02-18-2016 02:24 PM - edited 03-17-2019 05:57 AM
when we plugged a phone (POTS) line into a FXO port and called it we did not see the port even
recognizing the incoming call.
I made and minor adjustment and did shut/ no shut and got a odd output, at that time I also had debug vpm sig on
R-BAY-SAMA(config)#voice-port 0/1/0
R-BAY-SAMA(config-voiceport)#shut
Feb 18 22:15:52.061: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_HTSP_IF_OOS]htspm_mgt_state
Feb 18 22:15:52.061: htsp_timer_stop
Feb 18 22:15:52.061: htsp_timer_stop2
Feb 18 22:15:52.061: htsp_timer_stop3
Feb 18 22:15:52.061: htsp_timer_stop_mlpp
Feb 18 22:15:52.061: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/0, changed state to Administrative Shutdown
Feb 18 22:15:52.061: htsp_process_event: [0/1/0, S_OPEN_PEND, E_DSP_INTERFACE_INFO]
Feb 18 22:15:52.165: htsp_dsp_message: SEND_SIG_STATUS: state=0x0 timestamp=57139 systime=1591949
Feb 18 22:15:52.165: htsp_process_event: [0/1/0, S_DOWN, E_DSP_SIG_0000]
R-BAY-SAMA(config-voiceport)#no shut
Feb 18 22:15:59.517: htsp_process_event: [0/1/0, S_DOWN, E_HTSP_IF_INSERVICE]
Feb 18 22:15:59.517: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/0, changed state to up
Feb 18 22:15:59.517: Foreign Exchange Office 0/1/0 rx_signal_map:
F F F F
5 F F F
F F F F
F F F F
Feb 18 22:15:59.517: [0/1/0] set signal state = 0x4 timestamp = 0
Feb 18 22:15:59.517: Foreign Exchange Office 0/1/0 tx_signal_map:
0 4 4 4
4 4 6 4
C C C C
C C C C
Feb 18 22:15:59.517: htsp_process_event: [0/1/0, S_OPEN_PEND, E_HTSP_GO_UP]
Feb 18 22:15:59.521: htsp_dsp_message: RESP_SIG_STATUS: state=0x0 timestamp=0 systime=1592684
Feb 18 22:15:59.529: Miscellaneous signaling debug data: (ch=4):
0004 0080 ABBA **
Feb 18 22:15:59.537: Miscellaneous signaling debug data: (ch=4):
0004 0080 ABBA **
Feb 18 22:15:59.545: Miscellaneous signaling debug data: (ch=4):
0004 0080 ABBA **
Feb 18 22:15:59.553: Miscellaneous signaling debug data: (ch=4):
0004 0080 ABBA **
Feb 18 22:15:59.561: Miscellaneous signaling debug data: (ch=4):
0004 0080 ABBA **
Feb 18 22:15:59.569: Miscellaneous signaling debug data: (ch=4):
0004 0080 ABBA **
Feb 18 22:15:59.577: Miscellaneous signaling debug data: (ch=4):
0004 0080 ABBA **
Feb 18 22:15:59.585: Miscellaneous signaling debug data: (ch=4):
0004 0080 ABBA **
Feb 18 22:15:59.593: Miscellaneous signaling debug data: (ch=4):
0004 0080 ABBA **
Feb 18 22:15:59.601: Miscellaneous signaling debug data: (ch=4):
0004 0080 ABBA **
Feb 18 22:15:59.609: Miscellaneous signaling debug data: (ch=4):
0004 0080 ABBA **
Feb 18 22:15:59.617: Miscellaneous signaling debug data: (ch=4):
0004 0080 ABBA **
Feb 18 22:15:59.625: Miscellaneous signaling debug data: (ch=4):
0004 0080 ABBA **
Feb 18 22:15:59.629: htsp_process_event: [0/1/0, FXOLS_NULL, E_HTSP_INIT]fxols_null_init
Feb 18 22:15:59.629: [0/1/0] set signal state = 0xC timestamp = 0
Feb 18 22:15:59.629: htsp_process_event: [0/1/0, FXOLS_INIT, E_HTSP_INSERVE]fxols_init_inserve
Feb 18 22:15:59.629: [0/1/0] set signal state = 0x4 timestamp = 0
Feb 18 22:15:59.629: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
Feb 18 22:15:59.629: htsp_timer - 125 msec
Feb 18 22:15:59.629: htsp_dsp_message: RESP_SIG_STATUS: state=0x0 timestamp=0 systime=1592695
Feb 18 22:15:59.629: htsp_process_event: [0/1/0, FXOLS_WAIT_RING_MIN, E_DSP_SIG_0000]
Feb 18 22:15:59.633: Miscellaneous signaling debug data: (ch=4):
0004 0080 ABBA **
Feb 18 22:15:59.757: htsp_process_event: [0/1/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
Feb 18 22:15:59.757: htsp_timer - 10000 msec
Feb 18 22:15:59.757: htsp_timer3 - 5600 msec
Feb 18 22:15:59.757: [0/1/0] htsp_start_caller_id_rx:Mode BELLCORE. Alerting 0x1
Feb 18 22:15:59.757: htsp_start_caller_id_rx create dsp_stream_manager
Feb 18 22:15:59.757: [0/1/0] htsp_dsm_create_success returns 1
Feb 18 22:16:05.357: htsp_process_event: [0/1/0, FXOLS_RINGING, E_HTSP_EVENT_TIMER3]fxols_snoop_clid_stop
Feb 18 22:16:05.357: htsp_timer_stop3
Feb 18 22:16:09.757: htsp_process_event: [0/1/0, FXOLS_RINGING, E_HTSP_EVENT_TIMER]fxols_ringing_disc
Feb 18 22:16:09.757: htsp_timer_stop3
Feb 18 22:16:09.757: [0/1/0] htsp_stop_caller_id_rx. message length 0
Feb 18 22:16:09.757: [0/1/0] htsp_dsm_close_done exit
R-BAY-SAMA(config)#exit
R-BAY-SAMA#sh voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/0/0 -- fxo-ls up dorm idle on-hook y
0/0/1 -- fxo-ls up dorm idle on-hook y
0/0/2 -- fxo-ls up dorm idle on-hook y
0/0/3 -- fxo-ls up dorm idle on-hook y
0/1/0 -- fxo-ls up dorm idle on-hook y
0/1/1 -- fxo-ls up dorm idle on-hook y
0/1/2 -- fxo-ls up dorm idle on-hook y
0/1/3 -- fxo-ls up dorm idle on-hook y
that part that is odd is which is different from what our other routers get.
0004 0080 ABBA **
Any thoughts?
*update*
this is happening on all the FXO ports even though most of them do not yet have a POTS line even plugged into them yet.
