07-02-2021 12:57 AM
Hi Guys
Having Trouble Register 9971 to UC 14 (all services are activated) , it does register to 12.5 su4 but not register to UC14
Pls note after successful registration to UC 12.5 i reseted the phone to factory default in order to go blanc with UC14
07-02-2021 01:09 AM
Whats the status message you see on the phone's. since you reset the phones to factory, can you make sure after reset phone has all required information to register with CUCM 14.
Make sure the old CTL/ITL which phone downloaded from CUCM 12.5 got moved before connecting to CUCM 14.
07-02-2021 03:04 AM - edited 07-02-2021 03:53 AM
Hi bro nithin
message keeps show on the phone's screen like Phone Not registered
btw , I did the same settings on UC 12.5 and registred but not on UC 14
yes , i deleted old CTL/ITL
How to debug on CUCM to find the root cause of registration issue ?
thanks
07-02-2021 06:54 AM
What does the phone status message says.
07-02-2021 07:04 AM
Hi bro nithin
thanks
07-02-2021 08:34 PM - edited 07-02-2021 08:43 PM
The message you posted is from the phone display, what does the status message says. you need to go to the phone setting and see the status message.
You can take the CUCM logs using RTMT. Go through the below video.
07-03-2021 09:17 AM
Getting Status Msgs like no Trusted list intalled , TFTP TimeOut SEPAAAABBBBCCCC , eventhough the Phone has connectevity to cucm
thanks
07-04-2021 07:10 PM - edited 07-04-2021 07:10 PM
If phone can communicate with the CUCM and if network settings are correct , check if there config file avaible on the TFTP. Hope you assigned DN for this phone.
http://TFTP-IP:6970/SEPAAAABBBBCCCC.cnf.xml.sgn
07-03-2021 12:48 AM - edited 07-03-2021 01:07 AM
Hi bro nithin
I don't know what happened with 9971 with UC 14 ,I Think something is hidden
9971 register smoothly to UC 12.5 SU4 , but not with UC 14 ,
Bro , 8845 registered smoothly with UC 14
the video quality is bad
thanks
thanks
Ibrahim
Jordan
THANKS
