10-12-2012 06:57 AM - edited 03-16-2019 01:39 PM
I ran into a strange issue with an FXS port and am wondering if anyone knows what might cause this. Calls come in and out but when dialing from an analog phone connected to the FXS port we don't hear it ringing, just silence until the remote side picks up. There is dial tone, just no ringing after the number is dialed. Any idea what might cause this?
Solved! Go to Solution.
10-15-2012 08:58 PM
You may also upgrade IOS on the 2811 router to a more stable version, if you take a look on:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html
Page 105, you can find the link for the recommended IOS for CUCM 7.x
Jorge Armijo
Sent from Cisco Technical Support Android App
10-12-2012 07:27 AM
Begin mentioning system, version, and configuration you're using-
10-12-2012 09:06 AM
Using a Cisco 2811, with VIC2-2FXS module. C2800NM-ADVIPSERVICESK9-M, Version 12.4(3i)
The router is an H.323 gateway with CCM7.1 PBX.
interface Serial0/0/0:23
no ip address
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
voice-card 0
no dspfarm
dsp services dspfarm
voice-port 0/2/0
voice-port 0/2/1
dial-peer voice 4000 voip
destination-pattern [1-8]...
modem passthrough nse codec g711ulaw
voice-class codec 1
voice-class h323 1
session target ipv4:{ip removed}
incoming called-number .
dtmf-relay h245-alphanumeric
fax rate disable
no vad
dial-peer voice 100 pots
description Office Fax
huntstop
destination-pattern {10-digit phone number here}
clid network-number {10-digit phone number here}
port 0/2/0
10-12-2012 09:15 AM
To connect an analog phone to CUCM, you should use SCCP not H.323.
Anyway, check:
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/voice_troubleshooting/old/vts_h323.html#wp1039325
10-14-2012 02:55 PM
Thanks, I willl look at that guide. As for the SCCP vs H.323, we use this same config at many sites and they work just fine and I'm starting to wonder if it's just a bug or incompatability with the version I have on this router.
10-14-2012 04:33 PM
On CUCM Admin
System --> Service Parameters -->CallManager
Look through the clusterwide H323 settings
Under the "Send H25User Info Message selection",
verify that the box for No Ringback is not checked
and the box for "User Infro for Ring Back Tone" is checked.
Alex.
Please rate useful posts.
10-16-2012 02:28 PM
@ acampbell
Checked my service parameters and while I didn't have any checkboxes to select, there was a drop down menu but it had "User Info for Call Progress Tone" already selected. Also, we have 20+ branch offices using the same configuration and they work fine. I did upgrade the IOS over the weekend and I'm now waiting to have someone on-site test to see if that fixed it.
10-15-2012 08:58 PM
Jorge Armijo
10-15-2012 10:16 PM
What happens when you dial station-to-station? Call another desk in the building. Tell them not to answer the phone. Do you get the ring back? Perform a call trap in the router on an outbound call and see if the SIP message indicates TRYING and RINGING.
This will isolate the issue to the UCM/Call Manger or the router config.
10-17-2012 07:14 AM
Seems the firmware upgrade took care of it.
Big "Thank You" to everyone who chimed in.
10-17-2012 10:00 AM
Hey,
Great to hear that the upgrade worked.
Thanks for the good rating!
Jorge Armijo
