10-22-2019 03:53 PM
First timer here.
I am running CUCM 11.5 and was wondering if I can globally apply SSH credentials that I put into the "Common Phone Profile".
Or do I have to go into each device profile and put those credentials in?
Further, I have already applied it to the "Common Phone Profile" and SSH doesn't work. I am just hoping I am missing a step and that I don't have to apply those credentials to each device.
Solved! Go to Solution.
10-22-2019 05:22 PM
Bitcoin,
You can do it through Bulk Administration >>> Update Phones. Select the phones you want and make sure you enable SSH access as well as add the user name and password, otherwise you need to do it as you configure the new phones.
10-22-2019 05:22 PM
Bitcoin,
10-23-2019 01:15 PM
Well that was simple. I very much appreciate the input!
