GetNewLineCalls on CUCM
h.abdelraouf
I have an issue using GetNewLineCalls TAPI API. On Cisco TSP 12.5
https://docs.microsoft.com/en-us/windows/win32/api/tapi/nf-tapi-linegetnewcalls
It always returns zero in the dwCallsNumEntries.
Although GetAddressStatus return the correct number of active calls on the same address that GetNewLineCalls uses
https://docs.microsoft.com/en-us/windows/win32/api/tapi/nf-tapi-linegetaddressstatus
I am trying to GetNewLineCalls just after I get the line handle from OpenLine.
Jaime Valencia
APIs are covered in DevNet, might want to post over there.
java
if this helps, please rate
Will do
