11-19-2012 09:44 AM - edited 03-16-2019 02:16 PM
Hi all,
I hav a Problem, recently I change a branch office to a different device pool serviced y by diferentes Call Managers subscribers (also I change the dial plan a little), I use Call Manager 8.6 and I am experienced problems here are the fact.
1.- The CUE is a ISM on the router
2.- the ISM is registered on a call manager cluster, as a CTI port and CTI route points.
3.- Calls from inside the network (voip) to the cue are succesful.
4.- Calls from PSTN do enter but do not stablish a codec.
These are the steps in a incomming call.
PSTN --> Gateway --> dial-peer --> Call Manager --> CTI route point (or phones) --> Call
It is strange because all incomming calls do not work, and but it works on the outgoing calls.do work well.
Here are some debugs.
The call do not establish de codec
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0xB3C0 39E3 0x29EAFDDC 0/0/0:0.31 0/1:2 888887101 None 9/9999
1 active call found
1 active call found
1 active call found
1 active call found
No good answer for disconnect calls.
#show dial-peer voice 9999
redirect ip2ip = disabled
local peer = false
probe disabled,
Secure RTP: system (use the global setting)
voice class perm tag = `'
Time elapsed since last clearing of voice call statistics never
Connect Time = 333749446, Charged Units = 0,
Successful Calls = 8606, Failed Calls = 205, Incomplete Calls = 35
Accepted Calls = 10305, Refused Calls = 899,
Last Disconnect Cause is "0 ",
Last Disconnect Text is "",
Last Setup Time = 1116926401.
Last Disconnect Time = 1115056827.
"Debug ccapi ino" command do not show good information
ov 19 17:30:21.566: //227/A109076C8247/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=8180887191
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=888887101
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Nov 19 17:30:21.566: //227/A109076C8247/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x3095A358, Interface Type=1, Destination=, Mode=0x0,
Call Params(Calling Number=8180887191,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=888887101(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=9999, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Sub Calling(TON=Abbreviated, NPI=Unknown, Data=r(, Length=48)
Sub Called(TON=National, NPI=National, Data=\B(0gsX, Length=24)
Nov 19 17:30:21.566: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 19 17:30:21.566: :cc_get_feature_vsa malloc success
Nov 19 17:30:21.566: cc_get_feature_vsa count is 2
Nov 19 17:30:21.566: :FEATURE_VSA attributes are: feature_name:0,feature_time:708754808,feature_id:228
Nov 19 17:30:21.566: //228/A109076C8247/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Nov 19 17:30:21.566: //228/A109076C8247/CCAPI/ccCallSetContext:
Context=0x2A3F4750
Nov 19 17:30:21.566: //227/A109076C8247/CCAPI/ccSaveDialpeerTag:
Nov 19 17:30:27.134: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
ccAppShutdownMode: remove it from the queue
Nov 19 17:30:36.562: //227/A109076C8247/CCAPI/cc_api_call_disconnected:
Cause Value=0, Interface=0x40765E98, Call Id=227
Call Entry(Responsed=FALSE, Cause Value=0, Retry Count=0)
Nov 19 17:30:36.562: //228/A109076C8247/CCAPI/ccCallDisconnect:
Cause Value=0, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=0, Call Entry(Responsed=FALSE, Cause Value=0)
Nov 19 17:30:36.562: //228/A109076C8247/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
Nov 19 17:30:36.562: //227/A109076C8247/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Nov 19 17:30:36.562: //227/A109076C8247/CCAPI/cc_api_get_transfer_info:
Nov 19 17:30:36.562: //228/A109076C8247/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3095A358, Tag=0x0, Call Id=228,
Call Entry(Disconnect Cause=0, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Nov 19 17:30:36.562: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 19 17:30:36.562: :cc_free_feature_vsa freeing 2A3EBD70
Nov 19 17:30:36.562: vsacount in free is 1
Nov 19 17:30:45.630: //227/A109076C8247/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x40765E98, Tag=0x0, Call Id=227,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Nov 19 17:30:45.630: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 19 17:30:45.630: :cc_free_feature_vsa freeing 2A3EBAD0
Here is my dial-peer configuration.
dial-peer voice 9999 voip
preference 1
destination-pattern 8........
session target ipv4:10.0.0.1
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
ip qos dscp ef signaling
no vad
dial-peer voice 9 pots
description *** Llamadas LOCALES ***
destination-pattern 9[1-9].......
incoming called-number .
direct-inward-dial
port 0/0/0:0
forward-digits 8
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
* The calling search spache for inbound call of the GW h323 do actually reach the partition where the DN are.
All my phones and CTI route points are registered in a subscriber 10.0.0.1
here are my trusted list.
GWRUVVoIP#show ip address trusted list
IP Address Trusted Authentication
Administration State: UP
Operation State: UP
IP Address Trusted Call Block Cause: call-reject (21)
VoIP Dial-peer IPv4 Session Targets:
Peer Tag Oper State Session Target
9999 UP ipv4:10.0.0.1
IP Address Trusted List:
ipv4 10.0.0.0 255.0.0.0
¿What seems to be the problem?
reggards.
11-19-2012 11:58 AM
Another debug.
I use the comman csim to test conectivitity, it works on every other voIP-pstn router, but not in wich I have the problem.
Nov 19 19:56:15.621: xrule_checking
Nov 19 19:56:15.621: xrule_checking calling , called 888882016
Nov 19 19:56:15.621: xrule_checking peer_tag 9999, direction 2, protocol 0
Nov 19 19:56:15.621: xrule_checking Return rc = -5
csim err csimDisconnected recvd DISC cid(303)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
If I can make the csim command to work, the problem of CUE will be fixed.
