567155824,feature_id:121
Oct 22 10:24:13.539: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Oct 22 10:24:13.539: :cc_free_feature_vsa freeing 21CE1AA8
Oct 22 10:24:13.539:  vsacount in free is 4
Oct 22 10:24:13.539: //448/DA1934B48114/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=19)
   Cause Value=19, Call Entry(Responsed=TRUE, Cause Value=19)
Oct 22 10:24:13.543: //448/DA1934B48114/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x23119190, Tag=0x0, Call Id=448,
   Call Entry(Disconnect Cause=19, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Oct 22 10:24:13.543: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Oct 22 10:24:13.543: :cc_free_feature_vsa freeing 21CE1C68
Oct 22 10:24:13.543:  vsacount in free is 3
Oct 22 10:24:13.543:  vsacount in free is 2
Oct 22 10:24:13.543: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Oct 22 10:24:13.543: :cc_get_feature_vsa malloc success
Oct 22 10:24:13.543:  cc_get_feature_vsa count is 3
Oct 22 10:24:13.543: :FEATURE_VSA attributes are: feature_name:0,feature_time:567155600,feature_id:122
Oct 22 10:24:13.543: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Oct 22 10:24:13.543:  feature call forward featname is 3
Oct 22 10:24:13.543: :cc_free_feature_vsa freeing 21CE1B88
Oct 22 10:24:13.543: //447/DA1934B48114/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=FALSE)
Oct 22 10:24:13.547: //447/DA1934B48114/CCAPI/ccCallForwardTo:
   Call Forward Number=2200, Call Forward Cause Reason=2, Call Id=447
Oct 22 10:24:13.547: //447/DA1934B48114/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x22542770, Call Id=447
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Oct 22 10:24:13.547: //447/DA1934B48114/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Oct 22 10:24:13.547: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
   data = 41A5CE54
Oct 22 10:24:13.547: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(41AE3F50)=0 - mempool cleanup
Oct 22 10:24:13.555: //447/DA1934B48114/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x22542770, Tag=0x0, Call Id=447,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Oct 22 10:24:13.555: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Oct 22 10:24:13.555: :cc_free_feature_vsa freeing 21CE1808
Oct 22 10:24:13.555:  vsacount in free is 1
Oct 22 10:24:13.555:  vsacount in free is 0
and also the sh run i attached.
thank you,
rocky
voice service voip
no sup sip moved
thanks Ayodeji,
It works.. now the mailbox can reach from trunk.
Thanks alot
regards,
Rocky
