Have problems to get video capabilities(vendor config) of phone if Override Common Settings not checked
donTIM111
I try to get video capabilities(vendor config) by using following Query:
CUCM Version 8
Tables (depands of size):
devicexml4k, devicexml8k,  devicexml16k
Query
SELECT
     devicexml4k.xml
FROM
     device, devicexml4k
WHERE
     device.pkid = devicexml4k.fkdevice
AND
     device.pkid = "pkid_of_phone';
Phone Configuration
If the checkbox Override Common Settings next to Video Capabilities is checked, then i get my video capabilities. Otherwise i don't get them.
The method getPhone outputs the same result.
My Question
     -Do you know in which table in the database I can find the default settings for the video capabilities for the phone?
     -or any ideas how I can solve the problem?
Sergej
jhindmarsh
I just experienced an issue with a customer, unless I checked in the box to Override Common Settings, the video capabilities on the phone devices was still defaulted to NO.
What is "Override Common Settings"?  It is available to select under "Enterprise Phone Configuration", under "Common Phone Profile, and under the device settings of a phone.  What does it actually do?
Jesse
