Help configuring SM-SMR-700-KB voice module on seperate 2911 router
Clay Plaga
Level 3
Level 3
I have a test network setup in my house. I have 2 Cisco 2911 routers with a switch module installed. One of the 2911 routers is my main switch\router. I have a switch module installed on this router. I am using both slots on this router, one slot has a PoE power supply, and the other slot has the switch module installed. I also have my Cisco phone configuration on this router. I have a second Cisco 2911 switch\router that I am not using. I have a voice mail module installed in this second router. Can I connect the second router to the network and run my voice mail module from this second router?
Any assistance will be appreciated.
Thank you.
I have added a public video description from gdrive
https://drive.google.com/file/d/1gDD9EepV2cRHjh3pvdlfbtMCDMrqI7wE/view?usp=sharing
its possible to make use of the second router for the Voice Mail.
Response Signature
Response Signature
Thank you. Is there a guide or documentation to get me started with this configuration?
