04-27-2013 06:54 AM - edited 03-16-2019 05:02 PM
Hi All
I want to configure H323 Trunk between CME and Avaya S8300(With E1 Module ) , and I have my Question is :
- what is the POTS Dial Peers i need ?
- what is the VOIP dial peers i need ?
Note: i need to press 9 first to go out side then press the number (mobile or home line)
Note: the phones are registered in CME , not in avaya
Note : mobile number range is 569XXX XXX , and home lnline is 2XXX XXXX
please give me the sample configuration based on my requirements .
thanks and regards
Solved! Go to Solution.
04-27-2013 07:02 AM
Hello
Kidnly find the below link which will be so usefull
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns829/467019.pdf
Thank you
pleae rate if this will help
04-27-2013 07:02 AM
Hello
Thank you
04-27-2013 07:11 AM
Thanks islam so much
04-27-2013 07:14 AM
you are very welcome , please share wirh us if you face any problem. We are with you for any help or any assistance.
Thank you
04-30-2013 06:13 AM
Dear Islam
I have CME , I have some questions :
- where i will configure the greeting like in CME or CUE :
" welcome to the XX company if you the extension press it now or , 1 for sales department , 2 for Maintence department " and this should be in arabic and english
- Do have any link and video training link to show me how to configure greeting in CME ?
- i can configure this greeting in CME or i need to configure CUE on it to configure this greeting ?
- Do i need a script editor to configure CUE or CME like IPCC ? or just access through GUI ?
your answers are very important for me
thanks
04-30-2013 03:32 PM
hello
You have two options
1-You can configure an AA on Cisco unity express .
2-If you do not have CUE , on CME you can configure B-ACD which will help you also for you.
3-For question about script it will be like IPCC do not worry about it . For CUE you can use web page to edit the welcome message and add actions for 0 go to operator and so on . there is script you can edit by eazy way as the examples which you will find below.
Thank you
please rate if this will help
04-30-2013 03:33 PM
Hello
kindly find the below links , i am waiting for any help and any assistance.
CUE AA
http://www.youtube.com/watch?v=XZ4QbH84Yvc
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/design/design21/cueaades.html
http://www.andovercg.com/datasheets/cisco-unity-express-voice-mail.pdf
CME B-ACD
https://supportforums.cisco.com/docs/DOC-16934
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/bacd/configuration/guide/40bacd.html
https://supportforums.cisco.com/docs/DOC-9527
http://pandaeatsbamboo.blogspot.com/2012/02/b-acd-drop-through-option.html
Thank you
04-30-2013 03:47 PM
Hello
Kindly find also below other way to configure the AA on CUE using CLI commands , it will be helpful also.
Step 1:
CUE:
groupname Administrators member user1
ccn trigger sip phonenumber 3600 (( 3600 AA which will be your responsible for AA))
application " autoattendant"
enabled
maxsessions 3
end trigger
exit
ccn application autoattendant
parameter "operExtn" "3001" (( 3001 your operator))
end application
////on your router///
dial-peer voice AA voip
destination-pattern 3600
session protocol sipv2
session target ipv4:x.x.x.x (IP of your CUE)
dtmf-relay sip-notify
codec g711ulaw
Step 2:
To record a new prompt and replace the default welcome greeting, perform the
following: You have two ways (( 1- record message using windows recorder then upload to flash 2- record using Cisco IP phone))
for Cisco IP phone on Cisco unity express you have to define phone 1 as admin
Step 3:
From IP Phone 1, dial number 3555 and login with your credentials. Select “2” to
manage custom prompts and record a new prompt.
Step 4:
Display the prompts in the system and notice the new recorded prompt:
CUE# show ccn prompts
CUE# ccn rename prompt AAWelcome.wav AAWelcome_orig.wav language en_US
Step 5:
Finally, rename the new recorded prompt to “AAWelcome.wav” using the
following command:
CUE# ccn rename prompt UserPrompt_01102009011309.wav AAWelcome.wav
lanuage en_US
Thank you
