02-02-2015 09:27 PM - edited 03-17-2019 01:48 AM
Hi All,
H323 gateway with 2 E1 trunk.
0/0/0 is Primary PRI for ext 64278.....
0/0/1 is Secondary PRI for ext 62135500-62135599
We have pots dial peer which are matching with answering address corresponding DID.
IOS version is 15.4
The pots dial peer for secondary PRI is 12 & Primary PRI is 9.
Here i can see the both DID will take some or the other PRI and will route the calls.
Both PRI is from same SP but they cannot do the tagging of the DID so they want only Primary PRI to make calls via trunk 0/0/0 & Secondary PRI to route calls via 0/0/1 .
answering address in the pots dial peer is not working , so kindly suggest solution for this.
This is causing caller ID mismatch once calls are routing via different trunk which are not mapped for them.
Shinaj.cm
card type e1 0 0
logging buffered 10000
logging console informational
enable secret 5 $1$4/t7$F3pjhr8/n0WH6iO6KgKQm1
aaa new-model
aaa authentication login default group tacacs+ line
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa session-id common
network-clock-participate wic 0
no ip source-route
ip cef
no ipv6 cef
isdn switch-type primary-5ess
crypto pki trustpoint TP-self-signed-3366272181
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3366272181
revocation-check none
rsakeypair TP-self-signed-3366272181
crypto pki certificate chain TP-self-signed-3366272181
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33333636 32373231 3831301E 170D3134 30363137 30393435
32375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 33363632
37323138 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100AFE7 E9B0D934 E96600C1 0D15DA1D CC2C1D19 EBC5D418 A02D15C6 A18D8AF0
D834ADE3 8346E673 04F96621 9106CB2D 2DA6F381 A4BCBDF8 33E35560 9C7EE8FE
49160F49 949C9B23 27395B05 26B14808 2994E847 52B83714 74D00BD6 5FA8E654
9528354A 1C6EBE39 2C016214 17BC1738 B27DDC97 A06CEA9E 5AC002B8 DAEEF185
E0D90203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14F02568 5FFF6279 34AC8784 BDFC20DB BCB24CEE D7301D06
03551D0E 04160414 F025685F FF627934 AC8784BD FC20DBBC B24CEED7 300D0609
2A864886 F70D0101 05050003 81810072 B849FF53 B6FBE343 5DB3A6BA C78C1379
68ACCD5A 3B701E83 42A4C020 E4F6A0F9 F1F535A4 3E60B592 192F8ACB F5B8597D
98DFA692 D98C7D25 26D567A3 5E8E0F04 48CE422D E0AA8C48 967891CA 55528E0D
86DC3F14 5C61CE55 C9E155A1 C2CD85E8 7D2FE383 CFF8E070 DC709D45 1062CA68
4152A78C 492345AC 55D43FAA 5021C5
quit
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
modem passthrough nse codec g711alaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729br8
codec preference 4 g729r8
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 3
voice translation-rule 1
rule 1 /.*/ /9&/
voice translation-rule 2
rule 2 /^9/ //
voice translation-rule 3
rule 1 /^6213\(\)/ /6213\1/
voice translation-rule 4
rule 1 /^6427\(\)/ /6427\1/
voice translation-profile Incoming
translate calling 1
translate called 2
voice translation-profile Outgoing6213
translate calling 3
voice translation-profile Outgoing6427
translate calling 4
license udi pid C3900-SPE100/K9 sn FOC18216YYC
hw-module pvdm 0/0
hw-module pvdm 0/1
username mland privilege 15 password 7 104305180B13425A
redundancy
controller E1 0/0/0
pri-group timeslots 1-31
controller E1 0/0/1
description Kaki Bukit PRI
no ip ftp passive
ip ftp username router
ip ftp password 7 08345C4A080D00
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no cdp enable
ip default-gateway 3.188.242.1
ip forward-protocol nd
no ip http server
ip http access-class 23
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
voice-port 0/0/0:15
cptone SG
voice-port 0/0/1:15
cptone SG
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm aa.bb.cc.ee identifier 11 version 7.0
sccp ccm aa.bb.cc.dd identifier 10 version 7.0
sccp
sccp ccm group 1
associate ccm 11 priority 1
associate ccm 10 priority 2
associate profile 1 register CFB
dspfarm profile 1 conference
description Hardware CFB
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 3
associate application SCCP
dial-peer voice 9 pots
answer-address 64278...
destination-pattern .T
no digit-strip
port 0/0/0:15
forward-digits all
dial-peer voice 6427 voip
description 6427XXXX-primary
preference 1
destination-pattern 6427....
session target ipv4:aa.bb.cc.ee
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
fax rate disable
no vad
dial-peer voice 6428 voip
description 6427XXXX-secondary
preference 2
session target ipv4:aa.bb.cc.dd
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
dial-peer voice 6861 voip
description 68616100-primary
preference 1
destination-pattern 68616100
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
dial-peer voice 6862 voip
description 68616100-secondary
preference 2
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
dial-peer voice 1 pots
description incoming call from PSTN
translation-profile incoming Incoming
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 6702 voip
description 6702XXXX-primary
preference 1
destination-pattern 6702....
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
dial-peer voice 6703 voip
description 6702XXXX-secondary
preference 2
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
dial-peer voice 11 pots
direct-inward-dial
port 0/0/1:15
dial-peer voice 6213 voip
description 6213XXXX-primary
preference 1
destination-pattern 6213....
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
dial-peer voice 6214 voip
description 6213XXXX-secondary
preference 2
destination-pattern 6214....
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
dial-peer voice 12 pots
answer-address 62135...
no digit-strip
port 0/0/1:15
forward-digits all
dial-peer voice 6215 voip
description 6213XXXX-primary incoming
preference 1
answer-address 6213....
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
dial-peer voice 6429 voip
description 6427XXXX-primary incoming
preference 1
answer-address 6427....
voice-class codec 1
voice-class h323 1
fax rate disable
no vad
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts ringing 24
ip source-address 3.188.242.5 port 2000
max-ephones 100
max-dn 400
line con 0
exec-timeout 60 0
password 7 111A490B04001E1F
line aux 0
exec-timeout 60 0
transport input all
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 3
access-class 23 in
exec-timeout 90 0
password 7 0100560A4819131C
notify
transport input all
line vty 4
access-class 69 in
exec-timeout 90 0
password 7 05185601325E5B1A
notify
transport input all
line vty 5 15
access-class 23 in
exec-timeout 90 0
notify
transport input all
scheduler allocate 20000 1000
end
02-02-2015 10:25 PM
Make the test calls and Provide
debug voip dialpeer all
debug voip ccapi inout
02-03-2015 08:14 PM
Hi Hemant,
I will collect such logs and will get back to you.
Shinaj.cm
02-25-2015 03:21 AM
Hi Hemant,
We have created cor list and applied it and which fixed the issue.
Thank you for your help & assistance in resolving the case.
Shinaj.cm
