h323 gateway redundant call manager
dan.letkeman
Level 4
Level 4
I am trying to setup a redunant connection from a 2921 voice router to both my publisher and my subscriber call manager.  Everything is working when the publisher is running, but I recently did an upgrade and when the publisher (10.1.1.11) was down, the outside callers could not call in, they just got a busy signal.  All of our phones automatically registered with the subscriber so that part worked fine, but no outside calls made it through the router.
Dial-peer 503, and 504 should be failing over.
Here is the relevant config:
voice service voip
ip address trusted list
  ipv4 10.1.1.11
  ipv4 10.1.1.12
gcid
clid substitute name
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  h225 timeout setup 3
voice class h323 1
  h225 timeout tcp establish 3
application
global
  service alternate DEFAULT
redundancy
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24
interface Loopback0
ip address 10.1.100.100 255.255.255.255
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.1.100.100
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.1.1.10 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
router eigrp 100
network 10.1.1.0 0.0.0.255
network 10.1.100.100 0.0.0.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
voice-port 0/0/0:23
echo-cancel coverage 64
bearer-cap Speech
ccm-manager redundant-host 10.1.1.12
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.1.1.11
ccm-manager config
mgcp call-agent 10.1.1.11 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
dial-peer voice 100 pots
description 7 Digit Dialing
destination-pattern 9[2-9]......
port 0/0/0:23
forward-digits 7
no sip-register
dial-peer voice 200 pots
incoming called-number .
direct-inward-dial
port 0/0/0:23
dial-peer voice 101 pots
description Long Distance 11 Digit Dialing
destination-pattern 91[2-9]..[2-9]......
port 0/0/0:23
forward-digits 11
no sip-register
dial-peer voice 105 pots
description 3 Digit Service Codes
destination-pattern 9[2-8]11
port 0/0/0:23
forward-digits 3
no sip-register
dial-peer voice 5000 pots
description Calling Card
destination-pattern 9[0][2-9]..[2-9]......
port 0/0/0:23
forward-digits 11
no sip-register
dial-peer voice 102 pots
description Local 10 Digit Dialing
destination-pattern 9[2-9]..[2-9]......
port 0/0/0:23
forward-digits 10
no sip-register
dial-peer voice 901 voip
incoming called-number 8.T
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 106 pots
description Star 6 Codes
destination-pattern 9*6[1-9][2-9]..[2-9]......
clid restrict
port 0/0/0:23
forward-digits 10
no sip-register
dial-peer voice 503 voip
preference 1
destination-pattern 5553......
session target ipv4:10.1.1.11
voice-class h323 1
ip qos dscp cs3 signaling
no vad
dial-peer voice 504 voip
preference 2
session target ipv4:10.1.1.12
voice-class h323 1
no vad
gateway
timer receive-rtp 1200
gatekeeper
no shutdown
I must be missing something.
Dan.
From the debugs:
-First the call tries to connect to 10.1.1.11; TCP transactions show that the TCP cannot be established:
Dec 28 15:22:42.874: TCP: Random local port generated 41942, network 1
Dec 28 15:22:42.874: TCB2CEF6C08 bound to 10.1.100.100.41942
Dec 28 15:22:42.874: Reserved port 41942 in Transport Port Agent for TCP IP type 1
Dec 28 15:22:42.874: TCP: sending SYN, seq 3207241951, ack 0
Dec 28 15:22:42.874: TCP0: Connection to 10.1.1.11:1720, advertising MSS 1460
Dec 28 15:22:42.874: TCP0: state was CLOSED -> SYNSENT [41942 -> 10.1.1.11(1720)]
Dec 28 15:22:42.874: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xFE0C
Channel ID i = 0xA98381
Exclusive, Channel 1
vr#
Dec 28 15:22:44.866: TCP389: ACK timeout timer expired
Dec 28 15:22:44.874: 10.1.100.100:41942 <---> 10.1.1.11:1720   congestion window changes
Dec 28 15:22:44.874: cwnd from 1460 to 1460, ssthresh from 65535 to 2920
Dec 28 15:22:44.874: TCP0: timeout #1 - timeout is 4000 ms, seq 3207241951
Dec 28 15:22:44.874: TCP: (41942) -> 10.1.1.11(1720)
Cause Value 38 = CC_CAUSE_NETWORK_OUT_OF_ORDER
-Then the call tries to connect to 10.1.1.12; There is H323 signaling but CUCM sends a release complete:
--snip--
Dec 28 15:22:45.878: H225.0 OUTGOING PDU ::=
value H323_UserInformation ::=
   h323-uu-pdu
     h323-message-body setup :
--snip--
--snip--
Dec 28 15:22:46.242: H225.0 INCOMING PDU ::=
   h323-uu-pdu
     h323-message-body callProceeding :
--snip--
--snip--
Dec 28 15:22:46.246: H225.0 INCOMING PDU ::=
   h323-uu-pdu
     h323-message-body releaseComplete :
--snip--
Cause Value 27 = CC_CAUSE_DESTINATION_OUT_OF_ORDER
-As summary, when matching dial-peer 501 TCP link cannot be established. And when matching dial-peer 502 the CUCM rejects the call
-It would be necessary to check the network or the services on the first CUCM and for the second, well to capture CUCM traces to see why CUCM is rejecting the call
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
28 Replies 28
Chris Deren
Does the device pool assigned to the H323 GW in CUCM has CUCM Group assigned that lists both CUCM servers?
Chris
Yes the communications manager group has both the publisher and subscriber in it.
Dan.
Did you collect "debug isdn q931" or "debug voice dialpeer" for that call?
How about outbound calls, did that work?
Chris
Did you verify that the GW is registered with the Subscriber? Do a show ccm-manager on the GW
HTH Regards, Yosh
He is using it as H323 not MGCP GW, so there is no registration. See the controller and serial configuration.
Chris
I don't belive I am using mgcp.  Just h323.
Primary         Down                     10.1.1.11
First Backup    Down                     10.1.1.12
Second Backup   None
Current active Call Manager:    None
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            15:41:21 CST Nov 17 2012 (elapsed time: 5w4d)
Last MGCP traffic time:         15:41:21 CST Nov 17 2012 (elapsed time: 5w4d)
Last failover time:             None
Last switchback time:           None
Switchback mode:                Graceful
MGCP Fallback mode:             Not Selected
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
Backhaul/Redundant link is down
Configuration Auto-Download Information
No configurations downloaded
Current state: Downloading XML file
Configuration Download statistics:
        Download Attempted             : 1
          Download Successful          : 0
          Download Failed              : 0
          TFTP Download Failed         : 28740
        Configuration Attempted        : 0
          Configuration Successful     : 0
          Configuration Failed(Parsing): 0
          Configuration Failed(config) : 0
Last config download command:
FAX mode: disable
Configuration Error History:
Can you ping from 10.1.100.100 to 10.1.1.12 ?
Run an extended ping from the router.
Pierre.
Both the publisher and subscriber have this result with an extended ping:
The publisher, subscriber and router are all connected to the same switch, with nothing much else on the switch.
Dan,
Are you sure the Publisher was really down (No IP connectivity) ?
You can maybe change the preference so that the Subscriber will be the first one.
Pierre.
Yes the publisher was in the middle of an upgrade.  I am sure of that because I was the one that was doing it.
I did try chaning the preference when it was down and it made no difference.
It's not because the Pub is in the midle of an upgrade that its IP stack is still not working.
If this is the case, the router can still reach the Pub IP address and send the traffic to a black hole.
My suggestion is to change the preference now on your router so that the Subscriber is the first one.
Then run a few calls.
Sounds like IP routing issue, your GW is on different VLAN from the servers, so ensure you have proper routing between the vlans. The following does not look right:
HTH,
Chris
No its not a routing issue, and they are all on the same subnet.
duplex auto
speed auto
pub: 10.1.1.11
sub: 10.1.1.12
interface Loopback0
I am using the loopback for h323 connectivity.
vr#ping
Protocol [ip]:
Target IP address: 10.1.1.12
Repeat count [5]: 100
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 10.1.100.100
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 100, 100-byte ICMP Echos to 10.1.1.12, timeout is 2 seconds:
Packet sent with a source address of 10.1.100.100
Your H323 protocol is bound to the loopback interface which is different subnet:
interface Loopback0
