Beginner
h323 error "Bearer capability not available(0x3A)"
Has anyone seen the following error: **ERROR**: call_progress: DEV_CONNECTED VOICE ERROR: Bearer capability not available(0x3A): b channel 0 call id 0x27E5 ?
The above error happens when I enter the "debug isdn q931" and also I do not get any output from it.
Thanks in advance.
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Re: h323 error "Bearer capability not available(0x3A)"
Hi, the message is cosmetic, happens all the time, and doesn't affect functionality.
Arguably, Cisco sholud remove it soon.
4 REPLIES 4
Highlighted
Participant
What version of CUCM?
Is video enabled on your phone?
Are you faxing out of this gateway.
Jon
Highlighted
Beginner
After rebooting the router I started getting the debug isdn q931 output again but the error continues and this is how it happens:
ISDN Se0/3/0:23 Q931: TX -> ALERTING pd = 8 callref = 0xAE74
ISDN Se0/3/0:23 Q931: TX -> CONNECT pd = 8 callref = 0xAE74
ISDN Se0/3/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x2E74
ISDN Se0/3/0:23 **ERROR**: call_progress: DEV_CONNECTED VOICE ERROR: Bearer capability not available(0x3A): b channel 1 call id 0x1B
I don't have video or fax enable and it happens only on incoming calls.
Highlighted
Hall of Fame Master
Highlighted
Beginner
You are correct, this is a cosmetic issue (according to Cisco). The 12.4T images should remove it.
Thanks.
