H323 Gateway Security. Can you Authenticate CUCM
David.Pellat
Beginner
Beginner
We are running 3825 routers and CUCM 7.x.  We have been asked to look at vulnerabilites in the security.
We have found that from inside the network we  can setup an H323 soft phone, point it at our gateway and make external calls.
Besides applying ACL's on the interfaces specifying IP addresses, is there a way to secure the H323 devices that can connect to the gateway?
David
2 ACCEPTED SOLUTIONS
You can invoke the IP toll fraud implementation feature if you upgrade your
3800 to at least 15.1.2T
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080b3e123.shtml
This allows you to build a kind of access list that only allows the IP addresses you state to access the gateway to
make calls
Alex
Regards, Alex. Please rate useful posts.
Or simply use static ACL denying access to TCP port 1720 and TCP/UDP ports 5060/5061 from non-authorised IPs.
_____ Please rate helpful posts Пожалуйста оценивайте полезные сообщения
6 REPLIES 6
Vipul Jindal
The Link does not seem to work.
David
Try now:
http://www.cisco.com/en/US/docs/ios/12_0t/voip/feature/guide/gwsecacc.html
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
This Document was around Gateway to Gatekeeper security.
I was hoping to find out if there is a way to secure the Cisco Callmanager  to Cisco H323 Gateway  communications.
IE, only allowing the gateway to accept outgoing call requests from the CUCM cluster/
David
make calls
Alex
