i need to configure the cards on the MGCP the problem im not sure about slot 1 and slot 2 on the 4451 , is the slot 1 on the right or the left when imf acing the device?
The installation guide has diagrams which explain every part of the ISR, plus, there should be a sticker in the back that explains how the slots are numbered.
java
if this helps, please rate
