881
jonathanwalton
Beginner
Has anyone successfully created a SIP trunk to lenny@sip.itslenny.com in CUCM?
I have tested with a non-cisco sip client to ensure it’s not a firewall issue, but CUCM seems to only want to trunk to an IP address. Any ideas how to trunk to lenny@sip.itslenny.com:5060 in CUCM?  I'm running 7.15.
http://itslenny.com/ for anyone curius about what I'm trying to do
1 REPLY 1
mkchandak
Beginner
As what you are referring to is a destination, using SIP trunk to itslenny.com wouldn't work. You need to setup a trunk from an ISP and use lenny@itslenny.com as the destination. If you don't have a SIP trunk, you need to route calls using a DID.
HTHs
Create
Recognize Your Peers
Content for Community-Ad
