05-13-2012 04:14 AM - edited 03-16-2019 11:08 AM
anyone knows the issue?
May 13 11:00:04.479: //239/97B8EB11806A/CCAPI/ccCallDisconnect:
Cause Value=18, Call Entry(Responsed=TRUE, Cause Value=18)
May 13 11:00:04.479: //239/97B8EB11806A/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
05-13-2012 05:27 AM
No user responding.
HTH,
Alex
*Please rate helpful posts
05-13-2012 05:34 AM
but the called number (extension number where i am sending call) is not ringing
05-13-2012 05:41 AM
Maybe that is the problem. Do you get answer from the other side? Are you sending the call correctly?
You have posted only these two lines from the CCAPI with no other explanation and that is what they usualy mean.
Best regards,
Alex
05-13-2012 06:13 AM
Router=2901 with 4-port FXO Card
Connection plar = 3705 (which is extension registered on CUCM)
Both incoming and outgoing calls are not working
MCTRTR#sh tech-support | sec voice
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
h225 connect-passthru
sip
bind control source-interface Loopback10
bind media source-interface Loopback10
registrar server
no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
voice register global
mode cme
source-address 10.1.210.193 port 5060
max-dn 10
max-pool 10
authenticate register
voice register dn 1
number 3700
name Operator
voice register dn 2
number 3701
name PRO OFFICE
voice register dn 3
number 3702
name Rashid
voice register dn 4
number 3703
name Salim
voice register dn 5
number 3704
name test
voice register pool 1
id mac 0014.7F00.682A
number 1 dn 1
username mstuser1 password sale8833
codec g711ulaw
voice register pool 2
id mac 0014.7F00.64CA
number 1 dn 2
username mstuser2 password sale8833
codec g711ulaw
voice register pool 3
id mac 0014.7F00.6620
number 1 dn 3
username mstuser3 password sale8833
codec g711ulaw
voice register pool 4
id mac 0014.7F00.69D1
number 1 dn 4
username mstuser4 password sale8833
codec g711ulaw
voice register pool 5
id mac 0014.7F00.64A4
number 1 dn 5
username mstuser5 password sale8833
codec g711ulaw
voice-port 0/1/0
trunk-group FXO
input gain -3
output attenuation -1
echo-cancel coverage 64
no comfort-noise
cptone OM
connection plar opx 3705
music-threshold -45
bearer-cap Speech
caller-id enable
voice-port 0/1/1
trunk-group FXO
input gain -3
no comfort-noise
cptone OM
music-threshold -45
bearer-cap Speech
caller-id enable
voice-port 0/1/2
trunk-group FXO
input gain -3
no comfort-noise
cptone OM
music-threshold -45
bearer-cap Speech
caller-id enable
voice-port 0/1/3
trunk-group FXO
input gain -3
no comfort-noise
cptone OM
music-threshold -45
bearer-cap Speech
caller-id enable
dial-peer voice 16 voip
destination-pattern 2000
session protocol sipv2
session target ipv4:10.1.210.200
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2 pots
trunkgroup FXO
tone ringback alert-no-PI
description National
destination-pattern 92.......$
fax rate disable
prefix 2
dial-peer voice 4 pots
trunkgroup FXO
description International
destination-pattern 900.T
fax rate disable
prefix 00
dial-peer voice 1 pots
description ***Incoming from PSTN***
incoming called-number .
direct-inward-dial
dial-peer voice 3702 voip
description To CallManager Pub
destination-pattern 37..$
session target ipv4:10.50.2.3
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
req-qos guaranteed-delay audio
acc-qos guaranteed-delay audio
fax-relay ecm disable
fax rate 14400
fax nsf 000000
fax protocol pass-through g711ulaw
no vad
dial-peer voice 3 pots
trunkgroup FXO
destination-pattern 99.......
prefix 9
dial-peer voice 3701 voip
session target ipv4:10.50.2.4
voice-class codec 1
voice-class h323 1
fax rate 14400
fax nsf 000000
no vad
05-13-2012 09:41 AM
Some ideas:
- Use debug voip dialpeer to see dial-peer matching to make sure you're routing calls correctly.
- You don't need dial-peer 1 pots since true DID services in FXO can never be utilized. You're using connection plar to route inbound calls to a default location (perhaps to a recepcionist).
- To follow best practices (when you have Pub and Sub) you should route calls primarily to Sub and if Sub is down then you route calls to Pub. So, if dial-peer 3701 is for Sub you should configure it with a higher preference than dial-peer for Pub.
- Check if the h323 gw in UCM is defined with the IP address of the router's interface that has the h323-gateway voip bind srcaddr command.
- Check CSS of the h323 gw defined in UCM.
Hope it helps,
Kind regards,
- Adrian.
05-14-2012 01:13 AM
Following debug is ON to fix the issue
Voice Port Module port specific debugging is on for 0/1/0
CCAPI:
debug voip ccapi inout is ON (filter is OFF)
May 14 08:10:14.430: //-1/118CE82D87B3/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=9820
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
May 14 08:10:14.430: //-1/118CE82D87B3/CCAPI/cc_api_call_setup_ind_common:
Interface=0x3176D83C, Call Info(
Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=9820(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Incoming Dial-peer=0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Source Trkgrp Route Label=FXO, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
May 14 08:10:14.430: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 14 08:10:14.430: :cc_get_feature_vsa malloc success
May 14 08:10:14.430: cc_get_feature_vsa count is 1
May 14 08:10:14.430: :FEATURE_VSA attributes are: feature_name:0,feature_time:805690104,feature_id:83
May 14 08:10:14.430: //5412/118CE82D87B3/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=9820(TON=Unknown, NPI=Unknown))
May 14 08:10:14.430: //5412/118CE82D87B3/CCAPI/cc_process_call_setup_ind:
Event=0x2B913860
May 14 08:10:14.430: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 9820
May 14 08:10:14.434: //5412/118CE82D87B3/CCAPI/ccCallSetContext:
Context=0x32E9F4F8
May 14 08:10:14.434: //5412/118CE82D87B3/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 5412 with tag 0 to app "_ManagedAppProcess_Default"
May 14 08:10:14.434: //5412/118CE82D87B3/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
May 14 08:10:14.434: //5412/118CE82D87B3/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=FALSE, Mode=0,
Outgoing Dial-peer=1, Params=0x32E9A4E8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
May 14 08:10:14.434: //5412/118CE82D87B3/CCAPI/ccCheckClipClir:
In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Destination Pattern=9820, Called Number=9820, Digit Strip=FALSE
Redirect Number=, Display Info=
Account Number=, Final Destination Flag=TRUE,
Guid=118CE82D-9CD3-11E1-87B3-943A7377E196, Outgoing Dial-peer=1
May 14 08:10:14.434: //5412/118CE82D87B3/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=9820
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
May 14 08:10:14.434: //5412/118CE82D87B3/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x2B69F1EC, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=9820(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1, Call Count On=FALSE,
Source Trkgrp Route Label=FXO, Target Trkgrp Route Label=, tg_label_flag=1, Application Call Id=)
May 14 08:10:14.434: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 14 08:10:14.434: :cc_get_feature_vsa malloc success
May 14 08:10:14.434: cc_get_feature_vsa count is 2
May 14 08:10:14.434: :FEATURE_VSA attributes are: feature_name:0,feature_time:805689880,feature_id:84
May 14 08:10:14.434: //5413/118CE82D87B3/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
May 14 08:10:14.434: //5413/118CE82D87B3/CCAPI/ccCallSetContext:
Context=0x32E9A498
May 14 08:10:14.434: //5412/118CE82D87B3/CCAPI/ccSaveDialpeerTag:
May 14 08:10:14.438: //5413/118CE82D87B3/CCAPI/cc_api_call_proceeding:
Interface=0x2B69F1EC, Progress Indication=NULL(0)
May 14 08:10:15.158: //5413/118CE82D87B3/CCAPI/cc_api_call_disconnected:
Cause Value=17, Interface=0x2B69F1EC, Call Id=5413
Call Entry(Responsed=TRUE, Cause Value=17, Retry Count=0)
May 14 08:10:15.158: //5412/118CE82D87B3/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
May 14 08:10:15.158: //5413/118CE82D87B3/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=5413
May 14 08:10:15.158: //5413/118CE82D87B3/CCAPI/ccCallDisconnect:
Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=17)
Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
May 14 08:10:15.158: //5413/118CE82D87B3/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2B69F1EC, Tag=0x0, Call Id=5413,
Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
May 14 08:10:15.158: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 14 08:10:15.158: :cc_free_feature_vsa freeing 3005DA10
May 14 08:10:15.158: vsacount in free is 1
May 14 08:10:15.158: //5412/118CE82D87B3/CCAPI/ccCallDisconnect:
Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
May 14 08:10:15.158: //5412/118CE82D87B3/CCAPI/cc_api_get_transfer_info:
May 14 08:10:45.158: //5412/118CE82D87B3/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3176D83C, Tag=0x0, Call Id=5412,
May 14 08:10:45.158: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 14 08:10:45.158: :cc_free_feature_vsa freeing 3005DAF0
May 14 08:10:45.158: vsacount in free is 0
05-14-2012 05:51 AM
DEBUG H245 OUTPUT:
May 14 10:53:03.793: Changing to new event: CONNECT
h323chan_chn_connect: connecting to 10.50.2.4:1720
May 14 10:53:03.793: h323chan_gw_conn: Created socket fd=3
May 14 10:53:03.793: h323chan_gw_conn: connect in progress on fd=3h323chan_chn_connect: using fd=3, owner_data(ccb) 0x3001D3D4
changing from NONE state to CONNECTING state
May 14 10:53:04.161: h323chan_chn_process_read_socket: fd=3 of type CONNECT_PENDING has data
May 14 10:53:04.161: Changing to new event: CONNECTED
changing from CONNECTING state to CONNECTED state
May 14 10:53:04.161: h245_encode_faststart
May 14 10:53:04.161: h323chan_chn_process_read_socket: fd=3 of type CONNECTED has data
May 14 10:53:04.161: h323chan_recvdata: No Data on fd=3
PROCESS_READ: FAILED/NOT COMPLETE,rc 10, fd=3
May 14 10:53:19.161: h323chan_close: TCP connection from fd=3 closed
May 14 10:53:19.161: Changing to new event: CONNECT
h323chan_chn_connect: connecting to 10.50.2.3:1720
May 14 10:53:19.161: h323chan_gw_conn: Created socket fd=3
May 14 10:53:19.161: h323chan_gw_conn: connect in progress on fd=3h323chan_chn_connect: using fd=3, owner_data(ccb) 0x3001D3D4
May 14 10:53:19.785: h323chan_chn_process_read_socket: fd=3 of type CONNECT_PENDING has data
May 14 10:53:19.785: Changing to new event: CONNECTED
May 14 10:53:19.785: h245_encode_faststart
May 14 10:53:19.789: h323chan_chn_process_read_socket: fd=3 of type CONNECTED has data
May 14 10:53:19.789: h323chan_recvdata: No Data on fd=3
May 14 10:53:34.789: h323chan_close: TCP connection from fd=3 closed
