h245-alphanumeric on UCM 6.0.1(a) not work
paa
Hello all!
[ISP]---[3845-IP2IP-GW]---[CCM]
I have a strange problem with my UCM 6.0.1(a) When I call to outside from ip-phone, I can't work with IVR and dial extension number (for example I call 97273565 and dial ext 233 after connect).
I run debug on 3845:
debug h245 asn1
"value MultimediaSystemControlMessage ::= indication : userInput : signal :
signalType "2"
duration 100
It is example - other dialed digit were also recognized. So, I saw that my ip-phone sended dtmf to 3845 in dtmf-relay h245-signal.
So, why my ip-phone (7911) send DTMF in signal mode?
c3845 config (main part)
voice service voip
supplementary-service h450.12
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
h225 connect-passthru
h245 passthru tcsnonstd-passthru
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
!dial-peer voice 1 voip
description =TO CCM=
destination-pattern 247597[1-9]
voice-class codec 1
session target ipv4:10.110.100.1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 5 voip
descr =TO ISP=
destination-pattern 9T
voice-class codec 1
session target ipv4:172.16.119.2
no vad
On CCM 3845 register as h323 GW with unchecked "Wait for Far End H.245 Terminal Capability Set", set "MTP requared", checked "Enable Inbound FastStart". Other sets by default, "Media Resource Group List" - using CCM's MOH_2 and MTP_2 without multicast.
If I call from FXS-port on 3845 to outside - dtmf send as alphanumeric.
Please help!
5 Replies 5
jbarcena
Level 9
Level 9
So, if you change the dtmf on the dial-peer that is handling the call to h245-signal, are you able to handle the IVR options?
No, because my ISP can operate only with h245-alpha. My ISP says that get all dialing numbers in signal mode and also recognize its but can't use on there device. So, Is it impossible to use h245-alpha from ccm?
CallManager support incoming H245 alphanumeric
but sends h245-signal.
O, it is bad... But - My cisco-3845 terminate all calls from and to CCM. So, in outgoing dial-peer to ISP I set:
Can my 3845 translate incoming h245-signal from CCM to h245-alpha to ISP?
Great thanks to Cisco TAC - IP-2-IP cannot translate incoming h245-signal to h245-alpha.
