Walkthrough Wednesdays
165
Help VoIP bandwith calculation over an SD-WAN Link.
Hi Pals,
We were discussing today about how much bandwidth we need to allocate per call or per connection to incoming and outgoing voice. SD-WAN has for some reason degradated the quality of the normal voice operation compared against the MPLS or Metro-Ethernet.
I am trying to figure it out: 1. if the Legacy VoIP Standard also applies to the SD-WAN and how much percentage needs to be assigned to voice.
IE:
300 ms latency
30 ms jitter
1% packet drop.
30% bandwidth allocated to priority for voice
is all that still valid for SD-WAN?
2. Also, please help me to answer this question.
How much bandwidth per call do I need to allocate from my links if the codec is G711 or G729.
I know we need to calculate payload, L2, L3/UDP overhead... and that's it? no GRE or IPSEC or Site to Site VPN? for the calculation?
Thank you very much for your help.
2 REPLIES 2
Roger Kallberg
VIP Advisor
The encryption protocol header(s) would need to be included in the L3 overhead in your calculation. What medium are you using for your SD-WAN?
Please rate all useful posts
Well, the way I think the way we are doing it, is:...
SDWAN Device --> Ethernet Cable --> Cox Internet --> Coaxial Cable --> SDWAN Carrier MPLS Cloud 1 --> ENTERPRISE MPLS Cloud 1  --> Enterprise Data Centers.
We are using the local internet as a undelay connection to route to the SDWAN Carrier MPLS Cloud 1 then Enterprise MPLS.
Do you guys have a recommendation for G711 QoS for these cases?
Content for Community-Ad
Spotlight Awards 2021
