Participant
Group Pickup and T302 Timer?
How can I get rid of a connection delay when using the Group Pickup feature?
I configured several 3 digit Call Pickup Groups, and the rest of the dial plan is 6 digits. I notice it takes about 5 seconds to connect after pressing "Group Pickup" softkey then entering the 3 digit group number. I think I am hitting the T302 timer, which is also set at 5 seconds.
The pickup groups are numbered 100 - 109, and I don't have any other route pattern that matches those digits.
Thanks, Randy
Everyone's tags (2)
1 REPLY 1
Highlighted
Rising star
Re: Group Pickup and T302 Timer?
you may terminate the waiting for more digits after the third digit by using the pound (#) key.
if not working by default, you can program it.
Content for Community-Ad
July's Community Spotlight Awards
