05-25-2013 09:14 AM - edited 03-16-2019 05:30 PM
hi everyone
when i transfer a call from PSNT to another PRI (the PRI is goto siemens) the gateway will TX a disconct message Recovery on timer expiry
the time always 19 secound'
the gateway is a h323 gateway with CUCM
the log is debug cch323 and the IOS is 12.4
who can help me ....
05-25-2013 03:40 PM
Are both PRI's on the same GW?
Can you provide a complete diagram for this call flow?
Please capture further debugs:
deb isdn q931
deb voice ccapi inout
deb h225 asn1
deb h245 asn1
Then specify the original called/calling number and also the second called number (transfer called number)
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
05-25-2013 06:54 PM
hi jorge armijo
thanks for you help
i will get this information at night . now there is morning...
in my top
a call call the number 85118522 the router will send the call to CVP listen the IVR use SIP . then the caller will dial 9 to transfer the call to the phone nummber 7762 (the 7762 is a siemens ,and the siemens is connection the cisco router with E1) ,the transfer path have two :
1 the CVP transfer the call to cucm use sip trunk then the CUCM transfer the call to router (this is connection with siemens) use H323 . when the call is answered about the call auto disconnect with Recovery on timer expiry
2 the CVP direct transfer the call to router (connection with siemens) use SIP . but also disconnect with Recovery on timer expiry
05-25-2013 06:58 PM
next is debug voice ccapi and debug isdn q931 the ani is 13311173269 transfer called number is 7762
at the beginning the call already go to CVP so 123456789012633 is the CVP label
*May 25 14:21:33.098: //-1/3BFCA2468853/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=13311173269
----- ccCallInfo IE subfields -----
cisco-ani=sip:13311173269@172.18.5.15:5060
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=1
dest=sip:123456789012633@172.18.5.10;transport=udp
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*May 25 14:21:33.098: //-1/3BFCA2468853/CCAPI/cc_api_call_setup_ind_common:
Interface=0x49BF15C4, Call Info(
Calling Number=sip:13311173269@172.18.5.15:5060,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Called Number=sip:123456789012633@172.18.5.10;transport=udp(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=123, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=11002066
*May 25 14:21:33.098: //-1/3BFCA2468853/CCAPI/ccCheckClipClir:
In: Calling Number=sip:13311173269@172.18.5.15:5060(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=sip:13311173269@172.18.5.15:5060(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
*May 25 14:21:33.098: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 25 14:21:33.098: :cc_get_feature_vsa malloc success
*May 25 14:21:33.098: cc_get_feature_vsa count is 1
*May 25 14:21:33.098: :FEATURE_VSA attributes are: feature_name:0,feature_time:1727425136,feature_id:8592831
*May 25 14:21:33.098: //11002066/3BFCA2468853/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
*May 25 14:21:33.102: //11002066/3BFCA2468853/CCAPI/cc_process_call_setup_ind:
Event=0x4A0CA118
*May 25 14:21:33.102: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 123456789012633
*May 25 14:21:33.102: //11002066/3BFCA2468853/CCAPI/ccCallSetContext:
Context=0x4C57DCD8
>>>>CCAPI handed cid 11002066 with tag 123 to app "_ManagedAppProcess_bootstrap"
*May 25 14:21:33.106: //11002066/3BFCA2468853/CCAPI/ccCallProceeding:
*May 25 14:21:33.106: //11002066/3BFCA2468853/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x0
Call Entry(Connected=TRUE, Responsed=TRUE)
*May 25 14:21:34.110: //11002066/3BFCA2468853/CCAPI/ccCallHandoff:
Silent=FALSE, Application=0x4ACF1900, Conference Id=0xFFFFFFFF
*May 25 14:21:34.150: //11002066/3BFCA2468853/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=0(ms), Inter Digit Timeout=0(ms)
Call Entry(Inter Digit Timeout=0(ms), Initial Digit Timeout=0(ms))
*May 25 14:21:34.150: //11002066/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0xA7E0D2, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 25 14:21:34.150: //11002066/3BFCA2468853/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=11002066
*May 25 14:21:34.150: //11002066/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49BF15C4, callID=0xA7E0D2, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 25 14:21:34.150: //11002066/3BFCA2468853/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x49BF15C4, Call Id=11002066
Call Entry(Initial Digit Timeout=0(ms), Inter Digit Timeout=0(ms))
*May 25 14:21:34.278: //11002066/3BFCA2468853/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=5000(ms), Inter Digit Timeout=10000(ms)
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=5000(ms))
*May 25 14:21:34.278: //11002066/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
*May 25 14:21:34.278: //11002066/3BFCA2468853/CCAPI/ccCallReportDigits:
*May 25 14:21:34.278: //11002066/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
*May 25 14:21:34.278: //11002066/3BFCA2468853/CCAPI/cc_api_call_report_digits_done:
Call Entry(Initial Digit Timeout=5000(ms), Inter Digit Timeout=10000(ms))
*May 25 14:21:34.398: //11002066/3BFCA2468853/CCAPI/ccAssociateStream:
Coder=5, DTMF Relay=1, Vad=0,
Record Function=0x0, Event Queue=0x49FF0984, Stream Context=65E179DC,
Record Context=0x0, Stream Call Id=11002067, Call Id=11002066
Call Entry(Stream Status=2, Digit Enable=TRUE)
*May 25 14:21:34.398: //11002066/3BFCA2468853/CCAPI/cc_api_call_associated:
Interface=0x0, CallId=11002066, Disposition=0
Play Function=0x43787DA4, Codec=0x5, Vad=0x0
Media Type=0x3, SPI Context=0x4849AF00, Stream CallId=11002067
TX Dynamic Pt=0x0, RX Dynamic Pt=0x0
*May 25 14:21:39.662: //11002066/3BFCA2468853/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=0,
Source Call Id=11002066, Digit=9, DigitBeginFlags=0x0,
Rtp Timestamp=0x0, Rtp Expiration=0x0
*May 25 14:21:39.798: //11002066/3BFCA2468853/CCAPI/cc_api_call_digit_end:
Source Call Id=11002066, Digit=9, Duration=100,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Call Entry(Handoff Depth=0)
*May 25 14:21:39.798: //11002066/3BFCA2468853/CCAPI/ccDisassociateStream:
Call Entry(Stream Status=1, Digit Enable=TRUE)
*May 25 14:21:39.798: //11002066/3BFCA2468853/CCAPI/ccSetDigitTimeouts:
*May 25 14:21:39.802: //11002066/3BFCA2468853/CCAPI/ccSetDigitTimeouts:
*May 25 14:21:39.822: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
mempool not found from usrContainer(66C40E6C)
*May 25 14:21:39.822: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Mempool(61BF0C68) created in usrContainer(66C40E6C)
*May 25 14:21:39.826: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
vapp_apply_callinfo_precedence:
cisco-ani=
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=1
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=74
cisco-rdn=123456789012633
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=10 fwd_final_type =0
*May 25 14:21:39.826: //11002066/3BFCA2468853/CCAPI/ccSetDigitTimeouts:
*May 25 14:21:39.830: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
data = 66F3EAC4
*May 25 14:21:39.830: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(61BF0C68)=0 - mempool cleanup
*May 25 14:21:39.870: //11002066/3BFCA2468853/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x49BF15C4, Call Id=11002066
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
*May 25 14:21:39.870: //11002066/3BFCA2468853/CCAPI/ccSetDigitTimeouts:
*May 25 14:21:39.870: //11002066/3BFCA2468853/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*May 25 14:21:39.870: //11002066/3BFCA2468853/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49BF15C4, Tag=0x0, Call Id=11002066,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
*May 25 14:21:39.874: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 25 14:21:39.874: :cc_free_feature_vsa freeing 66F66A68
*May 25 14:21:39.874: vsacount in free is 0
*May 25 14:21:40.370: //-1/00B5E9DF5504/CCAPI/cc_api_display_ie_subfields:
cisco-ani=13311173269
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=7762
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 25 14:21:40.374: //-1/00B5E9DF5504/CCAPI/cc_api_call_setup_ind_common:
Interface=0x49C3AD3C, Call Info(
Calling Number=13311173269,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=7762(TON=Unknown, NPI=Unknown),
Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=11002069
*May 25 14:21:40.374: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 25 14:21:40.374: :cc_get_feature_vsa malloc success
*May 25 14:21:40.374: cc_get_feature_vsa count is 1
*May 25 14:21:40.374: :FEATURE_VSA attributes are: feature_name:0,feature_time:1726259560,feature_id:8592832
*May 25 14:21:40.374: //11002069/00B5E9DF5504/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=13311173269(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=7762(TON=Unknown, NPI=Unknown))
*May 25 14:21:40.374: //11002069/00B5E9DF5504/CCAPI/cc_process_call_setup_ind:
Event=0x4A0CA118
*May 25 14:21:40.374: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 7762
*May 25 14:21:40.374: //11002069/00B5E9DF5504/CCAPI/ccCallSetContext:
Context=0x482B33A4
>>>>CCAPI handed cid 11002069 with tag 0 to app "_ManagedAppProcess_Default"
*May 25 14:21:40.374: //11002069/00B5E9DF5504/CCAPI/ccCallProceeding:
*May 25 14:21:40.378: //11002069/00B5E9DF5504/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=8000, Params=0x48058BDC, Progress Indication=NULL(0)
*May 25 14:21:40.378: //11002069/00B5E9DF5504/CCAPI/ccCheckClipClir:
In: Calling Number=13311173269(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=13311173269(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Destination Pattern=[6-8]..., Called Number=7762, Digit Strip=FALSE
Redirect Number=, Display Info=
Account Number=13311173269, Final Destination Flag=TRUE,
Guid=00B5E9DF-BBC9-011A-5504-7C02AC12050F, Outgoing Dial-peer=8000
*May 25 14:21:40.378: //11002069/00B5E9DF5504/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=7762
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 25 14:21:40.378: //11002069/00B5E9DF5504/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x4AC9A27C, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=13311173269,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=7762(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=8000, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*May 25 14:21:40.378: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 25 14:21:40.378: :cc_get_feature_vsa malloc success
*May 25 14:21:40.378: cc_get_feature_vsa count is 2
*May 25 14:21:40.378: :FEATURE_VSA attributes are: feature_name:0,feature_time:1726259336,feature_id:8592833
*May 25 14:21:40.382: //11002070/00B5E9DF5504/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*May 25 14:21:40.382: //11002070/00B5E9DF5504/CCAPI/ccCallSetContext:
Context=0x48058B8C
*May 25 14:21:40.382: //11002069/00B5E9DF5504/CCAPI/ccSaveDialpeerTag:
*May 25 14:21:40.382: ISDN Se0/3/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 13311173269
*May 25 14:21:40.386: ISDN Se0/3/1:15 Q931: Sending SETUP callref = 0x387F callID = 0xB0BF switch = primary-net5 interface = User
*May 25 14:21:40.386: ISDN Se0/3/1:15 Q931: TX -> SETUP pd = 8 callref = 0x387F
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0081, '13311173269'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '7762'
*May 25 14:21:40.450: ISDN Se0/3/1:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xB87F
*May 25 14:21:40.454: //11002070/00B5E9DF5504/CCAPI/cc_api_call_proceeding:
Interface=0x4AC9A27C, Progress Indication=NULL(0)
*May 25 14:21:40.470: ISDN Se0/3/1:15 Q931: RX <- ALERTING pd = 8 callref = 0xB87F
*May 25 14:21:40.470: //11002070/00B5E9DF5504/CCAPI/cc_api_call_alert:
Interface=0x4AC9A27C, Progress Indication=NULL(0), Signal Indication=NOT PRESENT(255)
Call Entry(Retry Count=0, Responsed=TRUE)
*May 25 14:21:40.470: //11002069/00B5E9DF5504/CCAPI/ccCallAlert:
Progress Indication=INBAND(8), Signal Indication=NOT PRESENT(255)
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
*May 25 14:21:40.470: //11002070/00B5E9DF5504/CCAPI/cc_api_get_called_ccm_detected:
CallInfo(ccm detected=0)
*May 25 14:21:40.470: //11002069/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4C7136D8, callID1=0xA7E0D5, callID2=0xA7E0D6, tag=0x0)
(confID=0x4C7136D8, callID1=0xA7E0D5, gcid=0-0-0-0, tag=0x0)
*May 25 14:21:40.474: //11002070/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4C7136D8, callID2=0xA7E0D6, gcid=0-0-0-0, tag=0x0)
*May 25 14:21:40.474: //11002069/00B5E9DF5504/CCAPI/ccConferenceCreate:
Conference Id=0x4C7136D8, Call Id1=11002069, Call Id2=11002070, Tag=0x0
*May 25 14:21:40.474: //11002069/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*May 25 14:21:40.474: cc_api_get_xcode_stream : 4534
*May 25 14:21:40.474: //11002069/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x201400, Source Interface=0x49C3AD3C, Source Call Id=11002069,
Destination Call Id=11002070, Disposition=0x0, Tag=0x0
*May 25 14:21:40.474: //11002070/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x201400, Source Interface=0x4AC9A27C, Source Call Id=11002070,
Destination Call Id=11002069, Disposition=0x0, Tag=0xFFFFFFFF
*May 25 14:21:40.474: //11002069/00B5E9DF5504/CCAPI/cc_generic_bridge_done:
Call Entry(Conference Id=0x201400, Destination Call Id=11002070)
*May 25 14:21:40.474: //11002070/00B5E9DF5504/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x201400, Destination Call Id=11002069)
*May 25 14:21:40.474: //11002070/00B5E9DF5504/CCAPI/cc_api_caps_ind:
Destination Interface=0x49C3AD3C, Destination Call Id=11002069, Source Call Id=11002070,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
*May 25 14:21:40.474: //11002069/00B5E9DF5504/CCAPI/cc_api_get_delay_xport:
CallInfo(delay xport=FALSE)
*May 25 14:21:40.478: //11002069/00B5E9DF5504/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x201400, Call Id1=11002069, Call Id2=11002070
*May 25 14:21:40.478: //11002069/00B5E9DF5504/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=11002069
*May 25 14:21:40.478: //11002070/00B5E9DF5504/CCAPI/cc_api_get_called_ccm_detected:
*May 25 14:21:40.522: //11002069/00B5E9DF5504/CCAPI/cc_api_caps_ind:
Destination Interface=0x4AC9A27C, Destination Call Id=11002070, Source Call Id=11002069,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
*May 25 14:21:40.522: //11002069/00B5E9DF5504/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=8334)
*May 25 14:21:40.526: //11002070/00B5E9DF5504/CCAPI/cc_api_caps_ack:
*May 25 14:21:40.526: //11002070/00B5E9DF5504/CCAPI/cc_api_voice_mode_event:
Call Id=11002070
Call Entry(Context=0x48058B8C)
Call Id=11002070
*May 25 14:21:42.958: //11002071/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
Call Entry Is Not Found
*May 25 14:21:42.958: //-1/CBB2457CA18A/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=sip:172.32.2.1
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=sip:7788000@172.18.5.10:5060
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 25 14:21:42.958: //-1/CBB2457CA18A/CCAPI/cc_api_call_setup_ind_common:
Calling Number=sip:172.32.2.1,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=sip:7788000@172.18.5.10:5060(TON=Unknown, NPI=Unknown),
Incoming Dial-peer=7788000, Progress Indication=NULL(0), Calling IE Present=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=11002071
*May 25 14:21:42.962: //-1/CBB2457CA18A/CCAPI/ccCheckClipClir:
In: Calling Number=sip:172.32.2.1(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=sip:172.32.2.1(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*May 25 14:21:42.962: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 25 14:21:42.962: :cc_get_feature_vsa malloc success
*May 25 14:21:42.962: cc_get_feature_vsa count is 3
*May 25 14:21:42.962: :FEATURE_VSA attributes are: feature_name:0,feature_time:1726259112,feature_id:8592834
*May 25 14:21:42.962: //11002071/CBB2457CA18A/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
*May 25 14:21:42.962: //11002071/CBB2457CA18A/CCAPI/cc_process_call_setup_ind:
Event=0x4A0C6EF0
*May 25 14:21:42.962: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 7788000
*May 25 14:21:42.962: //11002071/CBB2457CA18A/CCAPI/ccCallSetContext:
Context=0x4C0E0DDC
>>>>CCAPI handed cid 11002071 with tag 7788000 to app "_ManagedAppProcess_outbound"
*May 25 14:21:42.962: //11002071/CBB2457CA18A/CCAPI/ccCallSetupAck:
Call Id=11002071
*May 25 14:21:42.962: //11002071/CBB2457CA18A/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
*May 25 14:21:42.966: //11002071/CBB2457CA18A/CCAPI/ccCallProceeding:
*May 25 14:21:42.966: //11002071/CBB2457CA18A/CCAPI/ccCallAlert:
Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
*May 25 14:21:42.966: //11002071/CBB2457CA18A/CCAPI/ccCallConnect:
*May 25 14:21:42.970: //11002071/CBB2457CA18A/CCAPI/ccCallHandoff:
Silent=FALSE, Application=0x5DD453FC, Conference Id=0xFFFFFFFF
*May 25 14:21:43.014: //11002071/CBB2457CA18A/CCAPI/ccSetDigitTimeouts:
*May 25 14:21:43.014: //11002071/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0xA7E0D7, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 25 14:21:43.014: //11002071/CBB2457CA18A/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=11002071
*May 25 14:21:43.014: //11002071/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49BF15C4, callID=0xA7E0D7, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 25 14:21:43.014: //11002071/CBB2457CA18A/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x49BF15C4, Call Id=11002071
*May 25 14:21:43.066: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
mempool not found from usrContainer(66E80CC8)
*May 25 14:21:43.066: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Mempool(62C031FC) created in usrContainer(66E80CC8)
*May 25 14:21:43.066: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=74
cisco-rdn=7788000
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 25 14:21:43.070: //11002071/CBB2457CA18A/CCAPI/ccSetDigitTimeouts:
*May 25 14:21:43.074: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
data = 66F2D204
*May 25 14:21:43.074: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(62C031FC)=0 - mempool cleanup
*May 25 14:21:43.098: //11002071/CBB2457CA18A/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*May 25 14:21:43.150: //11002071/CBB2457CA18A/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49BF15C4, Tag=0x0, Call Id=11002071,
*May 25 14:21:43.150: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 25 14:21:43.150: :cc_free_feature_vsa freeing 66E49FA0
*May 25 14:21:43.150: vsacount in free is 2
*May 25 14:21:43.418: //11002072/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
*May 25 14:21:43.422: //-1/4223F312885E/CCAPI/cc_api_display_ie_subfields:
cisco-username=28296700
cisco-ani=sip:28296700@172.18.5.15:5060
cisco-anitype=4
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=1
dest=sip:123456789012634@172.18.5.10;transport=udp
cisco-desttype=0
cisco-destplan=0
cisco-rdie=74
cisco-rdn=22013333
cisco-lastrdn=
cisco-rdntype=4
cisco-rdnplan=1
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=15 fwd_final_type =0
*May 25 14:21:43.422: //-1/4223F312885E/CCAPI/cc_api_call_setup_ind_common:
Calling Number=sip:28296700@172.18.5.15:5060,(Calling Name=)(TON=Subscriber, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Called Number=sip:123456789012634@172.18.5.10;transport=udp(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=11002072
*May 25 14:21:43.422: //-1/4223F312885E/CCAPI/ccCheckClipClir:
In: Calling Number=sip:28296700@172.18.5.15:5060(TON=Subscriber, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=sip:28296700@172.18.5.15:5060(TON=Subscriber, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
*May 25 14:21:43.422: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 25 14:21:43.422: :cc_get_feature_vsa malloc success
*May 25 14:21:43.422: cc_get_feature_vsa count is 3
*May 25 14:21:43.422: :FEATURE_VSA attributes are: feature_name:0,feature_time:1726259112,feature_id:8592835
*May 25 14:21:43.422: //11002072/4223F312885E/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Subscriber, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
*May 25 14:21:43.426: //11002072/4223F312885E/CCAPI/cc_process_call_setup_ind:
Event=0x4A0C6EF0
*May 25 14:21:43.426: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 123456789012634
*May 25 14:21:43.426: //11002072/4223F312885E/CCAPI/ccCallSetContext:
Context=0x52702F74
>>>>CCAPI handed cid 11002072 with tag 123 to app "_ManagedAppProcess_bootstrap"
*May 25 14:21:43.430: //11002072/4223F312885E/CCAPI/ccCallProceeding:
*May 25 14:21:43.430: //11002072/4223F312885E/CCAPI/ccCallConnect:
*May 25 14:21:44.430: //11002072/4223F312885E/CCAPI/ccCallHandoff:
*May 25 14:21:44.470: //11002072/4223F312885E/CCAPI/ccSetDigitTimeouts:
*May 25 14:21:44.470: //11002072/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0xA7E0D8, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 25 14:21:44.470: //11002072/4223F312885E/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=11002072
*May 25 14:21:44.470: //11002072/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49BF15C4, callID=0xA7E0D8, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 25 14:21:44.470: //11002072/4223F312885E/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x49BF15C4, Call Id=11002072
*May 25 14:21:44.662: //11002072/4223F312885E/CCAPI/ccAssociateStream:
Record Function=0x0, Event Queue=0x49FF0984, Stream Context=614BEC18,
Record Context=0x0, Stream Call Id=11002073, Call Id=11002072
*May 25 14:21:44.662: //11002072/4223F312885E/CCAPI/cc_api_call_associated:
Interface=0x0, CallId=11002072, Disposition=0
Media Type=0x3, SPI Context=0x4B498E00, Stream CallId=11002073
*May 25 14:21:47.410: ISDN Se0/3/1:15 Q931: RX <- CONNECT pd = 8 callref = 0xB87F
Connected Number i = 0x1180, '7762'
*May 25 14:21:47.410: %ISDN-6-CONNECT: Interface Serial0/3/1:30 is now connected to 7762 N/A
*May 25 14:21:47.410: ISDN Se0/3/1:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x387F
*May 25 14:21:47.410: //11002070/00B5E9DF5504/CCAPI/cc_api_call_connected:
Interface=0x4AC9A27C, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*May 25 14:21:47.414: //11002069/00B5E9DF5504/CCAPI/ccCallConnect:
Progress Indication=INBAND(8), Data Bitmask=0x1
*May 25 14:21:47.414: //11002070/00B5E9DF5504/CCAPI/cc_api_get_called_ccm_detected:
*May 25 14:21:47.414: //11002069/00B5E9DF5504/CCAPI/ccCallNotify:
*May 25 14:21:58.166: //11002075/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
*May 25 14:21:58.166: //-1/D4C2D346A194/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 25 14:21:58.166: //-1/D4C2D346A194/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=11002075
*May 25 14:21:58.166: //-1/D4C2D346A194/CCAPI/ccCheckClipClir:
*May 25 14:21:58.166: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 25 14:21:58.170: :cc_get_feature_vsa malloc success
*May 25 14:21:58.170: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 25 14:21:58.170: cc_get_feature_vsa count is 4
*May 25 14:21:58.170: :FEATURE_VSA attributes are: feature_name:0,feature_time:1726258888,feature_id:8592836
*May 25 14:21:58.170: //11002075/D4C2D346A194/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*May 25 14:21:58.170: //11002075/D4C2D346A194/CCAPI/cc_process_call_setup_ind:
Event=0x4A0C6EF0
*May 25 14:21:58.170: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*May 25 14:21:58.170: //11002075/D4C2D346A194/CCAPI/ccCallSetContext:
Context=0x4C167E60
>>>>CCAPI handed cid 11002075 with tag 7788000 to app "_ManagedAppProcess_outbound"
*May 25 14:21:58.170: //11002075/D4C2D346A194/CCAPI/ccCallSetupAck:
Call Id=11002075
*May 25 14:21:58.170: //11002075/D4C2D346A194/CCAPI/cc_api_set_transfer_info:
*May 25 14:21:58.170: //11002075/D4C2D346A194/CCAPI/ccCallProceeding:
*May 25 14:21:58.174: //11002075/D4C2D346A194/CCAPI/ccCallAlert:
*May 25 14:21:58.174: //11002075/D4C2D346A194/CCAPI/ccCallConnect:
*May 25 14:21:58.178: //11002075/D4C2D346A194/CCAPI/ccCallHandoff:
*May 25 14:21:58.222: //11002075/D4C2D346A194/CCAPI/ccSetDigitTimeouts:
*May 25 14:21:58.222: //11002075/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0xA7E0DB, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 25 14:21:58.222: //11002075/D4C2D346A194/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=11002075
*May 25 14:21:58.222: //11002075/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49BF15C4, callID=0xA7E0DB, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 25 14:21:58.222: //11002075/D4C2D346A194/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x49BF15C4, Call Id=11002075
*May 25 14:21:58.278: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
mempool not found from usrContainer(660AFED0)
*May 25 14:21:58.278: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Mempool(66BE5E40) created in usrContainer(660AFED0)
*May 25 14:21:58.278: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=74
cisco-rdn=7788000
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 25 14:21:58.278: //11002075/D4C2D346A194/CCAPI/ccSetDigitTimeouts:
*May 25 14:21:58.282: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
data = 66F3AA84
*May 25 14:21:58.282: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(66BE5E40)=0 - mempool cleanup
*May 25 14:21:58.306: //11002075/D4C2D346A194/CCAPI/ccCallDisconnect:
*May 25 14:21:58.358: //11002075/D4C2D346A194/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49BF15C4, Tag=0x0, Call Id=11002075,
*May 25 14:21:58.362: //11002075/D4C2D346A194/CCAPI/cc_api_call_disconnect_done:
*May 25 14:21:58.362: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 25 14:21:58.362: :cc_free_feature_vsa freeing 66E49EC0
*May 25 14:21:58.362: vsacount in free is 3
*May 25 14:22:06.462: //11002072/4223F312885E/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x49BF15C4, Call Id=11002072
*May 25 14:22:06.462: //11002072/4223F312885E/CCAPI/ccDisassociateStream:
*May 25 14:22:06.466: //11002072/4223F312885E/CCAPI/ccSetDigitTimeouts:
*May 25 14:22:06.474: //11002072/4223F312885E/CCAPI/ccCallDisconnect:
*May 25 14:22:06.474: //11002072/4223F312885E/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49BF15C4, Tag=0x0, Call Id=11002072,
*May 25 14:22:06.478: //11002072/4223F312885E/CCAPI/cc_api_call_disconnect_done:
*May 25 14:22:06.478: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 25 14:22:06.478: :cc_free_feature_vsa freeing 66E49FA0
*May 25 14:22:06.478: vsacount in free is 2
*May 25 14:22:07.118: //11002069/00B5E9DF5504/CCAPI/cc_api_call_disconnected:
Cause Value=102, Interface=0x49C3AD3C, Call Id=11002069
Call Entry(Responsed=TRUE, Cause Value=102, Retry Count=0)
*May 25 14:22:07.118: //11002069/00B5E9DF5504/CCAPI/ccConferenceDestroy:
Conference Id=0x201400, Tag=0x0
*May 25 14:22:07.118: //11002069/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*May 25 14:22:07.118: //11002070/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=11002069, Disposition=0x0, Tag=0x0
*May 25 14:22:07.118: //11002069/00B5E9DF5504/CCAPI/cc_generic_bridge_done:
*May 25 14:22:07.118: //11002069/00B5E9DF5504/CCAPI/ccCallDisconnect:
Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=102)
Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
*May 25 14:22:07.118: //11002069/00B5E9DF5504/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
*May 25 14:22:07.118: //11002070/00B5E9DF5504/CCAPI/ccCallDisconnect:
Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*May 25 14:22:07.118: //11002070/00B5E9DF5504/CCAPI/cc_api_get_transfer_info:
*May 25 14:22:07.126: //11002069/00B5E9DF5504/CCAPI/cc_api_get_transfer_info:
*May 25 14:22:07.130: //11002069/00B5E9DF5504/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49C3AD3C, Tag=0x0, Call Id=11002069,
Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0)
*May 25 14:22:07.130: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 25 14:22:07.130: :cc_free_feature_vsa freeing 66E4A160
*May 25 14:22:07.130: vsacount in free is 1
*May 25 14:22:07.138: %ISDN-6-DISCONNECT: Interface Serial0/3/1:30 disconnected from 7762 , call lasted 19 seconds
*May 25 14:22:07.142: ISDN Se0/3/1:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x387F
Cause i = 0x80E6 - Recovery on timer expiry
*May 25 14:22:07.222: ISDN Se0/3/1:15 Q931: RX <- RELEASE pd = 8 callref = 0xB87F
Cause i = 0x8090 - Normal call clearing
*May 25 14:22:07.222: ISDN Se0/3/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x387F
*May 25 14:22:07.226: //11002070/00B5E9DF5504/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x4AC9A27C, Tag=0x0, Call Id=11002070,
*May 25 14:22:07.226: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 25 14:22:07.226: :cc_free_feature_vsa freeing 66E4A080
*May 25 14:22:07.230: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 25 14:22:07.230: vsacount in free is 0
*May 25 14:22:13.374: //11002076/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
*May 25 14:22:13.374: //-1/DDD361A9A198/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 25 14:22:13.374: //-1/DDD361A9A198/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=11002076
*May 25 14:22:13.374: //-1/DDD361A9A198/CCAPI/ccCheckClipClir:
*May 25 14:22:13.378: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 25 14:22:13.378: :cc_get_feature_vsa malloc success
*May 25 14:22:13.378: cc_get_feature_vsa count is 1
*May 25 14:22:13.378: :FEATURE_VSA attributes are: feature_name:0,feature_time:1726208384,feature_id:8592837
*May 25 14:22:13.378: //11002076/DDD361A9A198/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*May 25 14:22:13.378: //11002076/DDD361A9A198/CCAPI/cc_process_call_setup_ind:
Event=0x4A0C6EF0
*May 25 14:22:13.378: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*May 25 14:22:13.378: //11002076/DDD361A9A198/CCAPI/ccCallSetContext:
Context=0x4FFE41E4
>>>>CCAPI handed cid 11002076 with tag 7788000 to app "_ManagedAppProcess_outbound"
*May 25 14:22:13.382: //11002076/DDD361A9A198/CCAPI/ccCallSetupAck:
Call Id=11002076
*May 25 14:22:13.382: //11002076/DDD361A9A198/CCAPI/cc_api_set_transfer_info:
*May 25 14:22:13.382: //11002076/DDD361A9A198/CCAPI/ccCallProceeding:
*May 25 14:22:13.382: //11002076/DDD361A9A198/CCAPI/ccCallAlert:
*May 25 14:22:13.382: //11002076/DDD361A9A198/CCAPI/ccCallConnect:
*May 25 14:22:13.386: //11002076/DDD361A9A198/CCAPI/ccCallHandoff:
*May 25 14:22:13.426: //11002076/DDD361A9A198/CCAPI/ccSetDigitTimeouts:
*May 25 14:22:13.426: //11002076/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0xA7E0DC, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 25 14:22:13.426: //11002076/DDD361A9A198/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=11002076
*May 25 14:22:13.430: //11002076/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49BF15C4, callID=0xA7E0DC, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 25 14:22:13.430: //11002076/DDD361A9A198/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x49BF15C4, Call Id=11002076
*May 25 14:22:13.482: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
mempool not found from usrContainer(66E78000)
*May 25 14:22:13.482: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Mempool(66AD41FC) created in usrContainer(66E78000)
*May 25 14:22:13.482: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=74
cisco-rdn=7788000
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 25 14:22:13.486: //11002076/DDD361A9A198/CCAPI/ccSetDigitTimeouts:
*May 25 14:22:13.486: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
data = 66F2FC44
*May 25 14:22:13.486: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(66AD41FC)=0 - mempool cleanup
*May 25 14:22:13.510: //11002076/DDD361A9A198/CCAPI/ccCallDisconnect:
*May 25 14:22:13.566: //11002076/DDD361A9A198/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49BF15C4, Tag=0x0, Call Id=11002076,
*May 25 14:22:13.566: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 25 14:22:13.566: :cc_free_feature_vsa freeing 66E3D978
*May 25 14:22:13.566: vsacount in free is 0
[END] 2013/5/25 22:24:50
05-25-2013 07:57 PM
Ok, I can see the first and second call, the second call goes to the PBX via E1, the call actually connects, however I can see on the incoming leg of the call the "102" disconnect code. Meaning that the router is just forwarding the disconnect from the incoming leg, I cannot see all the signaling, since I was not aware of the SIP leg, and actually I can't see any h323 signaling, so you better get a new set of captures:
deb voice ccapi inouy
deb isdn q931
deb ccsip messages
So, the call flow, is something like this?
PSTN>>>85118522>>>GW>>>SIP>>>CVPxfer7762>>>SIP>>>GW>>>E1>>>Siemens
Jorge Armijo
05-25-2013 10:35 PM
OK i will debug this infomation at night!
the call flow .i don't konw what is CVPXFER7762 you mean is CVP transfer 7762?
if so ,you are right this my top....
when i lookat debug voice ccapi...i just can know the ani dnis and incoming / outgoing dial-peer .......
05-26-2013 07:53 AM
hi jorge
next is the trace debug voice ccapi inout debug isnd q931 debug ccsip message
i find when the call conected. the cvp(172.18.5.15) will send about 4 times 200OK to router (172.18.5.10) then CVP disconect the call . i think the router should return 200 OK ack to CVP...huh? but i don't know how to resolve this problem.....
05-26-2013 08:09 AM
[BEGIN] 2013/5/26 22:20:30
gwa#
gwa#
gwa#
gwa#
gwa#
gwa#
gwa#
gwa#
gwa#
gwa#
gwa#
gwa#
gwa#
*May 26 14:18:07.364: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:123456789014495@172.18.5.10:5060 SIP/2.0
Via: SIP/2.0/UDP 172.18.5.15:5060;branch=z9hG4bKpE4eErPVrcli2oQF230Amg~~2310200
Max-Forwards: 70
To: <123456789014495>;tag=22214754-1DA5123456789014495>
Call-ID: F0F61B31C54411E2B730EC4476465320-136957804804445697@172.18.5.15
CSeq: 2 BYE
Content-Length: 0
Contact: <02283726793>02283726793>
Reason: Q.850;cause=16
*May 26 14:18:07.364: //11014254/DF58B8698BC7/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x49BF15C4, Call Id=11014254
*May 26 14:18:07.368: //11014254/DF58B8698BC7/CCAPI/ccDisassociateStream:
Record Context=0x0, Stream Call Id=11014255, Call Id=11014254
*May 26 14:18:07.372: //11014254/DF58B8698BC7/CCAPI/ccSetDigitTimeouts:
*May 26 14:18:07.376: //11014254/DF58B8698BC7/CCAPI/ccCallDisconnect:
*May 26 14:18:07.380: //11014254/DF58B8698BC7/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49BF15C4, Tag=0x0, Call Id=11014254,
*May 26 14:18:07.380: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 26 14:18:07.380: :cc_free_feature_vsa freeing 6674D278
*May 26 14:18:07.380: vsacount in free is 0
*May 26 14:18:07.380: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
From: 02283726793 <02283726793>;tag=ds57c96c9102283726793>
Date: Sun, 26 May 2013 14:18:07 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 2 BYE
Content-Length: 0
*May 26 14:18:08.492: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8 callref = 0x03ED
Sending Complete
Standard = CCITT
Channel ID i = 0xA18384
Preferred, Channel 4
Calling Party Number i = 0x2183, '13311173269'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '1085118522'
*May 26 14:18:08.496: ISDN Se0/3/0:15 Q931: Received SETUP callref = 0x83ED callID = 0x5C17 switch = primary-net5 interface = User
*May 26 14:18:08.500: //-1/EC73D259A535/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=1085118522
cisco-desttype=2
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 26 14:18:08.500: //-1/EC73D259A535/CCAPI/cc_api_call_setup_ind_common:
Interface=0x4AB00E28, Call Info(
Calling Number=13311173269,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=1085118522(TON=National, NPI=ISDN),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Incoming Dial-peer=9100, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*May 26 14:18:08.500: //-1/EC73D259A535/CCAPI/ccCheckClipClir:
In: Calling Number=13311173269(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Out: Calling Number=13311173269(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
*May 26 14:18:08.500: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 26 14:18:08.500: :cc_get_feature_vsa malloc success
*May 26 14:18:08.500: cc_get_feature_vsa count is 1
*May 26 14:18:08.500: :FEATURE_VSA attributes are: feature_name:0,feature_time:1717336888,feature_id:8601727
*May 26 14:18:08.500: //11014258/EC73D259A535/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=13311173269(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=1085118522(TON=National, NPI=ISDN))
*May 26 14:18:08.504: //11014258/EC73D259A535/CCAPI/cc_process_call_setup_ind:
Event=0x4A0CA118
*May 26 14:18:08.504: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 1085118522
*May 26 14:18:08.504: //11014258/EC73D259A535/CCAPI/ccCallSetContext:
Context=0x483888E4
>>>>CCAPI handed cid 11014258 with tag 9100 to app "_ManagedAppProcess_Default"
*May 26 14:18:08.504: //11014258/EC73D259A535/CCAPI/ccCallProceeding:
*May 26 14:18:08.508: //11014258/EC73D259A535/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=400, Params=0x483E0BFC, Progress Indication=NULL(0)
*May 26 14:18:08.508: //11014258/EC73D259A535/CCAPI/ccCheckClipClir:
Destination Pattern=24000, Called Number=24000, Digit Strip=FALSE
Called Number=24000(TON=National, NPI=ISDN),
Account Number=, Final Destination Flag=TRUE,
Guid=EC73D259-C545-11E2-A535-EC4476464CC0, Outgoing Dial-peer=400
*May 26 14:18:08.508: //11014258/EC73D259A535/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=24000
cisco-desttype=2
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 26 14:18:08.508: //11014258/EC73D259A535/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x49BF15C4, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=13311173269,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=24000(TON=National, NPI=ISDN), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=400, Call Count On=FALSE,
*May 26 14:18:08.508: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 26 14:18:08.508: :cc_get_feature_vsa malloc success
*May 26 14:18:08.508: cc_get_feature_vsa count is 2
*May 26 14:18:08.508: :FEATURE_VSA attributes are: feature_name:0,feature_time:1717336664,feature_id:8601728
*May 26 14:18:08.508: //11014259/EC73D259A535/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*May 26 14:18:08.508: //11014259/EC73D259A535/CCAPI/ccCallSetContext:
Context=0x483E0BAC
*May 26 14:18:08.508: //11014258/EC73D259A535/CCAPI/ccSaveDialpeerTag:
*May 26 14:18:08.512: //11014259/EC73D259A535/CCAPI/cc_api_call_proceeding:
Interface=0x49BF15C4, Progress Indication=NULL(0)
*May 26 14:18:08.512: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Sending: Binary Message Body
*May 26 14:18:08.512: Content-Type: application/x-q931
08 02 83 ED 05 A1 04 03 80 90 A3 18 03 A1 83 84 6C 0D 21 83 31 33 33 31 31 31 37 33 32 36 39 70 0B A1 31 30 38 35 31 31 38 35 32 32 0D 0A
*May 26 14:18:08.516: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:24000@172.18.5.15:5060 SIP/2.0
Via: SIP/2.0/UDP 172.18.5.10:5060;branch=z9hG4bK4D4F6D49C
Remote-Party-ID: <13311173269>;party=calling;screen=yes;privacy=off13311173269>
To: <24000>24000>
Date: Sun, 26 May 2013 14:18:08 GMT
Call-ID: EC764391-C54511E2-8BD586FD-A7F81A54@172.18.5.10
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE: 360
Cisco-Guid: 3967013465-3309638114-2771774532-1984318656
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1369577888
Contact: <13311173269>13311173269>
Expires: 180
Allow-Events: telephone-event
Content-Type: multipart/mixed;boundary=uniqueBoundary
Mime-Version: 1.0
Content-Length: 811
--uniqueBoundary
Content-Type: application/sdp
Content-Disposition: session;handling=required
v=0
o=CiscoSystemsSIP-GW-UserAgent 2077 1027 IN IP4 172.18.5.10
s=SIP Call
c=IN IP4 172.18.5.10
t=0 0
m=audio 16624 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
--uniqueBoundary
Content-Disposition: signal;handling=optional
Content-Length: 46
m! # ! l
! 13311173269p
!1085118522
--uniqueBoundary
Content-Type: application/gtd
IAM,
PRN,isdn*,,NET5*,
USI,rate,c,s,c,1
USI,lay1,alaw
TMR,00
CPN,04,,1,1085118522
CGN,04,,1,y,4,13311173269
CPC,09
FCI,,,,,,,y,
GCI,ec73d259c54511e2a535ec4476464cc0
--uniqueBoundary--
Xshell
*May 26 14:18:08.520: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <24000>24000>
CSeq: 101 INVITE
Content-Length: 0
Contact: <172.18.5.15:5060>172.18.5.15:5060>
*May 26 14:18:08.520: ISDN Se0/3/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x83ED
Channel ID i = 0xA98384
Exclusive, Channel 4
*May 26 14:18:08.852: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:123456789014496@172.18.5.10;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.18.5.15:5060;branch=z9hG4bKpE4eErPVrcli2oQF230Amg~~2310201
Max-Forwards: 69
To: <123456789014496>123456789014496>
From: 13311173269 <13311173269>;tag=ds4ca2c2a113311173269>
Call-ID: EC73D259C54511E2A535EC4476464CC0-136957807006045698@172.18.5.15
CSeq: 1 INVITE
Content-Length: 856
Expires: 60
User-Agent: Cisco-SIP-CVP/7.x
App-Info: <172.18.5.15:8000:8443>
Call-Info: <172.18.5.10:5060>;purpose=x-cisco-origIP172.18.5.10:5060>
Supported: timer
Supported: resource-priority
Supported: replaces
Supported: sdp-anat
Min-SE: 360
MIME-Version: 1.0
Cisco-Gucid: EC73D259C54511E2A535EC4476464CC0
--uniqueBoundary
Content-Length: 244
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
--uniqueBoundary
Content-Length: 46
m! # ! l
! 13311173269p
!1085118522
--uniqueBoundary
Content-Length: 178
IAM,
PRN,isdn*,,NET5*,
USI,rate,c,s,c,1
USI,lay1,alaw
TMR,00
CPC,09
FCI,,,,,,,y,
--uniqueBoundary--
*May 26 14:18:08.856: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Receiving: Binary Message Body
*May 26 14:18:08.856: Content-Type: application/x-q931
*May 26 14:18:08.860: //11014260/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
*May 26 14:18:08.864: //-1/ECAAC0258BD6/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=1
dest=sip:123456789014496@172.18.5.10;transport=udp
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 26 14:18:08.864: //-1/ECAAC0258BD6/CCAPI/cc_api_call_setup_ind_common:
Called Number=sip:123456789014496@172.18.5.10;transport=udp(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=11014260
*May 26 14:18:08.864: //-1/ECAAC0258BD6/CCAPI/ccCheckClipClir:
*May 26 14:18:08.864: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 26 14:18:08.864: :cc_get_feature_vsa malloc success
*May 26 14:18:08.864: cc_get_feature_vsa count is 3
*May 26 14:18:08.864: :FEATURE_VSA attributes are: feature_name:0,feature_time:1717336440,feature_id:8601729
*May 26 14:18:08.864: //11014260/ECAAC0258BD6/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*May 26 14:18:08.868: //11014260/ECAAC0258BD6/CCAPI/cc_process_call_setup_ind:
Event=0x4A0CA118
*May 26 14:18:08.868: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 123456789014496
*May 26 14:18:08.868: //11014260/ECAAC0258BD6/CCAPI/ccCallSetContext:
Context=0x4C0E59FC
>>>>CCAPI handed cid 11014260 with tag 123 to app "_ManagedAppProcess_bootstrap"
*May 26 14:18:08.892: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 1 INVITE
Content-Length: 0
*May 26 14:18:08.896: //11014260/ECAAC0258BD6/CCAPI/ccCallProceeding:
*May 26 14:18:08.896: //11014260/ECAAC0258BD6/CCAPI/ccCallConnect:
*May 26 14:18:08.900: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <123456789014496>;tag=22219EB8-1A0F123456789014496>
CSeq: 1 INVITE
Contact: <123456789014496>123456789014496>
Supported: replaces
Supported: sdp-anat
Content-Length: 243
v=0
o=CiscoSystemsSIP-GW-UserAgent 170 6074 IN IP4 172.18.5.10
s=SIP Call
t=0 0
m=audio 19230 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Received:
SIP/2.0 200 Ok
To: <24000>;tag=ds3a156e5424000>
CSeq: 101 INVITE
Content-Length: 243
Supported: replaces
Supported: sdp-anat
Session-Expires: 1800;refresher=uac
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
*May 26 14:18:08.904: //11014259/EC73D259A535/CCAPI/cc_api_call_connected:
Interface=0x49BF15C4, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
*May 26 14:18:08.904: //11014258/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4C713600, callID1=0xA81072, callID2=0xA81073, tag=0x0)
(confID=0x4C713600, callID1=0xA81072, gcid=EC73D259-C54511E2-A535EC44-76464CC0, tag=0x0)
*May 26 14:18:08.904: //11014259/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4C713600, callID2=0xA81073, gcid=EC73D259-C54511E2-A535EC44-76464CC0, tag=0x0)
*May 26 14:18:08.904: //11014258/EC73D259A535/CCAPI/ccConferenceCreate:
Conference Id=0x4C713600, Call Id1=11014258, Call Id2=11014259, Tag=0x0
*May 26 14:18:08.904: //11014258/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x20169C, Source Interface=0x4AB00E28, Source Call Id=11014258,
Destination Call Id=11014259, Disposition=0x0, Tag=0xFFFFFFFF
*May 26 14:18:08.904: //11014259/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*May 26 14:18:08.904: cc_api_get_xcode_stream : 4534
*May 26 14:18:08.908: //11014259/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x20169C, Source Interface=0x49BF15C4, Source Call Id=11014259,
Destination Call Id=11014258, Disposition=0x0, Tag=0x0
*May 26 14:18:08.908: //11014258/EC73D259A535/CCAPI/cc_generic_bridge_done:
Conference Id=0x20169C, Source Interface=0x49BF15C4, SourceXshell Call Id=11014259,
*May 26 14:18:08.908: //11014258/EC73D259A535/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x20169C, Destination Call Id=11014259)
*May 26 14:18:08.908: //11014259/EC73D259A535/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x20169C, Destination Call Id=11014258)
*May 26 14:18:08.908: //11014258/EC73D259A535/CCAPI/cc_api_caps_ind:
Destination Interface=0x49BF15C4, Destination Call Id=11014259, Source Call Id=11014258,
*May 26 14:18:08.908: //11014259/EC73D259A535/CCAPI/cc_api_caps_ind:
Destination Interface=0x4AB00E28, Destination Call Id=11014258, Source Call Id=11014259,
*May 26 14:18:08.908: //11014259/EC73D259A535/CCAPI/cc_api_caps_ack:
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=562)
*May 26 14:18:08.908: //11014258/EC73D259A535/CCAPI/cc_api_caps_ack:
*May 26 14:18:08.908: //11014258/EC73D259A535/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x20169C, Call Id1=11014258, Call Id2=11014259
*May 26 14:18:08.908: //11014258/EC73D259A535/CCAPI/cc_api_voice_mode_event:
Call Id=11014258
*May 26 14:18:08.912: //11014258/EC73D259A535/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x483888E4)
*May 26 14:18:08.912: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:172.18.5.15:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.18.5.10:5060;branch=z9hG4bK4D4F6EB38
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*May 26 14:18:08.912: //11014258/EC73D259A535/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
*May 26 14:18:08.916: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:123456789014496@172.18.5.10:5060 SIP/2.0
Via: SIP/2.0/UDP 172.18.5.15:5060;branch=z9hG4bKpE4eErPVrcli2oQF230Amg~~2310202
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
*May 26 14:18:08.916: ISDN Se0/3/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x83ED
*May 26 14:18:09.736: ISDN Se0/3/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x03ED
*May 26 14:18:09.744: %ISDN-6-CONNECT: Interface Serial0/3/0:3 is now connected to 13311173269 N/A
*May 26 14:18:10.456: //11014260/ECAAC0258BD6/CCAPI/ccCallHandoff:
*May 26 14:18:10.500: //11014260/ECAAC0258BD6/CCAPI/ccSetDigitTimeouts:
*May 26 14:18:10.500: //11014260/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0xA81074, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 26 14:18:10.500: //11014260/ECAAC0258BD6/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=11014260
*May 26 14:18:10.500: //11014260/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49BF15C4, callID=0xA81074, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 26 14:18:10.500: //11014260/ECAAC0258BD6/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x49BF15C4, Call Id=11014260
*May 26 14:18:11.368: //11014260/ECAAC0258BD6/CCAPI/ccSetDigitTimeouts:
*May 26 14:18:11.368: //11014260/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
*May 26 14:18:11.368: //11014260/ECAAC0258BD6/CCAPI/ccCallReportDigits:
*May 26 14:18:11.368: //11014260/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
*May 26 14:18:11.368: //11014260/ECAAC0258BD6/CCAPI/cc_api_call_report_digits_done:
*May 26 14:18:11.384: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:7788000@172.18.5.10:5060 SIP/2.0
Via: SIP/2.0/UDP 172.32.2.1:5060;branch=z9hG4bK3FB19A6
To: <7788000>7788000>
Date: Sun, 26 May 2013 14:50:39 GMT
Call-ID: 7785B6C1-C54A11E2-8A10BD62-1005485D@172.32.2.1
Min-SE: 360
Cisco-Guid: 2005211801-3309965794-2316156258-268781661
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1369579839
Contact: <172.32.2.1:5060>172.32.2.1:5060>
Expires: 60
Mime-Version: 1.0
Content-Length: 508
--uniqueBoundary
v=0
o=CiscoSystemsSIP-GW-UserAgent 9064 7467 IN IP4 172.32.2.1
s=SIP Call
c=IN IP4 172.32.2.1
t=0 0
m=audio 17444 RTP/AVP 0 101
c=IN IP4 172.32.2.1
a=fmtp:101 0-16
a=ptime:20
--uniqueBoundary
IAM,
GCI,77851a99c54a11e28a0dbd621005485d
--uniqueBoundary--
*May 26 14:18:11.388: //11014263/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
*May 26 14:18:11.392: //-1/77851A998A0D/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 26 14:18:11.392: //-1/77851A998A0D/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=11014263
*May 26 14:18:11.392: //-1/77851A998A0D/CCAPI/ccCheckClipClir:
*May 26 14:18:11.392: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 26 14:18:11.392: :cc_get_feature_vsa malloc success
*May 26 14:18:11.392: cc_get_feature_vsa count is 4
*May 26 14:18:11.392: :FEATURE_VSA attributes are: feature_name:0,feature_time:1717336216,feature_id:8601730
*May 26 14:18:11.392: //11014263/77851A998A0D/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*May 26 14:18:11.396: //11014263/77851A998A0D/CCAPI/cc_process_call_setup_ind:
Event=0x4A0C6EF0
*May 26 14:18:11.396: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*May 26 14:18:11.396: //11014263/77851A998A0D/CCAPI/ccCallSetContext:
Context=0x4BC14B94
>>>>CCAPI handed cid 11014263 with tag 7788000 to app "_ManagedAppProcess_outbound"
*May 26 14:18:11.396: //11014263/77851A998A0D/CCAPI/ccCallSetupAck:
Call Id=11014263
*May 26 14:18:11.396: //11014263/77851A998A0D/CCAPI/cc_api_set_transfer_info:
*May 26 14:18:11.396: //11014263/77851A998A0D/CCAPI/ccCallProceeding:
*May 26 14:18:11.396: //11014263/77851A998A0D/CCAPI/ccCallAlert:
*May 26 14:18:11.396: //11014263/77851A998A0D/CCAPI/ccCallConnect:
*May 26 14:18:11.400: //11014263/77851A998A0D/CCAPI/ccCallConnect:
*May 26 14:18:11.404: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sun, 26 May 2013 14:18:11 GMT
CSeq: 101 INVITE
Content-Length: 0
*May 26 14:18:11.408: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <7788000>;tag=2221A880-26A7788000>
CSeq: 101 INVITE
Contact: <7788000>7788000>
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 1258 5378 IN IP4 172.18.5.10
s=SIP Call
t=0 0
m=audio 19384 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
*May 26 14:18:11.408: //11014263/77851A998A0D/CCAPI/ccCallHandoff:
*May 26 14:18:11.452: //11014263/77851A998A0D/CCAPI/ccSetDigitTimeouts:
*May 26 14:18:11.452: //11014263/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0xA81077, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 26 14:18:11.452: //11014263/77851A998A0D/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=11014263
*May 26 14:18:11.452: //11014263/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49BF15C4, callID=0xA81077, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 26 14:18:11.452: //11014263/77851A998A0D/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x49BF15C4, Call Id=11014263
*May 26 14:18:11.460: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:7788000@172.18.5.10:5060 SIP/2.0
Via: SIP/2.0/UDP 172.32.2.1:5060;branch=z9hG4bK3FB272A
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*May 26 14:18:12.076: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
mempool not found from usrContainer(6712D69C)
*May 26 14:18:12.076: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Mempool(668508D0) created in usrContainer(6712D69C)
*May 26 14:18:12.076: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=74
cisco-rdn=7788000
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 26 14:18:12.080: //11014263/77851A998A0D/CCAPI/ccSetDigitTimeouts:
*May 26 14:18:12.084: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
data = 66C8653C
*May 26 14:18:12.084: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(668508D0)=0 - mempool cleanup
*May 26 14:18:12.108: //11014263/77851A998A0D/CCAPI/ccCallDisconnect:
*May 26 14:18:12.112: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:172.32.2.1:5060 SIP/2.0
Via: SIP/2.0/UDP 172.18.5.10:5060;branch=z9hG4bK4D4F6FB66
To: <172.32.2.1>;tag=6E60FA4-18EF172.32.2.1>
Max-Forwards: 70
Timestamp: 1369577892
CSeq: 101 BYE
Content-Length: 0
*May 26 14:18:12.936: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Sun, 26 May 2013 14:50:40 GMT
CSeq: 101 BYE
Content-Length: 0
*May 26 14:18:12.936: //11014263/77851A998A0D/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49BF15C4, Tag=0x0, Call Id=11014263,
*May 26 14:18:12.936: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 26 14:18:12.936: :cc_free_feature_vsa freeing 665C7890
*May 26 14:18:12.936: vsacount in free is 3
*May 26 14:18:13.352: //11014260/ECAAC0258BD6/CCAPI/ccAssociateStream:
Record Function=0x0, Event Queue=0x49FF0984, Stream Context=668F3710,
Record Context=0x0, Stream Call Id=11014261, Call Id=11014260
*May 26 14:18:13.356: //11014260/ECAAC0258BD6/CCAPI/cc_api_call_associated:
Interface=0x0, CallId=11014260, Disposition=0
Media Type=0x3, SPI Context=0x4BB555C0, Stream CallId=11014261
*May 26 14:18:16.836: //11014258/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 9 to dstCallId 0xA81073
*May 26 14:18:16.836: //11014258/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3way_conference:
Check DTMF relay digit begin for 3way conf
*May 26 14:18:16.836: //11014258/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
*May 26 14:18:16.836: //11014258/xxxxxxxxxxxx/CCAPI/cc_relay_digit_end_for_3way_conference:
Check DTMF relay digit end for 3way conf
*May 26 14:18:16.836: //11014260/ECAAC0258BD6/CCAPI/cc_api_call_digit_begin:
Source Call Id=11014260, Digit=9, DigitBeginFlags=0x0,
*May 26 14:18:16.836: //11014260/ECAAC0258BD6/CCAPI/cc_api_call_digit_end:
Source Call Id=11014260, Digit=9, Duration=100,
*May 26 14:18:16.840: //11014260/ECAAC0258BD6/CCAPI/ccDisassociateStream:
*May 26 14:18:16.840: //11014260/ECAAC0258BD6/CCAPI/ccSetDigitTimeouts:
*May 26 14:18:16.900: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
mempool not found from usrContainer(671304DC)
*May 26 14:18:16.904: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Mempool(6599E4F0) created in usrContainer(671304DC)
*May 26 14:18:16.904: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
cisco-ani=
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=1
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=74
cisco-rdn=123456789014496
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 26 14:18:16.904: //11014260/ECAAC0258BD6/CCAPI/ccSetDigitTimeouts:
*May 26 14:18:16.908: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
data = 66C8CF3C
*May 26 14:18:16.908: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(6599E4F0)=0 - mempool cleanup
*May 26 14:18:17.720: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:123456789014496@172.18.5.10:5060 SIP/2.0
Via: SIP/2.0/UDP 172.18.5.15:5060;branch=z9hG4bKpE4eErPVrcli2oQF230Amg~~2310203
Max-Forwards: 70
CSeq: 2 BYE
Content-Length: 0
Reason:
*May 26 14:18:17.724: //11014260/ECAAC0258BD6/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x49BF15C4, Call Id=11014260
*May 26 14:18:17.728: //11014260/ECAAC0258BD6/CCAPI/ccSetDigitTimeouts:
*May 26 14:18:17.728: //11014260/ECAAC0258BD6/CCAPI/ccCallDisconnect:
*May 26 14:18:17.744: //11014260/ECAAC0258BD6/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49BF15C4, Tag=0x0, Call Id=11014260,
*May 26 14:18:17.744: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 26 14:18:17.744: :cc_free_feature_vsa freeing 665C7970
*May 26 14:18:17.744: vsacount in free is 2
*May 26 14:18:17.744: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:13311173269@172.18.5.10:5060 SIP/2.0
Via: SIP/2.0/UDP 172.18.5.15:5060;branch=z9hG4bKpE4eErPVrcli2oQF230Amg~~2310205
Max-Forwards: 70
To: <13311173269>;tag=22219D38-1E3A13311173269>
CSeq: 1 INVITE
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 2955 3155 IN IP4 172.18.5.11
s=SIP Call
c=IN IP4 172.18.5.11
t=0 0
m=audio 19280 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
*May 26 14:18:17.744: //11014258/EC73D259A535/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Sum Network, Params=0x0, Call Id=11014258
*May 26 14:18:17.748: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 2 BYE
Content-Length: 0
Reason:
*May 26 14:18:17.752: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 1 INVITE
Content-Length: 244
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
*May 26 14:18:17.772: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Sun, 26 May 2013 14:18:17 GMT
CSeq: 2 BYE
Content-Length: 0
Sent:
SIP/2.0 100 Trying
CSeq: 1 INVITE
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 2 BYE
Content-Length: 0
*May 26 14:18:17.776: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 1 INVITE
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Remote-Party-ID: <13311173269>;party=called;screen=yes;privacy=off13311173269>
Supported: replaces
Supported: sdp-anat
Content-Length: 244
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
*May 26 14:18:17.780: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:13311173269@172.18.5.10:5060 SIP/2.0
Via: SIP/2.0/UDP 172.18.5.15:5060;branch=z9hG4bKpE4eErPVrcli2oQF230Amg~~2310207
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
*May 26 14:18:17.784: //11014259/EC73D259A535/CCAPI/cc_api_call_facility:
Interface=0x49BF15C4, Call Id=11014259
*May 26 14:18:18.776: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:7762@172.18.5.10;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.18.5.15:5060;branch=z9hG4bKpE4eErPVrcli2oQF230Amg~~2310208
Max-Forwards: 69
To: <7762>7762>
From: 13311173269 <13311173269>;tag=ds6157eaab13311173269>
Call-ID: EC73D259C54511E2A535EC4476464CC0-136957808031045700@172.18.5.15
CSeq: 1 INVITE
Content-Length: 856
Expires: 60
App-Info: <172.18.5.15:8000:8443>;ringtone=ringback.wav
Supported: timer
Supported: replaces
Supported: sdp-anat
Min-SE: 360
MIME-Version: 1.0
--uniqueBoundary
Content-Length: 244
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
--uniqueBoundary
Content-Length: 46
m! # ! l
! 13311173269p
!1085118522
--uniqueBoundary
Content-Length: 178
IAM,
PRN,isdn*,,NET5*,
USI,rate,c,s,c,1
USI,lay1,alaw
TMR,00
CPC,09
FCI,,,,,,,y,
--uniqueBoundary--
*May 26 14:18:18.780: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
*May 26 14:18:18.780: Content-Type: application/x-q931
*May 26 14:18:18.784: //11014265/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
*May 26 14:18:18.788: //-1/F29508FC8BDF/CCAPI/cc_api_display_ie_subfields:
cisco-username=13311173269
----- ccCallInfo IE subfields -----
cisco-ani=sip:13311173269@172.18.5.15:5060
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=1
dest=sip:7762@172.18.5.10;transport=udp
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*May 26 14:18:18.788: //-1/F29508FC8BDF/CCAPI/cc_api_call_setup_ind_common:
Interface=0x49BF15C4, Call Info(
Calling Number=sip:13311173269@172.18.5.15:5060,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Called Number=sip:7762@172.18.5.10;transport=udp(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=40, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=11014265
*May 26 14:18:18.788: //-1/F29508FC8BDF/CCAPI/ccCheckClipClir:
In: Calling Number=sip:13311173269@172.18.5.15:5060(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=sip:13311173269@172.18.5.15:5060(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
*May 26 14:18:18.788: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 26 14:18:18.788: :cc_get_feature_vsa malloc success
*May 26 14:18:18.788: cc_get_feature_vsa count is 3
*May 26 14:18:18.792: :FEATURE_VSA attributes are: feature_name:0,feature_time:1717336440,feature_id:8601731
*May 26 14:18:18.792: //11014265/F29508FC8BDF/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
*May 26 14:18:18.792: //11014265/F29508FC8BDF/CCAPI/cc_process_call_setup_ind:
Event=0x4A0CA118
*May 26 14:18:18.792: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*May 26 14:18:18.792: //11014265/F29508FC8BDF/CCAPI/ccCallSetContext:
Context=0x4C492C24
>>>>CCAPI handed cid 11014265 with tag 40 to app "_ManagedAppProcess_Default"
*May 26 14:18:18.792: //11014265/F29508FC8BDF/CCAPI/ccCallProceeding:
*May 26 14:18:18.796: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
mempool not found from usrContainer(67133C7C)
*May 26 14:18:18.796: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Mempool(66AEA174) created in usrContainer(67133C7C)
*May 26 14:18:18.796: //11014265/F29508FC8BDF/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=8000, Params=0x47F954EC, Progress Indication=NULL(0)
*May 26 14:18:18.796: //11014265/F29508FC8BDF/CCAPI/ccCheckClipClir:
Calling Number=sip:13311173269@172.18.5.15:5060(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Guid=F29508FC-C545-11E2-8BDF-86FDA7F81A54, Outgoing Dial-peer=8000
*May 26 14:18:18.796: //11014265/F29508FC8BDF/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=1
dest=7762
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 26 14:18:18.796: //11014265/F29508FC8BDF/CCAPI/ccIFCallSetupRequestPrivate:
Call Params(Calling Number=sip:13311173269@172.18.5.15:5060,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
*May 26 14:18:18.796: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 26 14:18:18.796: :cc_get_feature_vsa malloc success
*May 26 14:18:18.796: cc_get_feature_vsa count is 4
*May 26 14:18:18.796: :FEATURE_VSA attributes are: feature_name:0,feature_time:1717336216,feature_id:8601732
*May 26 14:18:18.800: //11014266/F29508FC8BDF/CCAPI/ccIFCallSetupRequestPrivate:
*May 26 14:18:18.800: //11014266/F29508FC8BDF/CCAPI/ccCallSetContext:
Context=0x47F9549C
*May 26 14:18:18.800: //11014265/F29508FC8BDF/CCAPI/ccSaveDialpeerTag:
*May 26 14:18:18.800: ISDN Se0/3/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 13311173269
*May 26 14:18:18.804: ISDN Se0/3/1:15 Q931: Sending SETUP callref = 0x39B3 callID = 0xB1F3 switch = primary-net5 interface = User
*May 26 14:18:18.804: ISDN Se0/3/1:15 Q931: TX -> SETUP pd = 8 callref = 0x39B3
Sending Complete
Standard = CCITT
Calling Party Number i = 0x2181, '13311173269'
Called Party Number i = 0xA1, '7762'
*May 26 14:18:18.804: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <7762>7762>
Date: Sun, 26 May 2013 14:18:18 GMT
CSeq: 1 INVITE
Content-Length: 0
*May 26 14:18:19.140: ISDN Se0/3/1:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xB9B3
*May 26 14:18:19.140: ISDN Se0/3/1:15 Q931: RXshellX <- ALERTING pd = 8 callref = 0xB9B3
*May 26 14:18:19.144: //11014266/F29508FC8BDF/CCAPI/cc_api_call_proceeding:
*May 26 14:18:19.144: //11014266/F29508FC8BDF/CCAPI/cc_api_call_alert:
*May 26 14:18:19.148: //11014266/F29508FC8BDF/CCAPI/cc_api_call_alert:
*May 26 14:18:19.148: //11014265/F29508FC8BDF/CCAPI/ccCallAlert:
*May 26 14:18:19.148: //11014265/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4BF51D60, callID1=0xA81079, callID2=0xA8107A, tag=0x0)
(confID=0x4BF51D60, callID1=0xA81079, gcid=F295A524-C54511E2-8BE286FD-A7F81A54, tag=0x0)
*May 26 14:18:19.148: //11014266/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4BF51D60, callID2=0xA8107A, gcid=F295A524-C54511E2-8BE286FD-A7F81A54, tag=0x0)
*May 26 14:18:19.148: //11014265/F29508FC8BDF/CCAPI/ccConferenceCreate:
Conference Id=0x4BF51D60, Call Id1=11014265, Call Id2=11014266, Tag=0x0
*May 26 14:18:19.148: //11014265/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*May 26 14:18:19.148: cc_api_get_xcode_stream : 4534
*May 26 14:18:19.148: //11014265/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x20169D, Source Interface=0x49BF15C4, Source Call Id=11014265,
Destination Call Id=11014266, Disposition=0x0, Tag=0x0
*May 26 14:18:19.152: //11014266/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x20169D, Source Interface=0x4AC9A27C, Source Call Id=11014266,
Destination Call Id=11014265, Disposition=0x0, Tag=0xFFFFFFFF
*May 26 14:18:19.152: //11014265/F29508FC8BDF/CCAPI/cc_generic_bridge_done:
*May 26 14:18:19.152: //11014265/F29508FC8BDF/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x20169D, Destination Call Id=11014266)
*May 26 14:18:19.152: //11014266/F29508FC8BDF/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x20169D, Destination Call Id=11014265)
*May 26 14:18:19.152: //11014266/F29508FC8BDF/CCAPI/cc_api_caps_ind:
Destination Interface=0x49BF15C4, Destination Call Id=11014265, Source Call Id=11014266,
*May 26 14:18:19.152: //11014265/F29508FC8BDF/CCAPI/cc_api_caps_ind:
Destination Interface=0x4AC9A27C, Destination Call Id=11014266, Source Call Id=11014265,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
*May 26 14:18:19.152: //11014265/F29508FC8BDF/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=8261)
*May 26 14:18:19.152: //11014266/F29508FC8BDF/CCAPI/cc_api_caps_ack:
*May 26 14:18:19.156: //11014265/F29508FC8BDF/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x20169D, Call Id1=11014265, Call Id2=11014266
*May 26 14:18:19.156: //11014266/F29508FC8BDF/CCAPI/cc_api_voice_mode_event:
Call Id=11014266
Call Entry(Context=0x47F9549C)
*May 26 14:18:19.156: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: <7762>;tag=2221C6C8-17847762>
CSeq: 1 INVITE
Remote-Party-ID: <7762>;party=called;screen=no;privacy=off7762>
Contact: <7762>7762>
Supported: sdp-anat
Mime-Version: 1.0
Content-Length: 436
--uniqueBoundary
v=0
o=CiscoSystemsSIP-GW-UserAgent 2967 3973 IN IP4 172.18.5.10
s=SIP Call
t=0 0
m=audio 17596 RTP/AVP 0
a=ptime:20
--uniqueBoundary
ACM,
PRN,isdn*,,NET5*,
--uniqueBoundary--
*May 26 14:18:19.160: //11014265/F29508FC8BDF/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=11014265
*May 26 14:18:19.160: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.18.5.15:5060;branch=z9hG4bKpE4eErPVrcli2oQF230Amg~~2310209
Max-Forwards: 70
CSeq: 2 INVITE
Content-Length: 481
--uniqueBoundary
Content-Length: 189
v=0
s=SIP Call
t=0 0
a=ptime:20
--uniqueBoundary
Content-Length: 28
ACM,
PRN,isdn*,,NET5*,
--uniqueBoundary--
*May 26 14:18:19.164: //11014258/EC73D259A535/CCAPI/ccGenerateToneInfo:
*May 26 14:18:19.164: //11014259/EC73D259A535/CCAPI/cc_api_caps_ind:
*May 26 14:18:19.164: //11014259/EC73D259A535/CCAPI/cc_api_caps_ack:
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=205)
*May 26 14:18:19.168: //11014258/EC73D259A535/CCAPI/cc_api_caps_ack:
*May 26 14:18:19.168: //11014258/EC73D259A535/CCAPI/cc_api_voice_mode_event:
Call Id=11014258
*May 26 14:18:19.172: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sun, 26 May 2013 14:18:19 GMT
CSeq: 2 INVITE
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 2 INVITE
Supported: replaces
Supported: sdp-anat
Content-Length: 188
v=0
o=CiscoSystemsSIP-GW-UserAgent 2077 1028 IN IP4 172.18.5.10
s=SIP Call
t=0 0
a=ptime:20
*May 26 14:18:19.176: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.18.5.15:5060;branch=z9hG4bKpE4eErPVrcli2oQF230Amg~~2310210
Max-Forwards: 70
CSeq: 2 ACK
Content-Length: 0
*May 26 14:18:19.176: //11014259/EC73D259A535/CCAPI/cc_api_call_facility:
*May 26 14:18:27.168: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.32.2.1:5060;branch=z9hG4bK3FB31BF3
Date: Sun, 26 May 2013 14:50:55 GMT
Call-ID: 8123DF0A-C54A11E2-8A14BD62-1005485D@172.32.2.1
Min-SE: 360
Cisco-Guid: 2166571746-3309965794-2316418402-268781661
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1369579855
Expires: 60
Mime-Version: 1.0
Content-Length: 508
--uniqueBoundary
v=0
o=CiscoSystemsSIP-GW-UserAgent 3066 2203 IN IP4 172.32.2.1
s=SIP Call
c=IN IP4 172.32.2.1
t=0 0
m=audio 18494 RTP/AVP 0 101
c=IN IP4 172.32.2.1
a=fmtp:101 0-16
a=ptime:20
--uniqueBoundary
IAM,
GCI,812342e2c54a11e28a11bd621005485d
--uniqueBoundary--
*May 26 14:18:27.176: //11014268/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
*May 26 14:18:27.176: //-1/812342E28A11/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 26 14:18:27.180: //-1/812342E28A11/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=11014268
*May 26 14:18:27.180: //-1/812342E28A11/CCAPI/ccCheckClipClir:
*May 26 14:18:27.180: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 26 14:18:27.180: :cc_get_feature_vsa malloc success
*May 26 14:18:27.180: cc_get_feature_vsa count is 5
*May 26 14:18:27.180: :FEATURE_VSA attributes are: feature_name:0,feature_time:1717335992,feature_id:8601733
*May 26 14:18:27.180: //11014268/812342E28A11/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*May 26 14:18:27.180: //11014268/812342E28A11/CCAPI/cc_process_call_setup_ind:
Event=0x4A0CA118
*May 26 14:18:27.180: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*May 26 14:18:27.180: //11014268/812342E28A11/CCAPI/ccCallSetContext:
Context=0x4C7496BC
>>>>CCAPI handed cid 11014268 with tag 7788000 to app "_ManagedAppProcess_outbound"
*May 26 14:18:27.184: //11014268/812342E28A11/CCAPI/ccCallSetupAck:
Call Id=11014268
*May 26 14:18:27.184: //11014268/812342E28A11/CCAPI/cc_api_set_transfer_info:
*May 26 14:18:27.184: //11014268/812342E28A11/CCAPI/ccCallProceeding:
*May 26 14:18:27.184: //11014268/812342E28A11/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
*May 26 14:18:27.184: //11014268/812342E28A11/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x0
Call Entry(Connected=TRUE, Responsed=TRUE)
*May 26 14:18:27.184: //11014268/812342E28A11/CCAPI/ccCallHandoff:
*May 26 14:18:27.228: //11014268/812342E28A11/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=0(ms), Inter Digit Timeout=0(ms)
Call Entry(Inter Digit Timeout=0(ms), Initial Digit Timeout=0(ms))
*May 26 14:18:27.228: //11014268/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0xA8107C, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 26 14:18:27.228: //11014268/812342E28A11/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=11014268
*May 26 14:18:27.228: //11014268/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49BF15C4, callID=0xA8107C, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 26 14:18:27.228: //11014268/812342E28A11/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x49BF15C4, Call Id=11014268
Call Entry(Initial Digit Timeout=0(ms), Inter Digit Timeout=0(ms))
*May 26 14:18:27.236: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sun, 26 May 2013 14:18:27 GMT
CSeq: 101 INVITE
Content-Length: 0
Sent:
SIP/2.0 180 Ringing
To: <7788000>;tag=2221E628-1B887788000>
CSeq: 101 INVITE
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 5244 9042 IN IP4 172.18.5.10
s=SIP Call
t=0 0
m=audio 16790 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
*May 26 14:18:27.984: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
mempool not found from usrContainer(6712FD0C)
*May 26 14:18:27.984: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Mempool(6367DCD8) created in usrContainer(6712FD0C)
*May 26 14:18:27.984: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
vapp_apply_callinfo_precedence:
cisco-username=
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=74
cisco-rdn=7788000
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=10 fwd_final_type =0
*May 26 14:18:28.008: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Content-Length: 244
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
*May 26 14:18:28.012: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.32.2.1:5060;branch=z9hG4bK3FB41D47
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*May 26 14:18:28.012: //11014268/812342E28A11/CCAPI/ccSetDigitTimeouts:
*May 26 14:18:28.016: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
data = 66C885FC
*May 26 14:18:28.016: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(6367DCD8)=0 - mempool cleanup
*May 26 14:18:28.324: //11014268/812342E28A11/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*May 26 14:18:28.328: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.18.5.10:5060;branch=z9hG4bK4D4F70EF2
To: <172.32.2.1>;tag=6E64EAC-1EC0172.32.2.1>
Date: Sun, 26 May 2013 14:18:28 GMT
Max-Forwards: 70
Timestamp: 1369577908
CSeq: 101 BYE
Content-Length: 0
Received:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*May 26 14:18:29.172: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Sun, 26 May 2013 14:50:57 GMT
CSeq: 101 BYE
Content-Length: 0
*May 26 14:18:29.172: //11014268/812342E28A11/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49BF15C4, Tag=0x0, Call Id=11014268,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
*May 26 14:18:29.172: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 26 14:18:29.172: :cc_free_feature_vsa freeing 665C77B0
*May 26 14:18:29.172: vsacount in free is 4
*May 26 14:18:30.388: ISDN Se0/3/1:15 Q931: RX <- CONNECT pd = 8 callref = 0xB9B3
*May 26 14:18:30.388: %ISDN-6-CONNECT: Interface Serial0/3/1:30 is now connected to 7762 N/A
*May 26 14:18:30.388: ISDN Se0/3/1:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x39B3
*May 26 14:18:30.388: //11014266/F29508FC8BDF/CCAPI/cc_api_call_connected:
Connection Handle=0
*May 26 14:18:30.392: //11014265/F29508FC8BDF/CCAPI/ccCallConnect:
*May 26 14:18:30.392: //11014265/F29508FC8BDF/CCAPI/ccCallNotify:
*May 26 14:18:30.396: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
*May 26 14:18:30.396: Content-Type: application/x-q931
08 02 39 B3 07 4C 06 11 80 37 37 36 32 0D 0A
*May 26 14:18:30.396: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Mime-Version: 1.0
Content-Length: 574
--uniqueBoundary
v=0
s=SIP Call
t=0 0
a=ptime:20
--uniqueBoundary
Content-Length: 15
93L 7762
--uniqueBoundary
ANM,
PRN,isdn*,,NET5*,
--uniqueBoundary--
*May 26 14:18:31.464: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
*May 26 14:18:31.464: Content-Type: application/x-q931
*May 26 14:18:31.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Mime-Version: 1.0
Content-Length: 574
--uniqueBoundary
v=0
s=SIP Call
t=0 0
a=ptime:20
--uniqueBoundary
Content-Length: 15
93L 7762
--uniqueBoundary
ANM,
PRN,isdn*,,NET5*,
--uniqueBoundary--
*May 26 14:18:32.388: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
*May 26 14:18:32.388: Content-Type: application/x-q931
*May 26 14:18:32.392: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Mime-Version: 1.0
Content-Length: 574
--uniqueBoundary
v=0
s=SIP Call
t=0 0
a=ptime:20
--uniqueBoundary
Content-Length: 15
93L 7762
--uniqueBoundary
ANM,
PRN,isdn*,,NET5*,
--uniqueBoundary--
*May 26 14:18:33.896: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
*May 26 14:18:33.896: Content-Type: application/x-q931
*May 26 14:18:33.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Mime-Version: 1.0
Content-Length: 574
--uniqueBoundary
v=0
s=SIP Call
t=0 0
a=ptime:20
--uniqueBoundary
Content-Length: 15
93L 7762
--uniqueBoundary
ANM,
PRN,isdn*,,NET5*,
--uniqueBoundary--
*May 26 14:18:37.896: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
*May 26 14:18:37.896: Content-Type: application/x-q931
*May 26 14:18:37.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Mime-Version: 1.0
Content-Length: 574
--uniqueBoundary
v=0
s=SIP Call
t=0 0
a=ptime:20
--uniqueBoundary
Content-Length: 15
93L 7762
--uniqueBoundary
ANM,
PRN,isdn*,,NET5*,
--uniqueBoundary--
*May 26 14:18:41.896: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
*May 26 14:18:41.896: Content-Type: application/x-q931
*May 26 14:18:41.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Mime-Version: 1.0
Content-Length: 574
--uniqueBoundary
v=0
s=SIP Call
t=0 0
a=ptime:20
--uniqueBoundary
Content-Length: 15
93L 7762
--uniqueBoundary
ANM,
PRN,isdn*,,NET5*,
--uniqueBoundary--
*May 26 14:18:43.388: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.32.2.1:5060;branch=z9hG4bK3FB525D5
Date: Sun, 26 May 2013 14:51:12 GMT
Call-ID: 8ACEDA6A-C54A11E2-8A18BD62-1005485D@172.32.2.1
Min-SE: 360
Cisco-Guid: 2328772162-3309965794-2316680546-268781661
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1369579872
Expires: 60
Mime-Version: 1.0
Content-Length: 508
--uniqueBoundary
v=0
o=CiscoSystemsSIP-GW-UserAgent 6566 6559 IN IP4 172.32.2.1
s=SIP Call
c=IN IP4 172.32.2.1
t=0 0
m=audio 16608 RTP/AVP 0 101
c=IN IP4 172.32.2.1
a=fmtp:101 0-16
a=ptime:20
--uniqueBoundary
IAM,
GCI,8ace3e42c54a11e28a15bd621005485d
--uniqueBoundary--
*May 26 14:18:43.396: //11014269/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
Call Entry Is Not Found
*May 26 14:18:43.396: //-1/8ACE3E428A15/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=sip:172.32.2.1
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=sip:7788000@172.18.5.10:5060
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 26 14:18:43.400: //-1/8ACE3E428A15/CCAPI/cc_api_call_setup_ind_common:
Calling Number=sip:172.32.2.1,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=sip:7788000@172.18.5.10:5060(TON=Unknown, NPI=Unknown),
Incoming Dial-peer=7788000, Progress Indication=NULL(0), Calling IE Present=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=11014269
*May 26 14:18:43.400: //-1/8ACE3E428A15/CCAPI/ccCheckClipClir:
In: Calling Number=sip:172.32.2.1(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=sip:172.32.2.1(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*May 26 14:18:43.400: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 26 14:18:43.400: :cc_get_feature_vsa malloc success
*May 26 14:18:43.400: cc_get_feature_vsa count is 5
*May 26 14:18:43.400: :FEATURE_VSA attributes are: feature_name:0,feature_time:1717335992,feature_id:8601734
*May 26 14:18:43.400: //11014269/8ACE3E428A15/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
*May 26 14:18:43.400: //11014269/8ACE3E428A15/CCAPI/cc_process_call_setup_ind:
Event=0x4A0CA118
*May 26 14:18:43.400: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 7788000
*May 26 14:18:43.400: //11014269/8ACE3E428A15/CCAPI/ccCallSetContext:
Context=0x4C003B34
>>>>CCAPI handed cid 11014269 with tag 7788000 to app "_ManagedAppProcess_outbound"
*May 26 14:18:43.404: //11014269/8ACE3E428A15/CCAPI/ccCallSetupAck:
Call Id=11014269
*May 26 14:18:43.404: //11014269/8ACE3E428A15/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
*May 26 14:18:43.404: //11014269/8ACE3E428A15/CCAPI/ccCallProceeding:
*May 26 14:18:43.404: //11014269/8ACE3E428A15/CCAPI/ccCallAlert:
Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
*May 26 14:18:43.404: //11014269/8ACE3E428A15/CCAPI/ccCallConnect:
*May 26 14:18:43.408: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sun, 26 May 2013 14:18:43 GMT
CSeq: 101 INVITE
Content-Length: 0
Sent:
SIP/2.0 180 Ringing
To: <7788000>;tag=22222584-D317788000>
CSeq: 101 INVITE
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 9661 5658 IN IP4 172.18.5.10
s=SIP Call
t=0 0
m=audio 19328 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
*May 26 14:18:43.412: //11014269/8ACE3E428A15/CCAPI/ccCallHandoff:
Silent=FALSE, Application=0x5DD453FC, Conference Id=0xFFFFFFFF
*May 26 14:18:43.452: //11014269/8ACE3E428A15/CCAPI/ccSetDigitTimeouts:
*May 26 14:18:43.452: //11014269/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0xA8107D, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 26 14:18:43.452: //11014269/8ACE3E428A15/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=11014269
*May 26 14:18:43.452: //11014269/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49BF15C4, callID=0xA8107D, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 26 14:18:43.452: //11014269/8ACE3E428A15/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x49BF15C4, Call Id=11014269
*May 26 14:18:43.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.32.2.1:5060;branch=z9hG4bK3FB624F
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*May 26 14:18:43.528: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
mempool not found from usrContainer(67137E44)
*May 26 14:18:43.528: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Mempool(61983D28) created in usrContainer(67137E44)
*May 26 14:18:43.528: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=74
cisco-rdn=7788000
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 26 14:18:43.532: //11014269/8ACE3E428A15/CCAPI/ccSetDigitTimeouts:
*May 26 14:18:43.532: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
data = 66C892FC
*May 26 14:18:43.532: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(61983D28)=0 - mempool cleanup
*May 26 14:18:43.636: //11014269/8ACE3E428A15/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*May 26 14:18:43.640: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.18.5.10:5060;branch=z9hG4bK4D4F711C79
To: <172.32.2.1>;tag=6E68E08-23F8172.32.2.1>
Max-Forwards: 70
Timestamp: 1369577923
CSeq: 101 BYE
Content-Length: 0
*May 26 14:18:44.412: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Content-Length: 0
*May 26 14:18:44.416: //11014269/8ACE3E428A15/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49BF15C4, Tag=0x0, Call Id=11014269,
*May 26 14:18:44.416: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 26 14:18:44.416: :cc_free_feature_vsa freeing 665C77B0
*May 26 14:18:44.416: vsacount in free is 4
*May 26 14:18:45.896: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
*May 26 14:18:45.896: Content-Type: application/x-q931
*May 26 14:18:45.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Mime-Version: 1.0
Content-Length: 574
--uniqueBoundary
v=0
s=SIP Call
t=0 0
a=ptime:20
--uniqueBoundary
Content-Length: 15
93L 7762
--uniqueBoundary
ANM,
PRN,isdn*,,NET5*,
--uniqueBoundary--
*May 26 14:18:49.896: //11014265/F29508FC8BDF/CCAPI/cc_api_call_disconnected:
Cause Value=102, Interface=0x49BF15C4, Call Id=11014265
Call Entry(Responsed=TRUE, Cause Value=102, Retry Count=0)
*May 26 14:18:49.896: //11014265/F29508FC8BDF/CCAPI/ccConferenceDestroy:
Conference Id=0x20169D, Tag=0x0
*May 26 14:18:49.896: //11014265/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*May 26 14:18:49.896: //11014266/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=11014265, Disposition=0x0, Tag=0x0
*May 26 14:18:49.896: //11014265/F29508FC8BDF/CCAPI/cc_generic_bridge_done:
*May 26 14:18:49.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:13311173269@172.18.5.15:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.18.5.10:5060;branch=z9hG4bK4D4F72CC5
To: 13311173269 <13311173269>;tag=ds6157eaab13311173269>
Max-Forwards: 70
Timestamp: 1369577929
CSeq: 101 BYE
Reason: Q.850;cause=86
Content-Length: 0
*May 26 14:18:49.900: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 BYE
Content-Length: 0
*May 26 14:18:49.900: //11014265/F29508FC8BDF/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49BF15C4, Tag=0x0, Call Id=11014265,
Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0)
*May 26 14:18:49.900: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 26 14:18:49.900: :cc_free_feature_vsa freeing 665C7970
*May 26 14:18:49.900: vsacount in free is 3
*May 26 14:18:49.904: //11014266/F29508FC8BDF/CCAPI/ccCallDisconnect:
Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
*May 26 14:18:49.904: //11014266/F29508FC8BDF/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
*May 26 14:18:49.928: %ISDN-6-DISCONNECT: Interface Serial0/3/1:30 disconnected from 7762 , call lasted 19 seconds
*May 26 14:18:49.928: ISDN Se0/3/1:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x39B3
Cause i = 0x80E6 - Recovery on timer expiry
*May 26 14:18:50.444: ISDN Se0/3/1:15 Q931: RX <- RELEASE pd = 8 callref = 0xB9B3
Cause i = 0x8090 - Normal call clearing
*May 26 14:18:50.448: ISDN Se0/3/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x39B3
*May 26 14:18:50.452: //11014266/F29508FC8BDF/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x4AC9A27C, Tag=0x0, Call Id=11014266,
*May 26 14:18:50.452: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 26 14:18:50.452: :cc_free_feature_vsa freeing 665C7890
*May 26 14:18:50.452: vsacount in free is 2
*May 26 14:18:50.452: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
data = 66C92DBC
*May 26 14:18:50.452: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(66AEA174)=0 - mempool cleanup
*May 26 14:18:51.900: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REFER sip:13311173269@172.18.5.10:5060 SIP/2.0
Via: SIP/2.0/UDP 172.18.5.15:5060;branch=z9hG4bKpE4eErPVrcli2oQF230Amg~~2310212
Max-Forwards: 70
CSeq: 3 REFER
Content-Length: 0
Refer-To: <92929292>92929292>
Referred-By:
*May 26 14:18:51.904: //11014259/EC73D259A535/CCAPI/cc_api_call_facility:
*May 26 14:18:51.904: //11014259/EC73D259A535/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
CallInfo(ssCTreRoutingNotSupported=FALSE)
*May 26 14:18:51.904: //11014258/EC73D259A535/CCAPI/ccConferenceDestroy:
Conference Id=0x20169C, Tag=0x0
*May 26 14:18:51.904: //11014258/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=11014259, Disposition=0x0, Tag=0x0
*May 26 14:18:51.908: //11014259/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*May 26 14:18:51.908: //11014258/EC73D259A535/CCAPI/cc_generic_bridge_done:
*May 26 14:18:51.908: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 26 14:18:51.908: :cc_get_feature_vsa malloc success
*May 26 14:18:51.908: cc_get_feature_vsa count is 3
*May 26 14:18:51.908: :FEATURE_VSA attributes are: feature_name:0,feature_time:1717336216,feature_id:8601735
*May 26 14:18:51.908: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*May 26 14:18:51.908: feature_vsa is 665C7A50,featname is 0
*May 26 14:18:51.908: cc_get_feature_vsa count is 4
*May 26 14:18:51.908: :FEATURE_VSA attributes are: feature_name:0,feature_time:1717336440,feature_id:8601736
*May 26 14:18:51.908: : Generating new featurevsa,inserting it
*May 26 14:18:51.908: feature call transfer featname is 5
*May 26 14:18:51.908: feature_vsa is 665C7B30,featname is 0
*May 26 14:18:51.908: cc_get_feature_vsa count is 5
*May 26 14:18:51.908: :FEATURE_VSA attributes are: feature_name:0,feature_time:1717335992,feature_id:8601737
*May 26 14:18:51.908: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 26 14:18:51.908: :cc_free_feature_vsa freeing 665C7890
*May 26 14:18:51.908: vsacount in free is 4
*May 26 14:18:51.908: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 202 Accepted
Date: Sun, 26 May 2013 14:18:51 GMT
CSeq: 3 REFER
Content-Length: 0
Sent:
NOTIFY sip:172.18.5.15:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.18.5.10:5060;branch=z9hG4bK4D4F731660
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: refer
Subscription-State: pending;expires=180
Content-Type: message/sipfrag
Content-Length: 22
SIP/2.0 100 Trying
*May 26 14:18:51.912: //11014258/EC73D259A535/CCAPI/ccSaveDialpeerTag:
Outgoing Dial-peer=0
*May 26 14:18:51.912: //11014258/EC73D259A535/CCAPI/ccGetTBCTCap:
TGRM TBCT Enabled; TBCT Capability=0
*May 26 14:18:51.912: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 26 14:18:51.912: :cc_get_feature_vsa malloc success
*May 26 14:18:51.912: cc_get_feature_vsa count is 5
*May 26 14:18:51.912: :FEATURE_VSA attributes are: feature_name:0,feature_time:1717336216,feature_id:8601738
*May 26 14:18:51.912: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*May 26 14:18:51.912: : updating existing feature vsa
*May 26 14:18:51.912: feature call transfer featname is 5
*May 26 14:18:51.912: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 26 14:18:51.912: :cc_free_feature_vsa freeing 665C7890
*May 26 14:18:51.912: vsacount in free is 4
*May 26 14:18:51.916: //11014259/EC73D259A535/CCAPI/ccCallFacility:
Call Id=11014259
*May 26 14:18:51.916: //11014258/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4BF75D78, callID1=0xA81072, callID2=0xA81073, tag=0x0)
(confID=0x4BF75D78, callID1=0xA81072, gcid=EC73D259-C54511E2-A535EC44-76464CC0, tag=0x0)
*May 26 14:18:51.916: //11014259/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4BF75D78, callID2=0xA81073, gcid=EC73D259-C54511E2-A535EC44-76464CC0, tag=0x0)
*May 26 14:18:51.916: //11014258/EC73D259A535/CCAPI/ccConferenceCreate:
Conference Id=0x4BF75D78, Call Id1=11014258, Call Id2=11014259, Tag=0x0
*May 26 14:18:51.916: //11014258/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x20169E, Source Interface=0x4AB00E28, Source Call Id=11014258,
*May 26 14:18:51.916: //11014259/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*May 26 14:18:51.916: cc_api_get_xcode_stream : 4534
*May 26 14:18:51.916: //11014259/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x20169E, Source Interface=0x49BF15C4, Source Call Id=11014259,
*May 26 14:18:51.916: //11014258/EC73D259A535/CCAPI/cc_generic_bridge_done:
Call Entry(Conference Id=0x20169E, Destination Call Id=11014259)
*May 26 14:18:51.916: //11014259/EC73D259A535/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x20169E, Destination Call Id=11014258)
*May 26 14:18:51.916: //11014258/EC73D259A535/CCAPI/cc_api_caps_ind:
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
*May 26 14:18:51.916: //11014259/EC73D259A535/CCAPI/cc_api_caps_ind:
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
*May 26 14:18:51.920: //11014259/EC73D259A535/CCAPI/cc_api_caps_ind:
*May 26 14:18:51.920: //11014259/EC73D259A535/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=27657)
*May 26 14:18:51.920: //11014258/EC73D259A535/CCAPI/cc_api_caps_ack:
*May 26 14:18:51.920: //11014258/EC73D259A535/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x20169E, Call Id1=11014258, Call Id2=11014259
*May 26 14:18:51.920: //11014258/EC73D259A535/CCAPI/cc_api_voice_mode_event:
Call Id=11014258
*May 26 14:18:51.924: //11014258/EC73D259A535/CCAPI/cc_api_voice_mode_event:
*May 26 14:18:51.924: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.18.5.10:5060;branch=z9hG4bK4D4F74405
CSeq: 103 NOTIFY
Max-Forwards: 70
Event: refer
Subscription-State: terminated;reason=noresource
Content-Length: 35
SIP/2.0 503 Service Unavailable
Received:
SIP/2.0 200 Ok
CSeq: 102 NOTIFY
Content-Length: 0
Allow-Events: refer
Allow-Events: kpml
*May 26 14:18:51.928: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 103 NOTIFY
Content-Length: 0
Allow-Events: refer
Allow-Events: kpml
Received:
BYE sip:13311173269@172.18.5.10:5060 SIP/2.0
Via: SIP/2.0/UDP 172.18.5.15:5060;branch=z9hG4bKpE4eErPVrcli2oQF230Amg~~2310213
Max-Forwards: 70
CSeq: 4 BYE
Content-Length: 0
*May 26 14:18:51.928: //11014258/EC73D259A535/CCAPI/ccGenerateToneInfo:
*May 26 14:18:51.928: //11014259/EC73D259A535/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x49BF15C4, Call Id=11014259
*May 26 14:18:51.932: //11014259/EC73D259A535/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
*May 26 14:18:51.932: //11014258/EC73D259A535/CCAPI/ccConferenceDestroy:
Conference Id=0x20169E, Tag=0x0
*May 26 14:18:51.932: //11014258/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*May 26 14:18:51.932: //11014259/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*May 26 14:18:51.932: //11014258/EC73D259A535/CCAPI/cc_generic_bridge_done:
*May 26 14:18:51.932: //11014258/EC73D259A535/CCAPI/ccCallDisconnect:
*May 26 14:18:51.932: //11014258/EC73D259A535/CCAPI/cc_api_get_transfer_info:
*May 26 14:18:51.932: //11014259/EC73D259A535/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
*May 26 14:18:52.320: //11014259/EC73D259A535/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49BF15C4, Tag=0x0, Call Id=11014259,
*May 26 14:18:52.320: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 26 14:18:52.320: :cc_free_feature_vsa freeing 665C7970
*May 26 14:18:52.320: vsacount in free is 3
*May 26 14:18:52.320: vsacount in free is 2
*May 26 14:18:52.320: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 4 BYE
Reason: Q.850;cause=16
Content-Length: 0
*May 26 14:18:53.056: %ISDN-6-DISCONNECT: Interface Serial0/3/0:3 disconnected from 13311173269 , call lasted 42 seconds
*May 26 14:18:53.084: ISDN Se0/3/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x83ED
*May 26 14:18:53.236: ISDN Se0/3/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x03ED
*May 26 14:18:53.240: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x83ED
*May 26 14:18:53.244: //11014258/EC73D259A535/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x4AB00E28, Tag=0x0, Call Id=11014258,
*May 26 14:18:53.244: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May 26 14:18:53.244: :cc_free_feature_vsa freeing 665C77B0
*May 26 14:18:53.244: vsacount in free is 1
*May 26 14:18:53.244: vsacount in free is 0
*May 26 14:18:58.700: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.32.2.1:5060;branch=z9hG4bK3FB71604
Date: Sun, 26 May 2013 14:51:27 GMT
Call-ID: 93EEAA7D-C54A11E2-8A1CBD62-1005485D@172.32.2.1
Min-SE: 360
Cisco-Guid: 2481851989-3309965794-2316942690-268781661
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1369579887
Expires: 60
Mime-Version: 1.0
Content-Length: 508
--uniqueBoundary
v=0
o=CiscoSystemsSIP-GW-UserAgent 4040 2818 IN IP4 172.32.2.1
s=SIP Call
c=IN IP4 172.32.2.1
t=0 0
m=audio 18508 RTP/AVP 0 101
c=IN IP4 172.32.2.1
a=fmtp:101 0-16
a=ptime:20
--uniqueBoundary
IAM,
GCI,93ee0e55c54a11e28a19bd621005485d
--uniqueBoundary--
*May 26 14:18:58.704: //11014272/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
*May 26 14:18:58.704: //-1/93EE0E558A19/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*May 26 14:18:58.708: //-1/93EE0E558A19/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=11014272
*May 26 14:18:58.708: //-1/93EE0E558A19/CCAPI/ccCheckClipClir:
*May 26 14:18:58.708: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May 26 14:18:58.708: :cc_get_feature_vsa malloc success
*May 26 14:18:58.708: cc_get_feature_vsa count is 1
*May 26 14:18:58.708: :FEATURE_VSA attributes are: feature_name:0,feature_time:1724351392,feature_id:8601739
*May 26 14:18:58.708: //11014272/93EE0E558A19/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*May 26 14:18:58.708: //11014272/93EE0E558A19/CCAPI/cc_process_call_setup_ind:
Event=0x4A0CA118
*May 26 14:18:58.708: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*May 26 14:18:58.708: //11014272/93EE0E558A19/CCAPI/ccCallSetContext:
Context=0x482B59B4
*May 26 14:18:58.712: //11014272/93EE0E558A19/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 11014272 with tag 7788000 to app "_ManagedAppProcess_outbound"
*May 26 14:18:58.712: //11014272/93EE0E558A19/CCAPI/ccCallSetupAck:
Call Id=11014272
*May 26 14:18:58.712: //11014272/93EE0E558A19/CCAPI/cc_api_set_transfer_info:
*May 26 14:18:58.712: //11014272/93EE0E558A19/CCAPI/ccCallProceeding:
*May 26 14:18:58.712: //11014272/93EE0E558A19/CCAPI/ccCallAlert:
*May 26 14:18:58.712: //11014272/93EE0E558A19/CCAPI/ccCallConnect:
*May 26 14:18:58.712: //11014272/93EE0E558A19/CCAPI/ccCallHandoff:
*May 26 14:18:58.756: //11014272/93EE0E558A19/CCAPI/ccSetDigitTimeouts:
*May 26 14:18:58.756: //11014272/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0xA81080, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 26 14:18:58.756: //11014272/93EE0E558A19/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=11014272
*May 26 14:18:58.756: //11014272/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49BF15C4, callID=0xA81080, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*May 26 14:18:58.756: //11014272/93EE0E558A19/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x49BF15C4, Call Id=11014272
*May 26 14:18:58.764: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sun, 26 May 2013 14:18:58 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Content-Length: 0
Sent:
SIP/2.0 180 Ringing
To: <7788000>;tag=22226154-14D17788000>
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Se
[END] 2013/5/26 22:21:34
