Graceful failover of devices from SUB1 to SUB2
maxklutke
I need to reboot my SUB1.  All the devices are registered to SUB1.  Both SUBs are grouped and in all device pools (both subs are available to all devices).
Is there a way to make the phones gracefully failover to SUB2 so I can safely reboot SUB1?
Jaime Valencia
If your CUCM group is already adjusted for that to happen, there is nothing else you need to do, simply reboot the server.
java
if this helps, please rate
Jaime Valencia
java
Thank you for the confirmation, just what I needed.
