Beginner
Having Trouble Getting BLF Feature to Work on CP-8851 Phone
I have a CP-8851 phone set up to monitor a few extension numbers using the BLF feature but the assigned buttons do not light up when the monitored lines go off hook even though the buttons are assigned as sd blf keys.  I can assign one of the same extensions to my 8865 phone and it works like it should.  Active 8841 phone load version is sip88xx.12-0-1-11 and the Call Manager version is 11.5.1.12900-21.  The load version on my 8865 is sip8845_65.12-0-1-11.  Any help would be appreciated.
Dale Shew
dshew@uabmc.edu
1 ACCEPTED SOLUTION
Highlighted
VIP Advisor
Re: Having Trouble Getting BLF Feature to Work on CP-8851 Phone
Are you using subscribe_css or presence group, if so you need to make sure
that permissions are granted to watch these DNs.
***** remember to rate useful posts
2 REPLIES 2
Highlighted
VIP Advisor
Beginner
Thanks for your help Mohammed.  That was it.
Content for Community-Ad
August's Community Spotlight Awards
