09-25-2008 12:42 PM - edited 03-15-2019 01:33 PM
I have 2 phones, A and B, that are a part of the same Pickup group. Both phones' CSS contain the partition of the Group Pickup number. When I call Phone A and attempt to do a group Pickup on Phone B, I get a temp fail and hear a busy signal. I am not sure what I ma doing wrong on this???
Thanks!
09-25-2008 12:47 PM
Do you both phones registered to the same server or on different servers?
I recommend you to upload a CCM detailed trace while reproducing the problem to check what is the problem.
09-25-2008 12:50 PM
I think I found the issue...In 4.1, you didn't need to enter the GP pickup number, apparently in 6.1 you have to.
09-25-2008 12:58 PM
Hi Chris,
Nice work my friend! Have a look at this good thread, there are some nice details on the various Pickup options in CCM 6.x;
Take care,
Rob
09-29-2009 04:48 AM
Are you aware that a "group pickup" softkey intercept a call in another pickup group allowed on the pickup group configuration ? In this cas you have to dial the group DN to know which group you want to intercept.
The "pickup" softkey intercepts a call within the pickup group you belong to. So you do not need to dial the group DN.
I had a "temp fail" error in a case of a pickup group not reachable by the phone (DN in
hope this help.
09-29-2009 08:04 AM
Just to back up the post by Nicolas, in the pick up group configuration dont enter a partition as if you do it wont work.
Also, if you have phones within the same pick up group then you just need to press the softkey "pickup" and not "group pickup" to answer the call. You are then either presented with that call or the call rings at your phone depending whether you have auto pickup enabled or not.
09-30-2009 05:18 AM
It seems i was wrong.
the temp fail message is when the pickup is tried on a hunt call ringing on a phone in a pickup group you belong to.
On a direct call on the same phone, you can pick the call.
to enable pickup on a hunt pilot a avoid this issue, please refer to this topic : http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd498de
If someone can confirm this time I'm right ... :)
PS@Paul : I don't understand why a partition on a Pickip DN is a problem ... I've configured it many times without any issue. Can you explain ?
