02-14-2011 10:47 PM - edited 03-16-2019 03:27 AM
Hi. We're trying to generate a CSR for a local CA. This was easy in previous version of CUCM. We're running version 8.01. Please point me in the correct direction.
Solved! Go to Solution.
02-15-2011 03:18 AM
Does the following URL help ?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/8_0_2/secugd/secuview.html#wp1147888
Pierre.
02-15-2011 12:58 PM
I assume you want to sign your webpage certificate (tomcat). To do this on 8.x go to the OS Administration page, then to Security > Certificate Management. Click on the generate CSR button and select the service you would like to generate the CSR for most likely tomcat for the web service. After that has been done you'll see a download CSR button, that CSR can then be signed by whatever CA you will be using.
02-15-2011 03:18 AM
Pierre.
02-15-2011 12:58 PM
02-15-2011 08:11 PM
OK, well, I've just upgraded from version 4.1 to version 8.02 - don't try that at home - so the new interfaces is quite new to me ... thanks for your help.
