09-24-2018 01:02 AM - edited 03-17-2019 01:31 PM
hi
We have configured h323 gatway but unable to make incoming and outgoing calls.
We have
DID Range:
3617160300 - 3617160332 ( 361 is std code)
Internal extension:361300 , 361301, 361302, .... ( 361 we assigned side code)
We have created dial-peers. but outgoing and incoming not workking
outgoing calls getting cause code 21
debug voip ccaip inout
dial-peer voice 3 pots
discription outgoing calls.
destination-pattern 0T
incoming called-number .
direct-inward-dial
port 0/1/0:15
dial-peer voice 1 voip
destination-pattern 3613..
session target ipv4:XX.xx.xx.xx
voice-class codec 1
dtmf-relay h245-alphanumeric
!dial-peer voice 2 voip
prefrence 1
session target ipv4:xx.xx.xx.xx
voice-class codec 1
dial-peer voice 4 pots
discription incoming calls
direct-inward-dial
Please help me is there any dial-peer issue.
we need to config srst- how to create Translation rule.
PFA attached h323 config
09-24-2018 05:14 AM
09-24-2018 05:24 AM
09-24-2018 05:24 AM
Is there a reason you are doing H323 and not SIP?
09-24-2018 05:26 AM
09-24-2018 06:01 AM
Post "debug voice ccapi inout" and "debug isdn q931" along with the number you called.
09-24-2018 06:05 AM
09-24-2018 06:49 AM
Seems like trusted list in voice register global making the issue.
Can you remove the this command in voice register global or add those trusted ip and try an outgoing call.
