Getting Error on CME Disconnect cause 38 & 503
nayeem111
Am trying to call from CME to CUCM getting the below error. Calling from CUCM to CME is successful.
Below are the logs while calling from CME to CUCM(Version-7) which is not successful.
Please advise.
015022: Sep 30 15:18:56.787: //218719/4EA4AE8283FB/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x7FBEC2648010
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 4814
Called Number : 73230
Source IP Address (Sig ): 192.168.200.200
Destn SIP Req Addr:Port : 172.30.200.10:5060
Destn SIP Resp Addr:Port : 172.30.200.10:5060
Destination Name : 172.30.200.10
015023: Sep 30 15:18:56.787: //218719/4EA4AE8283FB/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.200.200
Source IP Port (Media): 28950
Destn IP Address (Media): -
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
015024: Sep 30 15:18:56.787: //218719/4EA4AE8283FB/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 38
Disconnect Cause (SIP) : 503
Error 38 means that your CME can't reach CUCM. Start with debug ip tcp
transactions to see what is happening when you initiate a connection
assuming that you use TCP SIP.
Check if there is anything blocking the connectivity and make sure the CME
is added to CUCM as SIP Trunk.
**** remember to rate useful posts
