H323 Dial-Peer Failover system
Hi guys,
I have an incoming VGW which has two dial peer pointing towards CUCMs.
CUCM are 192.168.1.1 and 1.2
When 1.1 went down the call did not try to reach 1.2 which was active. what configuration will help me achieve this?
dial-peer voice 1000 voip
huntstop
description Site 1
preference 1
answer-address 1000
destination-pattern 1000
progress_ind setup enable 3
voice-class codec 1
session target ipv4:192.168.1.1
dtmf-relay h245-signal h245-alphanumeric
playout-delay nominal 250
playout-delay mode fixed
fax-relay ecm disable
fax rate 9600
fax nsf 000000
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
ip qos dscp cs3 signaling
no vad
dial-peer voice 1001 voip
huntstop
description Site 1
preference 2
answer-address 1000
voice-class codec 1
session target ipv4:192.168.1.2
fax rate 9600
fax nsf 000000
no vad
Rajan
Can you enable hunting on both the dial-peers by configuring "no huntstop" in both the dial-peers and try.
Rajan
Suresh Hudda
Remove the huntstop command from dial peers.
Suresh
