Get ATA device information in XML format?
marcelh
Is there an equivalent to the /DeviceInformationX URL found on IP phones on ATA devices?
I would like to be able to get XML for device info and network config for an ATA so that I can parse it to automate device inventory in an asset database?
Any help is appreciated.
Geovani
As far as I know, the only way of getting a copy of the xml config file is by generating a PRT. Is this what you're looking for?
Geovani
marcelh
Hi Geovani,
I’m looking for a way to query ATA devices via a URL that will return XML that I can parse to help automate device inventory and add the information to our CMDB (using ServiceNow).
I’m doing something similar with Cisco IP phones and getting device information from the URL http:///DeviceInformationX.
