10-04-2013 07:47 AM - edited 03-16-2019 07:42 PM
Hello. I have next scheme:
Cisco 9971(1000) ---- Cisco 3945 -------- Cisco 2910 --- Cisco 7742G(1001)
Between two Cisco routers I configured dial-peers and it seems to be working (debug voice dialpeer shows success on both routers). But when I call from 1000 to 1001 or vice versa, I get fast busy tone. Could any one provide any suggestions what could br wrong?
Config is simple:
dial-peer voice 1001 voip
destination-pattern 1001
session target ipv4:10.2.4.254
codec g711alaw
And
dial-peer voice 113 voip
destination-pattern 1000
session target ipv4:10.2.4.120
codec g711alaw
10-04-2013 07:54 AM
Output from debud voice dialpeer:
cisco2901#
122968: Oct 4 16:49:47.183 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
Calling Number=, Called Number=1, Peer Info Type=DIALPEER_INFO_SPEECH
122969: Oct 4 16:49:47.183 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=1
122970: Oct 4 16:49:47.183 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
Result=Partial Matches(1) after DP_MATCH_DEST
122971: Oct 4 16:49:47.183 UTC+2: //-1/0893AE5B997F/DPM/dpMatchSafModulePlugin:
dialstring=1, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
122972: Oct 4 16:49:47.183 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersMoreArg:
Result=MORE_DIGITS_NEEDED(1)
122973: Oct 4 16:49:47.859 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
Calling Number=, Called Number=10, Peer Info Type=DIALPEER_INFO_SPEECH
122974: Oct 4 16:49:47.859 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=10
122975: Oct 4 16:49:47.859 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122976: Oct 4 16:49:47.859 UTC+2: //-1/0893AE5B997F/DPM/dpMatchSafModulePlugin:
dialstring=10, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
122977: Oct 4 16:49:47.859 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersMoreArg:
122978: Oct 4 16:49:48.195 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
Calling Number=, Called Number=100, Peer Info Type=DIALPEER_INFO_SPEECH
122979: Oct 4 16:49:48.195 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=100
122980: Oct 4 16:49:48.199 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122981: Oct 4 16:49:48.199 UTC+2: //-1/0893AE5B997F/DPM/dpMatchSafModulePlugin:
dialstring=100, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
122982: Oct 4 16:49:48.199 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersMoreArg:
122983: Oct 4 16:49:48.523 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
Calling Number=, Called Number=1000, Peer Info Type=DIALPEER_INFO_SPEECH
122984: Oct 4 16:49:48.523 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=1000
122985: Oct 4 16:49:48.523 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
122986: Oct 4 16:49:48.523 UTC+2: //-1/0893AE5B997F/DPM/dpMatchSafModulePlugin:
dialstring=1000, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
122987: Oct 4 16:49:48.523 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=113
122988: Oct 4 16:49:48.523 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=1001, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
122989: Oct 4 16:49:48.523 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=100
122990: Oct 4 16:49:48.523 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
122991: Oct 4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122992: Oct 4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122993: Oct 4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122994: Oct 4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchSafModulePlugin:
dialstring=1000, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
122995: Oct 4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
2: Dial-peer Tag=100
122996: Oct 4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122997: Oct 4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122998: Oct 4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersCore:
122999: Oct 4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchSafModulePlugin:
123000: Oct 4 16:49:48.527 UTC+2: //-1/0893AE5B997F/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
123001: Oct 4 16:49:48.527 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=1000, Called Number=1000, Peer Info Type=DIALPEER_INFO_SPEECH
123002: Oct 4 16:49:48.527 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
123003: Oct 4 16:49:48.527 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
123004: Oct 4 16:49:48.527 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
123005: Oct 4 16:49:48.527 UTC+2: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
10-04-2013 08:00 AM
Hello
Please can you use under the dial-peer codec g729r8, not g711alaw?.
Thank you
please rate all useful information
10-04-2013 08:08 AM
I tried it already - no use(((
10-04-2013 09:38 AM
Hi Volodymyr,
Do you have in this scenario, SIP and H323 for calls.
Ckeck in voice service voip (sip to h323 calls, and redirect ip2ip and trust list) features enable.
Ex:
voice service voip
ip address trusted list
ipv4 10.1.32.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
Regards.
J Rosa.
10-05-2013 03:25 AM
Yeap, I have such config already, but nevertheless it does not work(((
I tried to set codec everywhere to the same value but the result is the same(
10-05-2013 07:14 AM
The configs already in your router, ok! In destination router the config is same or no?
If possible, describe the your scenario CME X CME and attached configs the router A and B.
Regards.
J Rosa.
10-06-2013 04:25 AM
hi
Did you check whether u can ping between routers.
10-06-2013 05:28 AM
Can you share the show run from both routers?
Piyush
