05-06-2016 03:54 AM - edited 03-18-2019 11:58 AM
we have an issue with our H323 voice gateway connected to a Siemens PBX with an E1 cable, we can't send or receive call to or from the PBX, in attachment you can find, the isdn link status, gw configuration and the debug log for an outgoing call to the PBX directly from the router with csim start command, the analog phone number is 2234 and the prefix is 829.
thank you in advance.
05-06-2016 04:14 AM
Hi Youssef,
The config looks good and the right dial peer 22 is being hit for outbound leg. Can you try a no shut under the Voice service voip , serial interface 0/0/0:15 and the dial peers and test again.
Manish
05-06-2016 06:41 AM
05-06-2016 07:19 AM
It seems there is a issue at other end, so need to check with simens pbx. Do you have proper call routing configured at that end ?
Suresh
05-06-2016 09:10 AM
Yousseff,
the disconnect is coming from other end ie your PBX. you need to check why they are sending disconnect??
also are we having correct routing configure on the PBX side? check the called party number and look for the configuration on PBX if not correct please correct the same.
Cause i = 0x8083 - No route to destination
GW-YSF-PABX#
*May 6 13:38:20.448: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 8004816
*May 6 13:38:20.448: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x00A0 callID = 0x8021 switch = primary-net5 interface = User
*May 6 13:38:20.448: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00A0
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0081, '8004816'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '2234'
*May 6 13:38:20.580: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x80A0
*May 6 13:38:20.596: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x80A0
*May 6 13:38:20.596: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x00A0
*May 6 13:38:20.668: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80A0
Cause i = 0x8090 - Normal call clearing
GW-YSF-PABX#
05-06-2016 05:12 AM
you are getting cause value 63 however I personally don't feel good way to test call with csim. can you please test actual call scenario with debug h225 asn1, h2245 asn1 , voice capi inout and isdn q931
Cause No. 63 - service or option not available. unspecified.
This cause is used to report a service or option not available event only when no other cause in the service or option not available class applies.
further you can try what manish has suggested.
Br,
Nadeem Ahmed
