H.323 gateway call issue
Rakesh K
Hi Everyone,
I am trying to setup lab with two h.323 VG each one in a different cluster. one is 3925 router and the other one 2900 route with E1 PRI connected on both the router.
CUCM1-->10.106.97.240
router 3925-->10.106.97.200
Phone 1:- 5555--->SEP5EE0C5527C81
CUCM2-->10.106.106.100
router 2900-->10.106.97.202
Phone 2:-7962-->5000-->SEP54EE7558FB89
Phone 1 calls another phone it rings and i click to answer the phone I can hear still ringing and the Phone 2 timer will be running.
I have attached the router configuration.
6 Replies 6
Gregory Brunn
I am confused by your call flow.
are you saying phone 5555 is calling 5000 via an intercluster trunk h323?
or via the e1?
or are you attempting to send it via an h323 link between the routers?
Also your missing binds on your one router for your h323 traffic interface also you do not have the correct addresses looking quickly in you ipv4 trusted authentication list.
please elaborate on the call flow and also make a test call and post output from debug voice ccapi inout
and
debug voice  dial-peer
Aadhil Salim
This issue 95% related to routing issue ie make sure your routing is working fine and make sure show ip route showing all routes and try to ping from one CUCM to another CUCM
Just curious to know how you worked out that it is a routing issue? because it sounds more like a signalling issue to me.
thanks
Please remember to rate useful posts, by clicking on the stars below.
if it is signaling issue can you please tell me how we will troubleshoot
There was a routing issue which i have fixed thank you all
mark the correct answer
