Hair pinning
Rajnath Singh
Is it possible to configure a hair pinning config where two IP phones try to call each other via the same Gateway without configuring a POTS dial peer? What are the relevant configs for MGCP / H.323 / SIP Gateways?
RS.
What is throwing me off here is that the tendency is to assume that IP phones are leveraging a call procesing agent of some sort. A host that is responsible for call control. We are typically used to a client/server model when it comes to IP phone signaling. We assume phones are dumn, IOW.
So, with that in mind, Java was mentioning CME because it is a feature that can be loaded on a gateway to allow IP phones to register and communication. CME is basically a PBX (or key system if you must) and a SIP registrar/proxy. CME stands for Communications Manager Express. It is a licensed feature (i.e. pay for it).
You asked about SIP phones. So, CME with SIP configs can be found on CCO. One example:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00808f33eb.shtml
Now, if your phones can operate in a peer-to-peer mode then you I suppose you can use a cisco gateway to route calls using voip dial-peers. You would need to have the ability to route IP-to-IP calls. This is also a licensed feature set. Search for Cisco Unified Border Element (CUBE).
HTH.
-Bill (@ucguerrilla)
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Jaime Valencia
So, are you asking how to get two phones in the same GW to call each other and not hairpinn??
First of all, if all you got is a GW, then MGCP is not an option.
You can use CME, review the online documentation on it.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Jamie,
Basically I want 2 phones in the same GW to call eack other. Is there any way to do it via H.323 / SIP, if so are there any sample configs?
RS...
HTH.
malvo
hair band, or headband, is a flexible band worn around the head to hold hair in place or as a fashion accessory. hey come in various materials, widths, and designs, serving both practical and fashion purposes.
