01-26-2016 11:56 PM - edited 03-17-2019 05:38 AM
Hi All,
Please help me to get details about Hardware and software compactibilty for CUCM/CUC/CUPS.
Thank you,
Arjun Kamble
Solved! Go to Solution.
01-27-2016 12:05 AM
For CUC:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/compatibility/matrix/cucclientmtx.html
For CUCM and IM&P:
http://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-callmanager/products-device-support-tables-list.html
Deepak
01-27-2016 12:08 AM
For Hardware Compatibility, refer to below document:
http://docwiki.cisco.com/wiki/Unified_Communications_in_a_Virtualized_Environment
Deepak
01-28-2016 06:28 AM
http://lmgtfy.com/?q=unity+connection+hardware+compatibility+matrix
http://lmgtfy.com/?q=unified+presence+hardware+compatibility+matrix
http://lmgtfy.com/?q=communications+manager+hardware+compatibility+matrix
FYI, at the very least, if you're going to ask this, you need to mention for which versions you're asking, no mind readers here. As you failed to provide that info, use the above, and look for the version you're going to use.
01-27-2016 12:05 AM
For CUC:
For CUCM and IM&P:
Deepak
01-27-2016 11:13 PM
No need to rate if you do not find something helpful. Rating of 1 is not helping anyone, there are lot of efforts which goes in replying on the community apart from our regular work that we do.
Deepak
01-27-2016 12:08 AM
Deepak
01-27-2016 11:08 PM
Hi Deepak,
Thank you for prompt reply, Given links are not valid for required details. I need exact hardware(Hard Disk in GB/ RAM in GB) and software of server like MCS or IBM IDS server. and I need this details for CUCM/CUC/CUPS Services.
Could you please provide me exact details
Thank you,
Arjun Kamble
01-27-2016 11:21 PM
http://www.cisco.com/c/en/us/products/collateral/unified-communications/7800-series-media-convergence-servers/prod_brochure0900aecd8062a4f9.html
Deepak
01-27-2016 11:09 PM
Hi All,
Thank you,
Arjun Kamble
01-28-2016 06:28 AM
