Hi all,
Someone can tell me if VG 310 is supported in HCS 9.1.1 ? From what I read in the product data sheet "Cisco VG Series Analog Voice Gateways", I understood that it is only compatible with versions 9.1(2)SU2 or later . In HCS compatibility" Cisco Hosted Collaboration Solution documents Compatibility Matrix" reference only against the vg350. Someone can tell me how can i confirm this doubt or if it is compatible or not? Is there any device package that can add this VG310 to CUCDM database without having to upgrade (like in CUCM) ?
Best Regards
