H323 Gateway T1 PRI call ID problem
Hello
I can understadn why I can't modify my call ID in local calls.
Phone A (DN 7156) dial 887-1500, H323 make the call and applied a traslation rule.
Oct 30 13:04:55 EDT: //-1/00FA1AE63403/RXRULE/regxrule_match: No match; number=7156 rule precedence=1
Oct 30 13:04:55 EDT: //-1/00FA1AE63403/RXRULE/sed_subst: Successful substitution; pattern=7156 matchPattern=^7(...$) replacePattern=7697000 replaced pattern=7697000
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x4181, '7697000'
                Plan:ISDN, Type:Subscriber(local)
        Called Party Number i = 0xC1, '8871500'
In my other gateway recive this...
        Channel ID i = 0xA18387
                Preferred, Channel 7
        Calling Party Number i = 0x0080, '7156'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '1500'
When I use area code for make the call everything works as I expect.
here is my traslation rules and dial-peer.
voice translation-rule 1020
! this rule is for DID
rule 1 /^70\(..$\)/ /76970\1/ type any subscriber
! this rule is for extensions reached by main number.
rule 2 /^7\(...$\)/ /7697000/ type any subscriber
voice translation-profile LOCOUT
translate calling 1020
dial-peer voice 12 pots
trunkgroup AIRESPRING
translation-profile outgoing LOCOUT
destination-pattern 9[2-9][0-9][0-9]....
incoming called-number .
forward-digits 7
any comment will be appreciated
thanks
AA
What you're saying is quite confusing. Because if you do not send '7165', there is no way that telco can present that. Maybe check all traces again.
paolo bevilacqua
In the US, you should send ANI as ISDN/national, with 10 digits.
Hi Paolo,
This is the path
phone DN 7156 --> H323 -->  ((PSTN)) --> H323 --> AA 887-1500 both branches are in the same area code 330 and have the same telco.
when DN 7156 dial 91 (330)-887-1500 and local GW send 11 digits the gw at the other end shows.
        Calling Party Number i = 0x0080, '3307697000'
but when DN 7156 dial 9-887-1500 and local GW send 7 digits the gw at the other end shows.
I made the change that you mentioned before but in the other GW shows the DN instead the mask that i did with translation rules.
translaiton rule
rule 2 /^7\(...$\)/ /3307697000/ type any national
local gw shows
        Calling Party Number i = 0x2181, '3307697000'
                Plan:ISDN, Type:National
In conclusion I just wonder why the telco overrides the translation rule with the DN if I make the call with 7 digits.
thanks
You're rigth.
I did a mistake tracing the call, I forgot the route pattern have a route list with two gateways so the call was rerouted to the back-up gateway and this gateways don't have translation rules to mask DN 7156.
Nov  5 13:42:50 EST: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x09B9
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98395
                Exclusive, Channel 21
Nov  5 13:42:50 EST: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x89B9
Nov  5 13:42:50 EST: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x89B9
        Cause i = 0x82A9 - Temporary failure
Nov  5 13:42:50 EST: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x09B9
Nov  5 13:42:50 EST: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x89B9
Nov  5 13:43:09 EST: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0BB4
