In CVOICE Foundation Learning Guide by Kevin Wallace, page 443, table 5-5 talks about the order of operation of voice translation profiles, both for inbound and outbound directions.
It is mentioned that voice translation profiles applied globally are processed before those which are applied at the dial peer level. I already know how to configure global voice translation profile for inbound voip call legs (with voip-incoming translation-profile ...). My question is what is the command to configure outbound global voice translation profile?
I think he is talking about num-exp command which is applied globally and applied very first for digit manipulation.
Suresh
Suresh, I'm talking about voice translation profiles and not num exp. Please take a look at the file I attached.
I am not sure what do you mean by global translation profile, could you please clarify this. As per the book, we can create a translation profile and apply on the following:
Voice translation profile can be attached to these:
• VoIP dial peers
• Voice ports
• Any inbound VoIP call
• A specific range of source IP addresses in VoIP calls
• A trunk group
• A T1/E1 controller that is used for Nonfacility Associated Signaling (NFAS) trunks
• Survivable Remote Site Telephony (SRST)
~Amit
Please rate if helpful
