Help to Set up Access code for Incoming call for an particular DID
Murali shankar
Here is the requirement. When an Inbound call comes to a particular DID (1234) . The Number should prompt for the access code , once the code is entered it should reach the DID(1234). How can i set-up this?
Call Manager 10.5
Unity - 8.5
Jaime Valencia
There is no built-in feature to do what you're asking on any of what you mention, your options would be to build a TCL script or use UCCX/UCCE.
java
if this helps, please rate
Thanks.
Is there any suggestion we can provide other than going for TCL Script in UCCX/UCCE.
Just for clarification, TCL scripts are configured in the GW.
java
