04-21-2016 02:25 AM - edited 03-18-2019 11:56 AM
Hi Team,
I will really appreciate if anyone can help me with the hardware requirement for the below gateways to install IOS 15.1(4)M7:
2851
3825
3845
2821
I am in particular looking for DRAM / RAM requirements.
Thanks in advance.
-Karan
04-21-2016 02:47 AM
Hi Karan,
you need to mention the feature set also. latest release available is 15.1.4M10(MD)
for 2851 router, u can refer the link
https://software.cisco.com/download/release.html?mdfid=279120819&softwareid=280805680&os=&release=15.1.4M10&relind=AVAILABLE&rellifecycle=&reltype=latest&i=!pp
regds,
aman
04-21-2016 03:39 AM
Adding to Aman, if you are running/using voice features on these routers such as CME then refer to below link as per the CME version to know more about DRAM / RAM etc:
http://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-express/products-device-support-tables-list.html
Deepak
04-21-2016 08:13 AM
