06-29-2011 12:35 PM - edited 03-16-2019 05:42 AM
I´m trying to install a CUCM 6.1.4 in a MCS7845I3-K9-CMC2 V02, but appears this error message:
Critical Error:
The hardware you are using is not supported for this product. Installation will now halt.
What could be the problem?
Solved! Go to Solution.
06-29-2011 12:42 PM
According to the supported servers by release document the 7845I3 wasn't supported until 6.1(5) or 7.1(3). You need to use a newer software version.
06-29-2011 12:42 PM
07-05-2011 05:39 PM
Thanks Jonathan, I installed the version 6.1.5 and works.
