Get callid from snmp mib
rick_ikari_2
Hi all,
i try to use a php script to monitoring active call, all works good. The next step is to disconnect a call, when it trigger an event, for this pourpouse, i need to get the call id from "show active call brief", do you know a oid for this?
PS
i see the: cvCallActiveConnectionId, but i retrived the value on hex format, and when i try to covert it to decimal i had that:
[.1.3.6.1.4.1.9.9.63.1.3.2.1.1.61005798.1] => "C4 74 F0 C9 AB C4 11 DC 80 FB 00 18 BA 5E 32 70 "
196 312 552 753 924 1120 1137 1357 1485 1736 1736 1760 1946 2040 2090 -> 2202
but on show call active voice brief i had:
2589(id) : 14470(callid)
any suggestion?
ty in advance
hadbou
Level 5
Level 5
If you device supports the mib I mention below then "show isdn stat" can be retrieved using cpmActiveCallType:
cpmActiveCallType 1.3.6.1.4.1.9.10.19.1.3.1.1.5
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=cpmActiveCallType&submitValue=SUBMIT
sorry, but i use 3660 as ip2ip gw, and i had on it only sip and h323 calls...
