H323 GW, IP address Unknown
balitewiczp
Level 2
Level 2
I know the Status is normally Unknown, but the IP address is also Unknown.
On the GW, I have SCCP conference bridge using the same IP as the h323 bind statement, yet the conference bridge is connected.
Isnt it the h323 bound interface that is supposed to show up in Cm gateways?
7 Replies 7
Clifford McGlamry
No, it doesn't.  The gateway will always show an unknown status.  The name of the H323 gateway in CCM should be the IP address you have bound H323 services to.
yes, i know the status will always be unknown.  problem is that the IP address is also unknown.  resetting does no good.
yet sccp resources on the gw, bound to the same ip address register fine
H323 gateways will always show up as unknown. These are peer to peer links, so they are only active when in use. For them to show up as unknown is both normal and expected behavior. The real key is whether or not it works. BTW, you DO have to do a reset on the config after putting it into service to get it to work.
NOTICE OF CONFIDENTIALITY:
The information contained in this email transmission is confidential information which may contain information that is legally privileged and prohibited from disclosure under applicable law or by contractual agreement. The information is intended solely for the use of the individual or entity named above.
If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or taking of any action in reliance on the contents of this email transmission is strictly prohibited.
If you have received this email transmission in error, please notify us immediately by telephone to arrange for the return of the original transmission to us.
Logan Gaffney
Be sure you have the following configured under the interface you are trying to register:
h323-gateway voip interface
h323-gateway voip bind srcaddr
Reset the GW in CUCM
Also be sure there are no FW's blocking 1719 and 1720
cristian.munoz
Level 4
Level 4
Hello
Do you solve your issue?. I have the same problem and I performed a reset of Publisher.
TIA
Cristian.
If I remember right, I had a database replication issue.
I think not. Before this failure occurred, I performed a Backup successful.
Please, see the status DB:
TIA
Cristian Munoz
