01-02-2013 07:54 AM - edited 03-16-2019 02:57 PM
I'm sure there is a way to do this I'm just not sure how:
When someone leaves the company and is back filled by someone else there is a whole host of other people who have the old persons name on their side car or phone as a speed dial. Is there a bulk aministration that can "find and replace" the old person name with the new? I was trying to just rely on people to let me know when they needed updating,......but you know how THAT goes.
Thank you.
Solved! Go to Solution.
01-02-2013 08:21 AM
I typically advise users to login to the ccmuser interface and manage their own speeddials, upselling the fact that they can manage their speeddials at will, forward their phone remotely (with remote access of course), etc.
I wouldn't make the updates via sql directly, but if you're managing speeddials then pulling data via sql on the cli will save you time.
ie 'run sql select * from speeddial where label like '%xyz%'
or '...where speeddialnumber = '1234'
speeddial and blfspeeddial are the relevant tables.
01-02-2013 07:55 AM
No, BAT doesn't have that capability.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
01-02-2013 08:02 AM
Just curious then....how do you keep up with it all? I assign speed dials to people link a Ronco Rotisserie..."I set it and forget it". If they don't tell me to update then it seems that things get messy real quick.
01-02-2013 08:21 AM
01-02-2013 08:40 AM
Yes you are right it is time to unleash ccmuser. It's all ready to go, but I need to get a training sheet together, and then it's on them...
Thanks that really is the best solution. I have enough to worry about:)
