09-25-2012 10:28 AM - edited 03-16-2019 01:23 PM
is there a way to create a dial-peer that forwards all calls to an external number? PRI on a 2801 router doing H.323 and running CME 7.1
Thanks. Replies rated.
09-25-2012 10:50 AM
Hello Scott, what you wanna do? ex:
Someone call at extension 5555 and the call is forward to a cell phone number?
regards
Leonardo Santana
09-25-2012 01:18 PM
there is a fax machine down and the need is to forward that fax number off-site to another fax machine.
09-25-2012 01:37 PM
You can use a translation rule to replace the number:
voice translation-rule 1
rule 1 /5555/ /PSTN NUMBER/
And create a translation profifle and apply to your correct dial-peer:
voice translation-profile profile1 translate called 1 dial-peer voice 10 pots translation-profile outgoing profile1
But you need to test if the fax transmition will suceed!
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Leonardo Santana
09-25-2012 03:16 PM
Simply built either num-exp or ephone-dn with call forward all set to the desired designation.
Chris
